Question about Microsoft Xbox 360 Console
Xbox 360 - disc keeps ejecting
Every time I insert a disk into the drive it automatically ejects the disc
  • Anonymous Nov 12, 2008
    I have the same prob. That's you answer!? Take it back!!?? Lame!!
  • cab33 Dec 30, 2008
    im having the same problem...any idea if there is a way to check if my xbox is under warranty?
Take that shyt back or e.mail the maker of 360 an get a new 1 sent 2 u
Posted on Aug 25, 2008
The eject button on the xbox 360 does not work. Using the onscreen we are able to insert a game disc but no matter the game disc, the system cannot read it. We tried inserting discs several times but...
It has nothing to do with the eject button. if it clicks when you press it, then the button is fully functional. If the xbox has been opened up, and worked on before, look for things like severed traces, missing components, etc. But in all likelihood you are suffering from a fairly common hardware failure: a faulty disk drive. call microsoft and pray that youa re still under warranty. if not, then you have either shell out $100+, or open it up and replace the disk drive yourself.
Feb 04, 2011 | Microsoft Xbox 360 Console
Xbox 360 does not read disk when inserted. have to eject disk up to a dozen times before game starts!!!
Hello there.
Either your xbox optical drive is faulty and needs replacing, or if this only happens with one disk - the disc may be faulty.
I suggest trying another game in the console, if that works then maybe take the faulty disc back to where you purchased it, for a replacement.
Hope this helps.
Jul 03, 2008 | Video Game Consoles & Games
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
I went to put a game in the xbox to play,I waited for it to load & nothing happened.The screen said open tray.I waited & waited but nothing.I pressed the green button on the controller but the tray...
Well you may be having disk tray issues, sure hope so as compared to a burnt out lens module,try ejecting the tray fully and wiping all dust off around the grooves under the tray,one more tip is to keep a disk in the drive at all times, even when you aint playing it, you can also try giving it a gentle tap on the front pat where the disk tray is located any time you eject it or push the tray back in, come to think about it if you are fond of pushing the tray in after inserting a disc, stop cos it weakens the motor that drives the ejecting process, hope this helps...
Oct 25, 2010 | Microsoft Xbox 360 Console
I put in a disc. it says reading then goes back to open tray. Help me.
The most common reason for the Console saying reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Console including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Console going again!
Hope it works...
May 31, 2010 | Microsoft Xbox 360 Console
Eject disc
check the sata cable and the power on your drive other wise was the drive is the problem.
Mar 24, 2010 | Microsoft Xbox 360 Console
Hi,the door for putting disc in wont open.every time i push the button there is noise comn from machine like its trying to open but it cant?
This happens to me every now and then.
Here is how you can get around it:
Sometimes, you cannot open the disc tray on your Xbox 360 console by pressing the eject button. Any of the following things may cause this problem:
  • There is a hardware failure that affects the console, the disk drive, or the eject button.
  • A disc is lodged in the mechanism.
  • The clear protective plastic strip that is applied to the front of the tray to protect it during shipping is preventing the disc tray from opening.
To manually eject the disc from the disc tray, follow these steps:
  1. Unplug the power cord from your Xbox console. For more information about how to disconnect the power supply, click the following article number to view the article in the Microsoft Knowledge Base: 906205 (http://support.microsoft.com/kb/906205/ ) How to connect and disconnect your Xbox 360 power supply
  2. Position your Xbox 360 console horizontally, as you would position a VCR or a stereo component.
  3. Remove the faceplate from your Xbox console. For more information about how to remove the console faceplate, click the following article number to view the article in the Microsoft Knowledge Base: 907331 (http://support.microsoft.com/kb/907331/ ) How to attach or remove the faceplate on your Xbox 360 console
  4. Depending on the kind of disk drive that you have in your Xbox 360 console, you can use one of the following methods. Note In each case, make sure that you align the tool (a paper clip or stiff wire) to pass through another notch behind the hole on the console casing. Collapse this imageExpand this image906935.jpg
    • Method A: Insert a straightened paper clip or other small, stiff wire into the first hole from the left side of the disc tray. To release the disc tray, push the paper clip into the hole to press the manual eject mechanism. The manual eject mechanism is a white lever that is visible behind the console casing. The hole is located about 1.5 inches (approximately 4 centimeters) from the left edge of the disc tray.
    • Method B: Insert a straightened paper clip or other small, stiff wire into the second hole from the left side of the disc tray. Push the paper clip repeatedly into the hole to turn a gear to release the disc tray. The hole is located about 1.5 inches (approximately 4 centimeters) from the left edge of the disc tray.
    • Method C: Insert a straightened paper clip or other small, stiff wire into the hole that is directly under the "X3" logo on the Xbox 360 label on the disc tray to release the disc tray. The hole is located about 1 inch from the right edge of the disc tray.
  5. After you release the disc tray, the tray pops out slightly. You can pull the tray out the rest of the way to remove the disc. Note If you use method A or Method C in step 4, you may have to firmly press the disc eject mechanism to eject the disc tray.
  6. If you determine that a hardware failure has occurred that affects your Xbox console, contact Xbox Customer Support or submit a repair request for your Xbox 360 console.
(Information taken from: http://support.microsoft.com/kb/906935)
Hope it helped.
Nov 16, 2009 | Microsoft Xbox Console
Disc keeps ejecting
Sounds like your disc drive is malfunctioning. Honestly the only thing i could possibly think of is that the button for the disc drive could've gotten stuck and opens the 360 by any sudden movements.
Jul 01, 2009 | Microsoft Xbox 360 Console
Xbox 360
you need to send it off to get repaired
Aug 26, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
941 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
