Question about Canon CanoScan 3000F Flatbed Scanner
Power problem? Scanner does not respont to Scan, Copy or E-Mail command. I unplugged the power cord, but that did not solve the problem. Any other suggestions? Bob
Not work is scaner lanse?
Posted on Aug 25, 2008
How to solve scanner error 22 in HP laser jet 1213mfp
Perform a power reset.
Press the Power button to turn on the printer.
With the printer turned on , disconnect the power cord from the rear of the printer.
Wait at least 30 seconds. Reconnect the power cord to the rear of the printer.
update the firmware by download from this link: HP LaserJet Pro M1213nf Multifunction Printer Drivers
Jan 20, 2015 | HP Office Equipment & Supplies
Printer will not scan
he HP All-in-One product displays one of the following error messages on the control panel when scanning or copying:
  • Scanner failure, power off and on
  • Scanner System Failure
  • Scanner failed, cannot make copies or fax
  • Scanner failure. Unable to scan, copy, or send a fax
  • Scanner failure, cycle power
Additionally, the scanner bulb might not turn on during scanning.ry the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting.Solution one: Check the scanner lightFollow these steps to check the scanner light by making a color copy of any document.
  1. Load plain white, unused, letter size paper in the paper tray.
  2. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
  3. Make a color copy.
  4. When the product starts to scan the document to copy, slightly lift the scanner lid to see if the scanner light turns on. It is not necessary to lift the lid completely CAUTION:Do not look directly at the scanner light.The scanner light should be visible under the scanner glass to the right or left.Figure 1: Scanner light visible underneath the glass
    1 - Area where scanner light is visible2 - Scanner glass
    • If the scanner light does not turn on when the scanner mechanism moves across the scanner bed, continue to the solution to reset the product.
    • If the scanner light turns on , continue with the next solution.
    Solution two: Check the power connectionFollow these steps to troubleshoot the power connection.
    1. Press the Power button (c01602202.gif ) to turn off the product.
    2. Unplug the product power cord from any surge protector, extension cord, or power strip, and then connect the power cord directly to a wall outlet.
    3. Press the Power button (c01602202.gif ) to turn on the product.
    4. Load plain white, unused, letter size paper in the paper tray.
    5. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
    6. Try again to make a color copy.
      • If these steps resolved the issue , you do not need to continue troubleshooting.note.pngNOTE:If the product works properly when plugged directly into a wall outlet rather than a power strip or surge suppressor, the power strip or surge suppressor might not allow enough voltage for the product to work properly.
      • If the issue persists , continue with these steps.
    7. Press the Power button (c01602202.gif ) to turn off the product, disconnect the power cord from the wall outlet, and then reconnect the power cord to a different wall outlet.
    8. Press the Power button (c01602202.gif ) to turn on the product.
    9. Try again to make a color copy.
    • If the issue persists , continue to the next solution.
    Solution three: Reset the productFollow these steps to reset the product.
    1. Press the Power button (c01602202.gif ) to turn off the product.note.pngNOTE:The product might not turn off after pressing the Power button. Continue to the next step regardless.
    2. Disconnect the power cord from the rear of the product.
    3. Unplug the power cord from the electrical outlet.
    4. Wait 30 seconds.
    5. Replug the power cord into the electrical outlet.
    6. Reconnect the power cord to the rear of the product.
    7. Press the Power button (c01602202.gif ) to turn on the product.
    8. Load plain white, unused, letter size paper in the paper tray.
    9. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
    10. Try again to make a color copy.
Dec 11, 2011 | HEWLETT-PACKARD Officejet 4500 All-in-One...
After printer is on for a few minutes, getting error message-scanner failure turn printer off then on again. I am able to print before the error message appears, however, unable to copy or fax. Thank...
  1. Follow these steps to check the scanner light by making a color copy of any document.
  2. Load plain white, unused, letter size paper in the paper tray.
  3. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
  4. Make a color copy.
  5. When the product starts to scan the document to copy, slightly lift the scanner lid to see if the scanner light turns on. It is not necessary to lift the lid completely.
  1. Press the Power button to turn off the product.
  3. Press the Power button to turn on the product.
  7. Press the Power button to turn off the product, disconnect the power cord from the wall outlet, and then reconnect the power cord to a different wall outlet.
  8. Press the Power button to turn on the product.
Try again to make a color copy.If these steps resolved the issue , you do not need to continue troubleshooting.If the issue persists we have to reset the printer. Doing reset in the beginning stage is not recommended. Reply me back and i will provide the reset step instruction.
Regards
Riztech
Nov 26, 2010 | HP OfficeJet D135 All-In-One InkJet...
Scanner showing error 04 and cant let me scan
Disconnect the power supply from the back of the scanner base.
Disconnect the USB Interface cable and the ADF Accessory cable from the back of the scanner.
Press and hold the E-mail and Copy buttons at the same time. While pressing the E-mail and Copy buttons, reconnect the power supply to the scanner.
Reconnect the power supply and turn on the scanner.
Press the Scan Doc button. the carriage will start moving back and forth in the full scan bed length. To exit test, disconnect the power supply.
now try to scan the document ..........
Dec 14, 2009 | HP ScanJet 7650 Flatbed Scanner
White lines across my scanned images
I had the exact same problem! the problem seems to be with the CCD calibrating itself before it starts to scan.
If you look into the scanner, the scanner glass extends itself into the casing of scanner where the CCD rests. Every time before the scan starts the CCD starts to calibrate itself in its housing before it starts to scan. If there is any reminiscence of dust or anything object (like a piece of paper) stuck in the edges where the CCD rest, the white balancing is thrown off and it causes white lines to appear along the entire line where the dust was present.
Ideally the solution would be to open the scanner casing to clean the housing where the scanner CCD rest. This would solve the problem.
If you are unable to open the scanner casing, then try using a piece of paper or a thin edge of a cloth, slightly dampened to reach into the edge of the scanner glass where the CDD rests and clean it. This is what i did and this solved the problem.
Jul 09, 2009 | HP PhotoSmart C4385 All-in-One Printer
Two black vertical lines appear on copy, pdf, and scan results
  1. Unplug the power cord and the phone line from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Sep 01, 2008 | Lexmark X4270 All-in-One Multifunction...
Scanning problem
the black solid line that you were saying, is that vertical or horizontal? But anyways, i just want you to follow these steps...
Step one: Reset the printer
  1. Unplug the all-in-one USB cable from the computer.
  2. Verify the computer and the all-in-one have a three-prong power cord that connects to the power outlet.
  3. Unplug the all-in-one power cord from any power strips or surge protectors, and plug it directly into a wall outlet.
  4. Make a copy or scan, and see if the issue is resolved. If not, proceed to the next step.
Step two: Clean the glass and scanner backing
  1. Turn off the all-in-one.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the all-in-one.
  4. Raise the lid.
  5. Clean the glass with a soft dry cloth, or a sponge slightly moistened with non-abrasive glass cleaner or water.
  6. Dry the glass with a chamois, cellulose sponge or soft cotton cloth to prevent spotting.
  7. Clean the white scanner backing with a soft dry cloth or sponge slightly moistened with water, and allow it to dry.
Step three: Try a blank copy
  1. Plug the power cord back into the wall outlet.
  2. Plug the power cord into the all-in-one.
  3. Turn the power on.
  4. Close the lid; do not place any paper on the glass.
  5. Load paper in the paper tray.
  6. Do either of the following:
    • Press Start Copy Black to start a black-and-white copy job.
    • Press Start Copy Color to start a color copy job.
  7. Please let me know if the steps didnt resolve your issue.
Thank you so much...
adonscott
Jun 29, 2008 | HP Photosmart C3180 All-In-One InkJet...
Scanner failure message.
Scanner Failure, Power Off and On' Message Displays on the Control Panel when Copying or Scanning
Issue
The message 'Scanner failure, Power off and on' displays on the control panel of the product.
This error usually occurs when trying to scan, to make copies, or during the product start up.
Try the solutions in this document until the issue is resolved. It is not necessary to continue to the next solution if one solution resolves the issue.
Make a color copy of any document by pressing the Start Copy Color button on the control panel. While the product is making the copy, slightly lift the scanner lid to see if the scanner light is visible.
CAUTION: Do not look directly at the light. It is not necessary to completely open the lid to see the light.
If the scanner mechanism moves across the scan bed, but the light is not lit, click here to service the product .
Solution two: Check operating conditions
Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product.
Solution three: Check the power connections
1.
Make sure that the product is connected directly to a grounded wall outlet and not plugged into a power strip.
2.
Make a color copy by pressing the Start Copy Color button on the control panel.
3.
If the error message persists, temporarily move the product to a different room or outlet, and then make a color copy by pressing the Start Copy Color button on the control panel.
4.
Check the part number on the power supply to make sure that it matches the part number listed in the User Guide.
Solution four: Perform a power cycle
1.
Turn the product off.
2.
Unplug the power cord from the product.
3.
Wait 30 seconds, and then reconnect the power cord to the product.
4.
Turn the product on.
5.
Solution five: Reset the product
Step one: Perform a partial reset
1.
2.
Press and hold # and 3 while plugging in the power cord.
3. Make a color copy of any document by pressing the Start Copy Color button on the control panel.
If the partial reset resolves the issue, do not continue to the semi-full reset.
Step two: Perform a semi-full reset
CAUTION: Performing a semi-full reset deletes any phone numbers that are saved on the product.
1.
2.
Press and hold # and 6 while plugging in the power cord.
Solution six: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Mar 05, 2008 | HP OfficeJet d145 InkJet Printer
Half of document is printed
Follow these steps to try and resolve the issue: Step one: Reset the printer
NOTE: If the scanner bulb is not lit during a copy or scan, the product needs service. Step two: Clean the glass and scanner backing
  4. Raise the lid.
  5. Clean the glass with a soft dry cloth, or a sponge slightly moistened with non-abrasive glass cleaner or water. CAUTION: Do not use abrasives, acetone, benzene, or carbon tetrachloride on the glass; they can damage it. Do not place or spray liquid directly on the glass; the liquid might seep under the glass and damage the device.
  7. If the output is a full/half-black page, or has vertical black lines, the product needs service.
Step four: Service the product If you have completed all of the steps listed above and are still experiencing a problem, service your product.
Jan 10, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP Photosmart 2575 xi
you need to mention is the half print occurring during a print out/scan /photocopy? Follow these steps to try and resolve the issue: Step one: Reset the printer Unplug the all-in-one USB cable from the computer. Verify the computer and the all-in-one have a three-prong power cord that connects to the power outlet. Unplug the all-in-one power cord from any power strips or surge protectors, and plug it directly into a wall outlet. Make a copy or scan, and see if the issue is resolved. If not, proceed to the next step. NOTE: If the scanner bulb is not lit during a copy or scan, the product needs service. Step two: Clean the glass and scanner backing Turn off the all-in-one. Unplug the power cord from the wall outlet. Unplug the power cord from the back of the all-in-one. Raise the lid. Clean the glass with a soft dry cloth, or a sponge slightly moistened with non-abrasive glass cleaner or water. CAUTION: Do not use abrasives, acetone, benzene, or carbon tetrachloride on the glass; they can damage it. Do not place or spray liquid directly on the glass; the liquid might seep under the glass and damage the device. Dry the glass with a chamois, cellulose sponge or soft cotton cloth to prevent spotting. Clean the white scanner backing with a soft dry cloth or sponge slightly moistened with water, and allow it to dry. Step three: Try a blank copy Plug the power cord back into the wall outlet. Plug the power cord into the all-in-one. Turn the power on. Close the lid; do not place any paper on the glass. Load paper in the paper tray. Do either of the following: Press Start Copy Black to start a black-and-white copy job. Press Start Copy Color to start a color copy job. If the output is a full/half-black page, or has vertical black lines, the product needs service. Step four: Service the product If you have completed all of the steps listed above and are still experiencing a problem, service your product.
Sep 14, 2007 | HP Photosmart 2575 All-In-One InkJet...
Canon CanoScan 3000F Flatbed Scanner Logo
77 people viewed this question
old marine
old marine
