Will not turn on - Audio Players & Recorders
  • 1,800 Answers
Hi
i don't know ur device model but :
1/ check the internal battery give it a direct charge with the AC/DC adapter 12V
2/ if this not work try to check the switch On/OFF
3/ if this not working give it a firmware upgrade
u can download it from the support/download area of ur product.
plz rate this post if u can.
best regards
Posted on Aug 25, 2008
The volume comes on loud even when i have turned it down before turning off
It sounds as if the UP VOLUME button/switch is broken and ON all the time. See if it is stuck down
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Aug 09, 2016 | Dual Audio Players & Recorders
How do I increase the volume on my record and cd player
Feed the sound into a really loud p.a. system. You can use a high quality Mic to get the best sound.
Jan 11, 2015 | Audio Players & Recorders
My radio makes popping sound when on for about 20minutes but when i turn volume up it stops but sound is disorted.any ideas on problerm
Sounds like there's wires touching and it's grounding to its self or there's a bare wire rubbing on body. Check all speaker wires in trunk or back to which are the ones easiest to vet messed up
Jan 09, 2015 | Audio Players & Recorders
I what do I do if my gorilla MP3 turns on then back off
Try charging the battery the battery might be bad
Dec 25, 2014 | Audio Players & Recorders
I have a Toshiba Satellite A665-S6088. The last time I used it was last night and everything worked fine. It works with Windows 8.1, it has for a few months now, never had any problems until now. No...
Unplug the unit from ac power. Remove the battery. Wait a minute. Press and hold down the power button for 30 seconds. (Yes, I know, nothing will happen visible). Replace battery. Plug unit back in. Now try the power button and see if the unit resets. Sometimes this helps when all else fails especially with a computer which has "hung up" like yours. Let me know if this worked!
Aug 26, 2014 | Audio Players & Recorders
Why does blue light keep flashing when my HMDX boom box is turned on
clip_image002.jpg if it is a slow flashing that means it is connected
if it is a fast flashing that means it is pairing
Jun 01, 2014 | Audio Players & Recorders
It wont turn on, it shows 'push power protect' when you turn it on, or disconnect it and reconnect, i already attempted to disconnect the Sony Stereo MCH-EC909iP Mini Hi-Fi and it shows 'Push Power, P
The only thing I can think of is its goin into protection mode like an amplifier would, you maxed the volume out and it's protecting your speakers or you don't have the right voltage going to it, I can see you don't have it on a straight 120v plug and you might have the wiring wrong on the speakers to it might be too low of a ohm or too high
Nov 22, 2012 | Audio Players & Recorders
I have a 1970's Panasonic Flip Clock Radio. (Model RC6530) The radio works just fine, but the flp clock stopped flipping. There is power going to the unit. I can also hear a low hum from the flip...
It looks like your problem might be an easy fix, at least. If the gear train between the motor and clock got stripped, you'd be in a bit more trouble. If the motor just isn't spinning, remove it from the side of the clock housing. There are 2 screws (or nuts) holding it in place. When you get it off, the cover for the motor will also be off. Apply some 3 in 1 oil, or perhaps just a tiny bit of penetrating oil, and give it a spin. From what I've read, it should do just fine. A lot of people use wd40, but I understand that can gum up over time.
This is a "at your own risk" type of repair, but as long as you unplug it before dismantling the radio, I think you'll be fine.
Feb 10, 2012 | Audio Players & Recorders
47 people viewed this question
 Grubhead
Grubhead
