Question about Canonical Ltd. Ubuntu
Ubuntu Grub error 17
After installing Ubuntu on my hard drive (Windows XP) I got the Grub 1.5 Error 17 message, I don’t know how to solve this error, please help me.
Thank you.
  • mollE Sep 02, 2008
    1. Enter BIOS
    2. Make sure all HD's are detected.
    Write down the current settings so I have them in case you need them later.
    3. In the HD that has Ubuntu installed and set MODE to AUTO (not any of the other options).
    4. If the option is available, set TYPE to USER, don't change any of the figures that were automatically detected.
    If all the above failed -
    Set all drives TYPE to USER and MODE to AUTO (not LBA, large or normal).
    Good luck.
I've just explained it in another threads..hope it'll help you.. http://www.fixya.com/support/t888401-ubuntu_repair_grub
Posted on Aug 27, 2008
    Problem Solver:
  • 8 Answers
Here's a link that may help you http://users.bigpond.net.au/hermanzone/p15.htm#17
Posted on Aug 26, 2008
How to fix error 17 by starting windows xp at acer aspire zg5
Error 17 sounds like a grub bootloader problem, IE: your Acer disk didn't perhaps reload the boot code for Windows, or remove grub entirely.
http://www.ubuntu.com/download
Ubuntu 10.10 Latest Version
which can repair what windows has ruined and is unable to fix fix the problem
either burn it to a disk as an iso and install
you might have burn it to an iso first then boot from the cd rom to install ubuntu or you might just try to install ubuntu directly from the download if it does not install you might save it to a folder then burn it as an isohttp://download.cnet.com/active-iso-burner/3000-2646_4-10602452.html
once Ubuntu has been installed on your computer has corrected the fault you will be able to reinstall windows
or keep ubuntu and install windows next door to it
you can have a dual boot computer with both windows and ubuntu linux you will need to partition your hard drive to do this
is a free partition program.
I have actually used this process to fix my computer with similiar problems and it works.
also
You might want to look at this
http://en.kioskea.net/forum/affich-4...aspire-one-zg5 also
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
Right click on the error message select properties you will see all details about the error
or click start type in event viewer pressENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
Nov 27, 2013 | Computers & Internet
Hi i deleted the partition where Linux had been installed. now unable to boot XP and getting GRUB error 17. I dont have neither the linux nor XP CDs. what can i do?
Since GRUB is your bootloader, your computer now doesn't know where to boot. Your Windows XP data is still present but you cannot boot on it.
What you can do is to use a Live CD to copy your Windows files. Ubuntu is a popular choice. You can get it here : http://www.ubuntu.com/desktop/get-ubuntu/download
Boot on your Live CD, backup your files, then reinstall your OS of choice.
Hope this helped.
Please rate :)
Mar 04, 2011 | Computers & Internet
I have installed ubuntu in drive C(66gb) with windows xp,giving 13 gb space to ubuntu and rest to xp .now i have deleted the disk partition for ubuntu of 13 gb .when i start computer it shows grub error-17...
maybe if go to "start" right "my computer" click on "disk mangament" that ubuntu partition u deleted should be there and i think u need to add it to the windows partition allocate or allocated it i think...im not 100% ...make sure u do some reasrch before u make any changes....jus givin u my thoughts
Feb 15, 2011 | Dell Vostro 1014 Notebook
when this happened to me on my Vista machine last year, I freaked out until I accidentally fixed it using by booting with my original Vista boot disc, and choosing 'Repair OS'. Try finding a/your original Windows XP install disc and seeing if it will repair and replace your own Windows boot sector. It would be best to find the one that came with your system, or another like it, but if all else fails, just try a hologrammed Windows XP install CD, but instead of 'install', choose 'repair'.
Feb 15, 2011 | Compaq Presario M2000 Notebook
I installed Ubunto 9.0 AND when it came up it said, GRUB LOAD,no such partition, then at a prompt it says,grub rescue.
If you run a dual-boot system with Linux and Windows, this has happened to you. You had to do your monthly reinstall of Windows, and now you don’t see the linux bootloader anymore, so you can’t boot into Ubuntu or whatever flavor of linux you prefer.
Here’s the quick and easy way to re-enable Grub.
1) Boot off the LiveCD
2) Open a Terminal and type in the following commands, noting that the first command will put you into the grub “prompt”, and the next 3 commands will be executed there. Also note that hd0,0 implies the first hard drive and the first partition on that drive, which is where you probably installed grub to during installation. If not, then adjust accordingly.
sudo grub
> root (hd0,0)
> setup (hd0)
> exit
Reboot (removing the livecd), and your boot menu should be back.
Only read below if Windows is now missing from the boot menu
If you installed Ubuntu before you installed Windows, then Ubuntu will not have anything in the grub configuration for Windows. This is where you’ll have to do a bit of manual editing to the grub boot menu file.
If you open the file /boot/grub/menu.lst with the following command:
sudo gedit /boot/grub/menu.lst
You’ll see a sample section for Windows, which you’ll want to uncomment and add to the boot menu list in whatever position you want it in. (uncomment by removing the #’s)
# title Windows 95/98/NT/2000
# root (hd0,0)
# makeactive
# chainloader +1
Note that you should also verify that hd0,0 is the correct location for Windows. If you had installed Windows on the 4th partition on the drive, then you should change it to (hd0,3)
Nov 20, 2009 | Canonical Ltd. Ubuntu
What is grub error 17? how to fix it?
Its GRand Unified Bootloader used in Linux OS.
Normally you get this error when GRUB is not able recognise the partition from which you are trying to boot the system. Make sure the boot partition on your system is recognisable by GRUB (such as EXT3).
You can try to restore the GRUB using the LIVE CD
  1. Boot From Live CD
  2. Open Terminal Window
  3. type >sudo grub
  4. then type : find /boot/grub/stage1
  5. you'll get something like: (hd0, 1)
  6. then type : >root (hd0, 1)
  7. type: > setup (hd0)
  8. >quit
  9. >exit
Remove the Live CD and reboot the system.
Please let me know if you need any further assistance.
Thank you for choosing Fixya
Oct 30, 2009 | Compaq Presario M2000 Notebook
I was trying to load ubuntu onto a spare hard drive i had lying around. i used my everex stepnote 1500 note book to load the system on to the spare hard drive. now when i turn on my note book without the...
You should install Ubuntu from inside Windows with the wubi program. When you boot you will have Windows as the default boot option and Ubuntu as a second option. Choose the Ubuntu installation to reside on the external drive. You will connect the drive if you use Ubuntu.
If you do not do that, reinstall ubuntu on the external drive and choose to write the boot sector for GRUB or LILO on the external drive, not on the MBR of the primary drive.
Hope it helps.
Sep 12, 2009 | Everex StepNote NC1500 Notebook
Ubuntu grub error 17
You have to delete the ubuntu partition completely and recreate a new partition for the vista install. You can do this during the vista setup.
Jan 19, 2009 | Canonical Ltd. Ubuntu
Ubuntu Error 21
If you don't have windows on the computer, you can try the Ubuntu alternate install disk or reinstalling if you haven't tried that already. Do either of you have more then one hard drive? If so, which drive did you install Ubuntu on?
Sep 07, 2008 | Canonical Ltd. Ubuntu
Ubuntu Repair Grub
Do you have any other OS's installed? Its with the Grub. mostly looking for another OS. let me know.
Aug 06, 2008 | Canonical Ltd. Ubuntu
Canonical Ltd. Ubuntu Logo
433 people viewed this question
Top Canonical Ltd. Computers & Internet Experts
none
Dennis Gutowski
Dennis Gutowski
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
