Question about Olympus Stylus Verve / ?-mini Digital Camera
Date and time
How do I set the date and time on my Stylus Verve?
    Master:
  • 852 Answers
With the camera on, press the OK/MENU button. Use the arrow pad to select [MODE MENU]. Select the [SETUP] tab and press the right arrow. Select 'time icon' and press the right arrow. Select the date format and press the right arrow. Use up or down arrows to set each item and press the right arrow to move to the next item. Press the OK/MENU button when you have finished entering the date and time.
Posted on Sep 01, 2005
SOURCE:
I wuld like the date to appear on my printed photos. Is there a setting I can change on my camera to get this to happen?
The stylus Does Not have the option to burn the Date and Time data onto the photos directly.
However if you are plugging your camera directly into the printer the camera gives you an option to add the date.
Follow this link to the cameras manual
http://www.olympusamerica.com/files/oima_cckb/Stylus_1020_Mju_1020_Stylus_1010_Mju_1010_Instruction_Manual_EN.pdf
Pages 40 - 44 explain in great detail how to print with the date.
Apr 13, 2011 | Olympus Stylus 1010 Digital Camera
I keep losing date and time function. I was told a capacator needs to be replaced. How do I get access to it?
Welcome to FixYa.
One possible reason why do you keep losing the date and time is just because you left the camera for a day with the battery removed. The date and time will revert to the factory default settings.
I have here the link wher you can see the steps and image on how you can set and save the date and time on your camera. Just click here. Refer to page 86-87.
Feel free to send us your comments and suggestions if this solution was helpful
Thank you for using FixYa.
Apr 11, 2011 | Olympus Stylus Verve / ?-mini Digital...
I CANT GET THE DATE TO DISPLAY ON STYLUS 7010
there is a display button at the bottom right of the back of the camera. its the very bottom rocker buttons. it says DISP/? or/(and the trash symbol). knowing this go to look at your pictures (using the "play" symbol) and click DISP. the time and date should appear now.
Mar 21, 2010 | Olympus Stylus 7010 Digital Camera
Ultronic lcd clock with a stylus tucked in back of clock
This thing set under my bed, lifeless til I was looking for something else and decided it was time to get this clock working!
(Use the stylus pen for best results) After putting in two fresh batteries (or hit the reset button if your batteries are fresh). This will reset the clock and the 'clock' icon in the upper lefthand corner will be blinking. Now press and hold the display area where the hour of the day is displayed. The entire time will start blinking. Now start tapping on the blinking hours to increment the clock slowly to the correct hours (it will cycle all the way thru military time and regular time, so choose what you desire). Press and hold with the stylus to increment quickly. Do the same with the minutes, that are blinking too. When time is correct, tap the 'clock' icon once. The 'clock' icon will still blink, which I believe is correct operation.
To set the date, tap on 3rd icon down from the top left (it looks like a little calendar). This will put you into the date section of the clock (if you do nothing, it will cycle back to the clock, after ten seconds, as a default). Before it cycles back to the clock, press and hold with the stylus pen right below the word 'DATE', until the the entire displayed date starts blinking. Tap the first two digits of the year to go down in years and tap the right two numbers of the year to go up in years. Tap on the month number to increment; do the same with the date number. When all date entries are correct, either tap the 'calendar' icon, or let the clock sit for ten seconds: it will cycle back to the clock.
I guess you can set the alarm in a similar method.
Hopes this helps!
ExitKC
Nov 03, 2008 | RIM BlackBerry Pearl 8100
I have the date on my Olympus Stylus 1010 camera set, but when I download the pictures the date is gone. How do I set the camera to print pictures with the date?
Normally many cameras do not have date printing in its feature ..... while there wud a date setting ..... still try in your menu if there is any time or date stamping feature that needs to be turned on
Oct 12, 2008 | Olympus Cameras
Olympus Stylus Powers itself off
the power on button is located under de lens slyding thing, therefore probably is broken or just need to be glued to do that u will need to open the camera. the other u will need to replace a small battery on the mainboard. good luck
Dec 04, 2006 | Olympus Stylus 410 / ? 410 Digital Camera
Battery
The expected battery life of the Stylus Verve is about 300 frames.
Sep 01, 2005 | Olympus Stylus Verve S / ?-181 mini S...
Date and time
Battery
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Date and time
With the camera on, press the OK/MENU button. Use the arrow pad to select [MODE MENU]. Select the [SETUP] tab and press the right arrow. Select ‘time icon' and press the right arrow. Select the date format and press the right arrow. Use up or down arrows to set each item and press the right arrow to move to the next item. Press the OK/MENU button when you have finished entering the date and time.
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Olympus Stylus Verve / ?-mini Digital Camera Logo
76 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
