Question about Electrical Supplies
Craftsman riding lawn mower
Hard shifting, into neutral & reverse
  • fparmani May 02, 2009
    my craftsman riding mower will not shift out of reverse. it got increasingly difficult to shift then got stuck altogether. how do you adjust the clutch linkage. or can you break open the housing and adjust anything?
    Champion:
  • 242 Answers
Make sure you are fully engaging your clutch. If you are, then the shift linkage needs to be adjusted.
Posted on Oct 24, 2008
Model 917.203900 22 HP lawn tractor. Shifts consistently into forward but frequently won't shift into reverse. What's wrong?
  1. Craftsman Hydrostatic Transmission Fluid Change - YouTube
    ? 40:15
    www.youtube.com/watch?v=vd1EqFtTYgk
    May 10, 2012 - Uploaded by Smokeasammie
    I change the gear oil and hydrostatic transmission fluid on my Craftsman Lawn Tractor. Fluid per Peerless ...
Jul 20, 2015 | Craftsman Garden
Why won't my riding lawnmower shift into reverse?
Some mowers will not allow you to shift into reverse with the blades engaged for safety reasons. Try disengaging the blades then shift into reverse.
Aug 22, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman tl1000 riding mower won't go into neutral even when the shift lever is in that postion
Sounds like the shifter is broken take it back to sears for a free replacement that's the only good thing about craftsman
Oct 23, 2013 | Garden
I have a Craftsman LT1000 Riding Lawn Mower, Model # 917.271645. My problem is that even with the Gear Shift Rod sitting in the Neutral position within the Shift Console, I still have trouble...
There is a neutral safety switch, also known as an interlock switch. Check the switch mount and be sure it has not come loose from it's mounting location. If the engine does start from time to time, it most likely has become loose or has a loose connection at the connection. Let me know what you find.
Jan 22, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Really hard to move gears to reverse or forward
The problem sounds like the transaxle.Thanks for asking and I hope it helps
Jul 17, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lt1000 rider 42 in deck is stuck in gear and wont go into neutral. so i cant get it started.
this happens when lawnmower is cut off in gear try this mash clutch and shake mower forward and backwards while trying to shift into neutral
Sep 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42 in 19.5 unable to control speed forward motion
is this perhaps a hydro trans? if so, try putting the shift lever in neutral, then let off the brake pedal, use the shift lever to go forward and to neutral to stop - same with reverse, don't even use the brake pedal except for emergency stops. if it's a manual shift, it's possible the belt is incorrect, and/or the belt guides are bent or the belt is improperly routed - the belt guides are important as they allow the belt to "blossom" off the engine pulley, reducing the "shock" load when engaged - hope this helps
Jul 14, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Electrical Supplies Logo
270 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
