Question about Toshiba 50HP95 50 in. Plasma Television
My dead 42" plasma - power problem
Following some suggestions from you guys, I got brave and pulled the screws off of the back of the TV. I followed the AC wire to the input on the board. Right next to it was a fuse. I borrowed my friends Fluke multimeter and checked. I got no response. I checked another fuse to make sure and I got a beep, so I know the fuse is blown. It is a T8AH250V P - does anyone know where to find one?
By the way - YOU GUYS ROCK!!!!!!!!!!!!
Thanks
atombomb72 50 inch plasma tv toshiba
  • 2 more comments
  • ferry_70 Nov 29, 2008
    some body know to get the fuse type e.t8ah250v p i check in radio shack there does't have it....thank.s
  • mmalignaggi Jan 25, 2009
    what did you do'? i have a panasonic with 2 blown t8ah 250v fuses... where do i get these?
  • nanderson230
    nanderson230 Dec 20, 2012
    Amazon.com has them. Pretty cheap too. As long as it's not rushed delivery.
  • nanderson230
    http://www.amazon.com/s/ref=pd_sl_5j2o49...
I have same issue with Samsung HP-S4253 Plasma. The fuse is a Littlefuse (manufacturer they do not sell), I have search and called over 20 places and the latest is Fuses Unlimited but it is discontinued and they do not stock but they can order. I will not be able to contact them until the holidays are over. There most likley is a minimum order. If there are other fuses you need write down part #'s so you can fill the minimum if required.
If there is anyone out there that can help with finding these hard to find fuses it would be appreciated.
There are most likey other Plasmas or TVs that use the same fuse just have to figure out witch ones they are.
Fuses on Power Supply Board: The 8 amp is the one I require.
T8AH250V P
T10AH250V
Break Down of Fuse Description:
T = Time Lag
8A = 8 Amp
H = High Breaking Capacity (Ceramic) 1500A @ 250V AC
250V = 250 Volts
P = RoSH Compliant
Posted on Jan 01, 2009
    Problem Solver:
  • 6 Answers
Http://www.newark.com/littelfuse/0215008-mxp/cartridge-fuse/dp/42K9308
Fuse is a "Littelfuse 0215008.MXP"
8A 250V Slow-blow ceramic
Posted on Sep 29, 2009
Www.thepartstore.com has fuses and other television parts look there.I know they have Toshiba parts.
Posted on Feb 24, 2010
Run an insulated little wire from one end of a fuse to the other with some soldering...it should read
Posted on Mar 02, 2010
  • nanderson230
    nanderson230 Dec 18, 2012
    does the gauge of the wire matter?
    President:
  • 2,267 Answers
You can check radio shack, make sure you get one with the same voltage/current ratings.
Good Luck.
Posted on Aug 25, 2008
I am purchasing the 0215010.MXP fuse from Digikey.com, part number F1699-ND.
Posted on Aug 07, 2011
  • Vacuous_One Aug 22, 2011
    The fuse is available from several online distributors: Digikey (as noted), Newark, Mouser, Allied Electric.
    The fuse is a Littlefuse series 215. Base part number is 0215008. Suffix denotes options.
    Link to the fuse data (including an explanation of the part number) is: http://www.littelfuse.com/data/en/Data_S...
2 Suggested Answers
SOURCE: my dead 42" plasma - power problem
You can get the Fuse at digikey.com
Posted on Jul 30, 2010
The green led blinks 12times. local repair guy guy said somthing about taking out the y.
Power LED blinking it about 90% power supply board is dead.The other 5% are both boards some time are dead.The power supply board and the Tuner siginal board is dead.Replaced the power supply board it ur best bet to get power back.After power is back should get picture too.Not than the Tuner board also need it replaced.Tries Websites Shopjimmy.com,Ebay.com for boards parts.
Feb 16, 2010 | Sanyo DP42746 42 in. Plasma Television
Lg 42pg20 Plasma Will not turn on
If there is no LED burning to indicate there is power than the power supply is faulty.Repair is not verry easy to do with these complicated power supply's.
Nov 02, 2009 | LG 42PG20 42 in. Plasma HDTV
Dead, no power
It sounds like ze power supply blew when it was being turned off. This seems to be typical of plasmas. Bad power supplys wont let the tv come on and will result in no lights coming on. Since there R no lights coming on, I would suspect the power supply first, followed by the power control board,. and circuit board. It may cost anywhere from $250 to $500 to fix.
May 14, 2009 | NEC PXT-42SX1B 42 in. Plasma TV
42" Plazma Dead
Check the fuse on the powersupply & non-powersupply area, this was very common problem like the one you have experience..
`micro
Jun 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Dead 42" plasma - power problems
that was good to know.. good luc on your work..
`micro
Jun 01, 2008 | Philips 42PF9630A 42 in. Plasma Television
I went to Radio Shack and bought a 4 pack of 6.3amp 250v glass fuses (5x20)...stuck one in and it works like a charm.
Anyone know of any problem using a 6.3amp fuse instead of an 8amp one? I am thinking it just would blow out sooner...and I have 3 more I can go through until I find an 8amp fuse...am I crazy?
Atombomb72 - 42" dead plasma
This is the correct fuse:
see www.digikey.com
digikey part number is F2668-ND.
Black Bars
Hi guys.  This is totally fixable and pretty easy if you have tech skills at all.  I performed this fix even before I found the following thread that will explain it, and it worked flawlessly!  Read it entirely and follow carefully.  this works on many different models of plasma's.
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Nov 26, 2007 | Dell W4201C 42 in. Plasma HDTV
Got a 42 sampo plasma tc, no picture
Howzit Brother.
I had the same problem, but managed to repair it myself! There is no need to purchase a new
Power Supply! You can service the faulty PCB yourself, or give it to a Tehnician to service for you.
If you want to try service to yourself, here is how,
On the PCB marked QPWB11326-1B-4 you will need to do the following<
Replace the following Capacitor's, CS704(Most important one), CS705, CS706, CS707, CS708, CS713, CS715.
Replace the TOP210PFI IC marked ICS02
Replace the PC123 OPTO marked ICS03
Replace the TL431 Shunt Regulator marked ICS04
This solution should work! email me on engineering@elektroniktechnisch.co.za if you have any other requests!
Gavin Burger.
Jun 12, 2007 | Sampo PME-42V3 42 in. Plasma Television
Toshiba 50HP95 50 in. Plasma Television Logo
5,548 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
