Question about Hotpoint WMA46 Front Load Washer
Door Lock Light - flashing
Hello
My mum has a WMA46 frontloader washing machine. The other day the washing machine was doing a cycle and she heard a bang which flipped the home circuit breaker.
Now the door locked light keeps flashing. The door opens and closes ok, but we cannot stop the light from flashing.
Can someone please advise how we can fix this?
  • Anonymous Mar 14, 2014
    The machine wont lock the door to start cycle. It bleeps and then comes up with the flashing message 'door'. I have changed the door mechanism switch but it still doesn't work. Any suggestions?
  • 903 Answers
Does the door still lock? becasue it sounds like a faulty lock. It may need to be replaced.
Posted on Oct 23, 2008
  • martin kilpatrick
    martin kilpatrick Mar 28, 2014
    door still locks an opens i tryed a new one still the same
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
We have a Whirlpool 7KG frontloader washing machine (6th sense) model AWM8121. The problem is that the door light is flashing, the cycle has stopped at rinse (rinse light is on) and the machine is not...
We have an awm8121 and there seems to be a fault on the Spin cycle indicators with th 0 RPM and the 800 RPM flashing..
We can't seem to get the frontloader to finish the drain cycle and continue into the next was.
The last load of washing was still saturated when we managed to open the door.
Apr 20, 2011 | Whirlpool AWM8123 Front Load Washer
Washing machine model Hotpoint WMA46 - G wash 3kg load. When on the spin cycle, the machine started rocking violently, such as with a very unbalanced load. I grabbed the front of the machine and leaned...
I think probably the problem was caused an out of balance load.
which would cause the problem you have experienced.
The door catch can be replaced, but it means taking the door apart to replace it, and you may possibly have to replace the door lock as well.
I think it is worth repairing, but you may possibly have to get an enginner to do it for you.
Jan 08, 2011 | Hotpoint WMA46 Front Load Washer
Door lock flashing on hotpoint Aquarius washing machine
Look this is a long shot, but i once repaired a frontloader for a customer who was having this problem.the door lock light was showing up but it was actually the motor brushes in the motor,they where worn out & because they wern't making electrical contact the door lock light was staying on,this is stupid but the doorlock ran through the same circuit as the motor.so as a result the machine had no choice but to put up the door unlocked light.the door light must go out when the interlock closes that circuit but the motor was in that same circuit & when the motor open circuited due to the brushes the door light recognised this as an open circuit & lit up.it took me a while to work it out.Perhaps this is the same in your machine.I hope this helps you,ide be interested to know.
May 28, 2010 | Washing Machines
Hotpoint WMA46 door problem
From the symptons you describe, it could be a broken or weak spring in the door handle, which ca be fixed relatively inxpensively, that is where i would start, you can purchase one directly from hotpoint, or possibly a local repairer. if that does not cure the problem, then the odds are it will be a faulty programme module.
Hope this helps.
Jan 13, 2010 | Hotpoint WMA46 Front Load Washer
Door lock light flashing
could be a faulty belt. May need replacing. Or in the worse case scenario the bearings may need replacing.
Sep 21, 2008 | Hotpoint WMA46 Front Load Washer
Hotpoint wma46 door lock
make sure door seal is fitted correctly to the cabinet. you may find that all that is required is to push the door harder than usual till the seal beds in
Mar 29, 2008 | Hotpoint WMA46 Front Load Washer
WMA46
check that the outflow pipe is not blocked. Turn off power supply get a bucket ready, disconnect the outflow pipe from the u-bend under the sink and check that it is not blocked.
Mar 15, 2008 | Hotpoint WMA46 Front Load Washer
DOOR WILL NOT LOCK
assuming that you didfi not unwire ther door lock, the problem is probably just that the door seal just needs bedding in and you should be able to start by closing more firmly and pushing in till the door lock catches. did you properly seat the door boot on the cabinet?
Apr 07, 2007 | Hotpoint WMA46 Front Load Washer
Hotpoint WMA46 Front Load Washer Logo
2,260 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
