Internal screen is broken can a new one be fitted?
    Genius:
  • 2,920 Answers
Yes but you will need to order a new screen for it
Posted on Aug 25, 2008
Broken screen. i think both internal and external. it's pretty bad. replace screen? or buy new tv? or buy broken tv with in-tact screen? i paid $450 for this tv, so what is most cost effective?
Buying a new TV would save time most definitely, if it's in really bad shape the repair costs would add up pretty huge. Buying a broken TV with an intact screen might work as long as you can prove it's exporting signal though. If time means anything, and you have experience in engineering, I'd say go with buying a broken TV, otherwise based off your description, just buy a new system.
Jul 17, 2011 | Mitsubishi WD-65731 65" HDTV
No sound coming from left ear initially, now no sound at all.
Sorry, it's probably not fixable. The wires are either broken internally or have become detached from the solder fixings and the headphones are not designed to be repaired, nor are spare parts available.
The only exception is if the plug on the end is broken or has broken wires. Wiggle the wire at the plug end only whilst wearing the cans. If you get sound, then identify where the wire has broken and cut the plug off at that point. Strip the wires, correctly identify the left and right conductors and fit a replacement plug using soldered connections. Ensure that the screening sheath is correctly soldered to the casing (it's the earth connection for both conductors) and close the new plug casing.
In practice, it's fiddly, and only to be done if you're confident with a soldering iron. If not, just do as Philips intended and bin your old cans and buy new: it's not as if the SBCHP430/00 was an expensive model to start with.
Feb 16, 2011 | Philips SBCHP43000 Headphones
Internal screen broken & touch screen doesnt work now
you will have to replace the lcd or buy a new one.
Oct 27, 2009 | Garmin Nuvi 265W GPS Receiver
I have a broken internal screen Can I replace
The screen can be replaced, but it is costly to buy a new screen & you will need to have some knowledge of dismantling & re-assembling LCD Tv's.
Oct 11, 2009 | LG 37LB1R 37 in. HD-Ready LCD Television
Broken screen how much to fix
If you can find one:
New £1000 (ish) More than a new TV
Used £200 - £250 depending on which screen is fitted.
Send me the number from the back of the screen and I will see if I have 1:
Something like: FPF50C128135UE-55
I hope this helps
Mar 28, 2009 | Hitachi P50H401 50 in. Plasma HDTV
Scratch
hello, if there is a scratch on your reflective outer glass panel screen, it can be replaced if you are handy with tools or diy i happen to have the screen removal manual for this tv model th42pz700u you dont have to dissasemble the tv just the outer front housing remove the back panel and theres some screws that hold the front casing on those come of and the front refelctive glass can be removed without any trouble or dissasembly of the internals just the front casing
you may need to find a selling as is plasma tv with a broken internal screen usually they are this way that outer screen dosent break easily so unless you want to pay 489 for this reflective glass part i would try and find a 'for parts or repair 42 inch pany' they will fit if they are the same size make sure the outer screen is not broken or scratched. hope this help
Nov 29, 2008 | Panasonic TH-42PZ700U 42 in. Plasma...
My screen on my rca 61130 has cracked i ve removed the screen protector and need a NEW SCREEN can it be replaced
yes it can be replaced.calling a technician is much advisable as fitting the new screen is not very easy as it should be allighned as the old broken screen was before.if there is a slight difference in the fitting you will not be able to see the clear picture.
thanks.
Oct 13, 2008 | Televison & Video
Red light keeps blinking
either the piece of paper is jammed in between the gears of the printer.
or the toner cartridge is not fitted properly.
or any of the paper sensors are broken internally.they r very delicate and very thin and r black in colour.
just connect it to the pc and give a printout and the screen will display the problem in the printer if its paper jam then cleaning is required or the sensor is broken.if it says missing cartridge then cartridge not fitted properly.
Jul 15, 2008 | HP LaserJet 1010 Printer
SAMSUNG SCH-A870 INTERNAL BROKEN SCREEN
This is not fixable, you have to get a new phone. If you have insurance they will replace it for $50.
Nov 30, 2007 | Samsung SCH-a870 Cellular Phone
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
