Television when i click the channel button on my tv the menu screen pops up,and my remote wont work at all.????when i click the power button on tv nothing happeneds,but when i click the volume button tv turns on ???
  • Anonymous Aug 25, 2008
    replace all micro switchs
    Genius:
  • 1,550 Answers
You need to check what micro switch are bad and replace him because for that the remote don´´t work
Posted on Aug 25, 2008
How to program a vizio tv without a remote vizio
Upon first start you should be prompted. If not, you will find a series of buttons on the TV itself; power,channel up down, volume up/down, input and menu. Hit the menu button and the menu will pop up. Scroll up and down with channel button, select and controls are the volume. either that or you can get a Samsung phone that has an app built into it called watch on, which has a universal remote that works for virtually everything. Happy surfing.
Mar 05, 2015 | Vizio P50HDTV10A 50 in. Plasma HDTV
Everytime ichange the channel ; a big black box pops onthe screen and the only way it can be removed is by clicking a volume button ; what can i do?
Tv still have it Closed Caption functions is on.U have the tv original remote wright?Yes.Look at ur tv remote control look for a button that said CC,push that button a couple times make sure like all CC1,2,3.. all to off.Closed Caption functions will turn off should have no more black boxes pops up onto the tv screen.Also used the tv remote control go into the tv menu go into Closed Caption funcions look for functions like Text 1,2,3... turn it all to off too.Should stop it for good,if Text also on too.If u don't have the tv original remote.Try website like Remotes.com to buy the tv original remote.
Jul 09, 2011 | TruTech T2000D TV
Front panel buttons and remote have stopped working.
Is the favorite channel menu a function that is normally accessed by a button on the remote?
If so, that button on the remote might be stuck.
If this is the case, the menu may at times pop up all by itself and other buttons on the remote and on the TV's front panel may not respond at all (it had happened on my remotes more than once).
Try to clean the remote control (the housing, rubber pad with knobs, circuit board) with ethyl alcohol, when you clean the housing, you should also clean the holes through which the buttons protrude, there might be some dirt that keeps the button stuck.
It may also be a stuck button on the TV front panel, so check these too.
Also, it could be something else, i just wrote the description of a problem and the solution which to me seemed most likely.
Hope you get it fixed.
regards
3rq8 (Triarcuate)
Jul 25, 2009 | Sony FD Trinitron WEGA KV-20FS100 20" TV
All buttons on tv stopped working only turns ON no ...
There is a button lock in the menu of the television. Using your remote access the menu screen and unlock the buttons.
Feb 19, 2009 | ViewSonic N3735W 37 in. LCD TV
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Viewsonic power lock
On the tv itself hold down channel up button while holding that press and hold the menu button . this will un lock it
Dec 29, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Screen keeps going to menu mode
THE SWITCH BEHIND THE MENU BUTTON ON THE TV IS MOST LIKLY DOING YOU IN
Nov 14, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Conia plasma.no buttons work on the tv and the picture does not appear when you turn it on.it shut of one day.the aerial works and the tv has power.
How long have you owned the television. What is the exact model of the television. Once I have more information I can help you further.
Thanks,
Lee
Aug 26, 2008 | Televison & Video
Tv is on but wont play
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Give the brand name and the model number..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Televison & Video
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
