Question about Sony KDS-R50XBR1 50" HDTV
Picture quality poor
Just got my R50XBR1 back from the shop after replacing power supply, now the picture is fuzzy around images.. Looking at text on screen,can see green on one side and red on the other, colors not aligned together... Now what??
  • 2,071 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
if not please follow these:
Troubleshooting Tips:
1) Main cause of defective will be located on the KD-board
2) Confi rm KD-board is securely seated on the G2-board
3) Replace KD-board
Thats a fairly complex Chassis. Unless youre really good at dissassemble and reassembly of small components, I would suggest a Sony authorized reapir tech do the repair.
Certainly, I can help you. I would recommend going to the following link and getting the service manual so he can see first hand disassembly instructions and testing proceedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new KD board. heres the link.
http://servicemanuals.vstore.ca/
DON'T FORGET TO RATE:
Posted on Aug 25, 2008
Poor picture quality
Why do most security cameras shoot poor quality pictures ...
https://www.quora.com/Why-do-most-security-cameras-shoot-por-q... QuoraA good surveillance camera must have compact size, acceptable frame rate, ... Digital Cameras: How is the picture quality of the Samsung Galaxy S4 Zoom?
Why is DSLR cameras video quality so poor compared to ...
https://www.quora.com/Why-is-DSLR-cameras-video-quality QuoraWhy is DSLR cameras video quality so poor compared to still images at same resolution ... How does a digital camera work when taking a photo whose (image) ...
DigiTools: Communication, Information, and Technology Skills
https://books.google.com/books?isbn=0538741295
Jan 03, 2016 | Cameras
The picture quality is very poor. Picture is fuzzy.
Did you turn the ring on the camera itself? The camera does not automaticaly adjusts itself. You must turn the lens to focus manualy.
If nothing works and you just bought this camera, call microsoft and they will help you more.
Mar 05, 2010 | Microsoft LifeCam VX-3000 Web Camera
Poor Printing Quality
The last time I saw that I had to replace the HV power supply and prints went back to normal...If it's out of warranty it'll cost around $150.00
Aug 31, 2009 | Samsung CLX 3160fn All-In-One Printer
Poor picture (fuzzy ghost image/aura)
well you should check the settings and read menual
Jul 22, 2009 | Panasonic TC-P50G10 Plasma TV
Poor pictre quality
This set has 3 CRT's (picture tubes)
Remove the back bottom cover
Clean the CRT's with windex and a soft cloth.
(Find the Screen/Focus block)----Remove front grill cover and panel which covers the Screen/focus block.
Cover 2 crt's and adjust the focus control for remaining crt---(using the convergence pattern in the menu for the set)
adjust for the best focus.
cover that crt and move on to the next crt using the same procedure.
After setting the focus on all 3 tube's you will have the best focus possible for this set. If picture is still bad, you have bad crt's and the set is junk.
Cost to replace the CRT's is enormous!
Craig
May 08, 2009 | Televison & Video
Copy quality is poor. Replace toner, drum and transformer?
when you say the quality of the text is poor I am assuming that your are describing the line print
FIX
IF FUZZY remove corona wire and clean with q tip diped in alcohol
If IMAGE OFFSET check fuser rollers emove pad and ad fuser oil
IF copies lite remove print cartridge and shake back and forth to get toner distributed
also examine photoreceptor sounds the shutter is not closing and causing image distortment
Jan 05, 2009 | Sharp AL 1631 Copier
Picture is fuzzy
Do you have a HIGH DEFINITION satellite / cable SERVICE? Unless you are specifically set up to receive HD - your picture will still be back around 400 lines - and both LCD and Plasma HD units are notorious for looking WORSE when viewing NON-HD PROGRAMMING.
Unless your DVD is capable up converting up to (pseudo) HD, don't expect much there either.
Not sure how the INSIGNIA is set up for inputs, but good old Wal*Mart sells a FANTASTIC UNIVERSAL REMOTE called AVEX that is an absolute JOY to program and work with - and it's only about $20!
Put a DVD in your player and turn it on and let it play. I doubt that you are actually looking for a "CHANNEL" - but instead an *input* that is electronically controlled by your tv.
Go to the "TV" position on your remote and find the "INPUT" button. Pressing it should bring up a menu of different inputs that your tv has. Use your center UP/DOWN button to switch inputs until you see your DVD playing through one of them.
Jun 19, 2008 | Insignia 37" LCD Flat-Panel HDTV
Bad signal on my sms 2
i had the same problem, don't use rf, use an ave cable you can find them on ebay
Apr 03, 2008 | Sega Master System Console
Logiteck quickcam communicate
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Troubleshooting: Image Quality for Cameras trnsp.gif Detailed Description This article covers some standard troubleshooting for issues such as fuzzy, grainy, out-of-focus or off-color camera images. trnsp.gif Answer The information in this article applies to the following software
QuickCam 9.x and below
ImageStudio 7.x and below
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens. This will allow you to focus the camera image on objects at different distances. Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video. Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed. Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds. If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter. For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher. To change the color palette please perform the following steps:
  1. Click on "Start," "Settings," and "Control Panel."
  2. Double-click on the Display icon.
  3. Click on the tab labeled Settings.
  4. In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
  5. Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost." If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software. To do this:
  1. Open the QuickCam software.
  2. At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
  3. Choose "Advanced Camera Settings".
  4. Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
  5. If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
  6. Click OK when your are done.
Mar 05, 2008 | Logitech QuickCam Communicate STX Personal...
Sony KDS-R50XBR1 50" HDTV Logo
106 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
