Question about Lenovo 3000 N200 Notebook
Turns off my Lenovo 3000 N200 0769 turns off almost immediately it is turned on. all i hear within those few seconds it comes on is the cpu fan. can someone help me please.
    Genius:
  • 1,689 Answers
What you want to check on first is the battery of the laptop, it is best if you remove the battery, plug the charger in and see if it will have the same issue, if yes, then there is a possibility that the power board is smoked.
please check the link below for the possible things to do.
http://laptoprepair101.com/
if you did not have the same issue, there is a possibility that the battery of your laptop is already expired or have gone out. and replaceing it will be the best move.
Posted on Aug 25, 2008
Laptop shutting off every few minutes
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Apr 03, 2013 | Lenovo 3000 N100 Notebook PC
N500 overheat
TURN IT ON PUT UR EAR TO IT SEE IF U HEAR THE FAN COME ON IF U DO NOT HEAR IT U MAY NEED TO RE PLACE IT AND MAKE SURE THE FAN EXHAUST IS CLEAR
GOOD LUCK
Oct 08, 2011 | Lenovo 3000 N500 Notebook
I press the power button, CPU fan comes on for a few seconds then off. No video even from external monitor. Cpu slowly becomes warm and fan comes on to cool it. This continues but no video.
Welcome to Fixya
Sound like LCD problem. Try to drain the electorstatic charge of the board for this sometimes the cause of no display while computer is turned on. I wrote a tip on how to do this. Please click here.
If this will not work then you have a bad LCD there and needs to be repaired.
Please let me know if you have further questions.
Thank you for using Fixya!
Feb 19, 2011 | Lenovo 3000 N200 Intel Pentium Dual Core...
It was just this morning when I tried to turn my pc on.. unfortunately it did not. ! when i press the power button on cpu it turns on for a few second like one or two but immediately after it drops the...
Try replacing the power supply - I had a similar problem that was fixed that way. If that doesn't work, it's probably the motherboard itself. The CPU is also possible - have you overclocked it or otherwise cooked it? Is the CPU cooler/fan blocked with fluff, or has the fan been slow (or stopped) - noisy fan is a sign of bearing stiffness/partial seizure which slows the fan and lets the CPU get too hot. If the CPU is fried, you get the symptoms you describe (MB won't start the PS)
Dec 23, 2010 | ASUS M2N-MX Motherboard
Dell 9300 power up issues
The issue seems with with the mainboard please get it checked.
Thanks
Feb 24, 2010 | Dell Computers & Internet
I have a lenovo laptop, 3000 G410. Recently it has a problem which it shut down by itself after I use it for 20 minutes. After the shut down, I turn it on and this time it work only 2 minutes and shut down...
This sounds like a overheating problem (a CPU thermal shutdown).
This is caused by a faulty fan or the heat-sink and fan is clogged with dust. Check the fan to see if it spins freely, if not replace the faulty fan. Check the fan/heatsink assembly and remove/vacuum the dust from these components.
Nov 08, 2009 | Lenovo 3000 Y410 Notebook
All computer fans starts ok but trips with notice,
You may hear the case fans running. Remove PC cover and check CPU fan and replace, it may not be running at full speed.
Sep 23, 2009 | HP Compaq d530 SFF PC Desktop
Hi my laptop will turn off suddenly even though it is plugged
it may be shutting off due to thermal shutdown... basically the fan isn't keeping the cpu cool enough... check to make sure the fan is running and that the fan/cpu heatsink is clear of dust and dirt.
Robert
Dec 22, 2008 | Lenovo 3000 Y410 Notebook
Lenovo 3000 N200 Notebook Logo
132 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
