Question about Dishwashers
My hotpoint washer dryer wd61 door would not open after a blown fuse
I have the same problem - did you fix it - what was invoved\?
Posted on Oct 06, 2008
HOTPOINT WASHING MACHINE wmf540
You will have to find the component in the machine that has
gone live to neutral,live to eath or neutral to earth if it is protected by a RCCBO. Check on the back of the printed circuit board for "BLOWS" black marks blown components.
Jan 10, 2014 | Indesit Genuine Hotpoint Wmf540 Wml520...
How do I unlock the door on the 1200 washer and dryer?
The simple way is to is to take a screwdriver in the top right of the door lock at the door and a lever on the rod above the lock to open the door.
i hope it helps.
Thanks
Jun 21, 2011 | Siemens Dishwashers
My FDW80 hotpoint dishwasher has stopped releasing the tablet. The door won't pop open. Any ideas???
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Mar 13, 2011 | Hotpoint HDA3520ZBB Dishwasher
My hotpoint washer does not turn on
There are four components to check if your washer will not turn on at all. You need to check your power supply, the door switch, the cycle selector switch and the timer motor.
Am suspecting the power supply, Your dishwasher may not be receiving any power. It is somewhat difficult to check for power at the plug outlet because the plug for a dishwasher is usually behind the unit. You should make sure all the circuit breakers of your circuit breaker panel are in the correct positions, or check to make sure no fuses of your house fuse panel are blown.
That should do the job for you. Hope this helped you.
Jan 14, 2011 | Hotpoint Dishwashers
My son opened the washer before it completed the full washing cycle. Now it won't start at all. We checked the switches, gfi, circuit breakers. Is there a reset button somewhere? I pushed and held the...
HI- You didn't give a model # but it is possible that the fuse on the control board burnt out. This shuts the unit down if it gets blown. Yours may not have this fuse, can't tell without a model number but if you are sure it is getting power I'd have a tech out to look at it. You should be able to open the door anytime you want but maybe the door switch shorted out the fuse. If you have lights on the controller then it is more likely the door switch. Hope this helps.
Sep 24, 2010 | Kenmore Dishwashers
Hi, my Hotpoint aquarius SDW60 has blown my main fuse, and is overheating giving a burning smell, 2x lights flashing on the front?
There is probably a short circuit on the appliance, or a component such as the motor or timer/control board is defective. Contact an appliance service company.
Feb 22, 2010 | Hotpoint Dishwashers
Not draining and washer arm not spinning
Have you cleaned the drain filter? The symptoms you describe indicate that the filter are totally clogged.
Cleaning filters should be done every other week to maintain good function in dishwashers, it is not uncommon people forget that.
You access the filter by removing the perforated stainless steel plate at the floor of the washer tub, usually there is a round plastic knob in the middle that you turn counter-clockwise then lift it up. Underneath this plate you will find the main filter, take it out and clean with a soft brush under running water.
May 24, 2009 | Hotpoint 24 in. HDA2130Z Built-in...
POWER ON-PROGRAM WONT WORK
1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Aug 10, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Fridiare dish washer
Sounds like a blown thermal fuse. Most dishwashers have a thermal fuse mounted on or near the control board inside the console. There should also be a tech sheet inside the lower panel under the door that can help guide you. The thermal fuse should read a short. If it is open, it is non-resettable and must be replaced. I hope this helps you.
Jul 21, 2007 | Frigidaire 18 in. FDR252RB Built-in...
Bosch 5315 dishwasher
A fuse may have blown or a circuit breaker tripped. Replace fuse or reset circuit breaker at your fuse box/breaker box windman
Jan 30, 2006 | Bosch 24 in. SHU53 Built-in Dishwasher
Open Questions:
Dishwashers Logo
77 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
