Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I have a 1 GB flash drive that is physically broken and my laptop won't recognize it. The pin got bent and was partially out of the case.
    Sergeant:
  • 300 Answers
Relax , as long as your flash drive is not smashed with a hammer
we can get it back up and running , your notebook on the other hand may need a little technical lovin'
if you broke a pin in the USB port , thats gonna take some serious work , if the notbook is under warrenty use the warrenty
if the notebook is passed it's warrenty , then you CAN do the job yourself , you'll need to remove a USB port from a junk motherboard or better , and use that to replace the broken pins
that does involved some soldering with a solder gun or pen
which might cost you about 10 to 20 dollars as of 2008
Good luck and may the nforce2 be with you , always.
Posted on Aug 29, 2008
Bent flash drive
Unfortunately this drive is impossible to repair if bent (like from dropping while attached to laptop) and it cannot be recognized when plugged into your laptop. The silicon memory chip is sandwiched between the PCB material, if you take the case off of the outside you can observe that it is just a black square piece of silicon with no traces on the board only the metal pads to connect it intothe USB port. the "faceted" portion of the drive is only for grip and has no use other than a way to remove it from your laptop. The memory is very close into the connector, so when I dropped my laptop it bent it directly down the middle of the memory chip portion itself, undoubtedly severing thousands of microscopic connections in the chip. I believe this is a very poor design and will be buying the older "switch" style usb drives in the future.
Jan 31, 2014 | SanDisk Cruzer Facet 8GB USB 2.0 Flash...
Buffalo Ministation not flashing or recognized
Im having the same problem sound like your cable is not working or you need a new case because the pins are broken.
Jul 22, 2013 | Buffalo Technology 320GB MINISTATION TURBO...
Acer Aspire 5002WLMi Laptop won't recognize full 320 Gigabytes of new PATA hard drive. It's always been running a 80 Gigabyte 4200 RPM but that drive is old...a 2005 HD. New WD320 only reads 137...
The BIOS in the ACER determines the maximum size of the hard drive it can support.
Check the laptop's specification to see the max size you can install in this model laptop.
It appears that the max size your laptop can support is 140 Gb (unformatted). 137Gb formatted.
I suggest you install a hard drive up to 140 Gb capacity in your laptop and place the 320 Gb hard drive in an USB hard drive adapter case and when you attach this hard drive to the USB port in your ACER laptop then you will be able to get the full 320 Gb capacity after you delete the partition and create a 320 Gb partition and format the hard drive.
Nov 02, 2011 | Acer Aspire 5002WLMi Notebook
I bent my flashdrive and now it won't read. I initially was able to wiggle it around and once it read, I could drag one file to the desk top. Now, I can't it to read at all. What shall I do?
I would check the pins in the end of the flash drive and see if any of them are bent back. If these metal pieces aren't in the right place then the flash drive won't be able to connect to your laptop. I would try bending them back into place with a small flat head screwdriver. If you don't want to fix it yourself then I suggest you either buy a new flash drive or take it to an electronics store for more help.
May 01, 2011 | Verbatim VER95327 USB Hard Drive
I bought a hitachi external hard drive for mac, 250 g. when i first used it it took a long time for it to be recognized. On pc it works fine, but on my mac it won't get recognized anymore. (the hard drive...
Your problem could be any one of these issues:
1. Faulty USB port on PC: Try a different computer or laptop
2. Faulty USB cable: Try a different Cable
3. Corrupt memory: Fix by an expert required such as www.SaveMyUSB.com
4. Faulty connections on main circuit inside the hard drive: Physical Fix by an expert required such as www.SaveMyUSB.com
5. Faulty controller chip (worst case scenario) : Direct flash memory read required by an expert required such as www.SaveMyUSB.com
Hope this helps and that it is 1 or 2 as 3, 4 and 5 will cost you money.
Jan 01, 2011 | Hitachi SimpleDrive Mini 250GB USB 20...
My LaCie 500 GB external HD is not recognized by my (or any other) computer when connected, attempts to instal driver software fail and the device does not appear in the list of devices with removable...
Dec 31, 2010 | LaCie 500GB USB 2.0 7200 RPM 8MB 500 GB...
Hard Drive is not reading
Whoops!
Are the pins BENT out of alignment? It is SO easy to create this problem when connecting a drive.
If the pins are bent use the greatest of care putting them back in alignment with the other pins. Now carefully reconnect the drive.
Hope this helps!
Feb 24, 2009 | Fujitsu (MHV2120AH) 120 GB Hard Drive
Verbatim 1GB flash drive data recovery
Sounds like you broke something ;)
If your computer does not recognize anything when you plug it into the computer, your problem is most likely a broken contact inside the usb drive.
You should attempt to open the drive, and see if one of the four contacts on the inside of hte usb key are no longer making their way to the circuit board, and try to reconnect it.
IF you can push the connectors down with your fingers and make contact temporarily, and the computer recognizes it, try to just hold it there while you copy all your data off. Then throw away the flash drive.
Jan 22, 2008 | Electronics - Others
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
203 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
