Question about Acer Aspire 3680 Laptop
ACER 3680 will not power up
My acer 3680 laptop will not power on. The power cord when plugged in to the wall shows a bright green light, but when you plug the other end into the computer it gets dim and flikers. I tried taking the battery out and only use the wall plug but still the same. I tried another power cord and still the same. Any ideas? Maybe the power jack?
  • adamju Aug 25, 2008
    How do you check out the PC cooling fan if the computer will not power up at all? Thel light flickers on the power cord not the computer itself. I plug the computer in and press the power button and nothing happens. Its like no power to the computer.
    Thanks
    Guru:
  • 257 Answers
Hello, am temab concerniong your problem on powering your system right?
I hope the best thing for you to do is by checking whether the processor cooling fan is running cause that causes the system not to power on or power on and before short seconds it flickers and go on off again . there is nothing wrong with your power jack. If the problem is that the pc fan is not rolling then change the fan but if the fan is roling then change the processor itself. any other question?
Posted on Aug 25, 2008
Acer 3680 won't power on even when plugged into the wall
try doing power drain by disconnecting all the cables and battery then press and hold down the power button for 1 min then , check for working if not , you need to service the system
Jul 03, 2010 | Acer Aspire 3680 Laptop
Acer TravelMate Laptop, cord getting hot, not getting power
I would imagine the voltage regulator in the adapter brick it dying...it will fry your motherboard if it starts throwing off power spikes. laptops need good consistent power flow of the right voltage. Buy another adapter.
Sep 05, 2009 | UltraLast ULAC3660L For Acer Aspire...
My screen is black but the green light is on. What's wrong?
• TAKE OUT YOUR LAPTOP BATTERY
• REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
• NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS
That will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen. After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up.Else replace your battery.
Sep 02, 2009 | Acer Aspire 3680 Laptop
MY acer aspire 3680 not powering on. The light on the power cord is on but the light at the front of the laptop is not showing. I took out the battery and replaced it no differennce. I held down the power...
When you wriggle the plug in the power socket on the laptop and the charge LED flashes and in the right position it charges, this indicates that the power socket is faulty or there is a dry solder joint on the motherboard where this power socket is attached.
To get at the power socket will require dismantling the laptop completely.
If you are confident, can dismantle, reassemble a laptop and use a temperture controlled solder iron then try and fix it. If not a computer repair shop can do the repair, I suggest you get a quote first.
Aug 26, 2009 | Acer Aspire 3680 Laptop
Acer 3680 will not come on battery light blinks when power is pressed
take battery out. With the pattery out plug the computer in with your pwoer cord and see if it comes on, if it does, find yourself a new battery, you have a shorted one.
Jun 23, 2009 | Acer Aspire 3680 Laptop
Acer aspire 3680 laptop will not charge while plugged in wall
It appears that you have faulty laptop power connector socket.
This is why it appears to work sometimes when you plug the connector into the laptop in some direction.
To confirm this, wriggle the connector while you look at the charge light on the laptop, if it blinks as you wriggle it then the power socket is either faulty or just needs resoldering so it will make proper electrical contact.
You can get a compute techo to do this or you can do it yourself but it requires dismantling the laptop completely to get at this power socket.
Jun 01, 2009 | Acer Aspire 3680 Laptop
NO POWER
Heyy don't panic. I know its very costly to replace mother board or power supply SMPS. And i assures you that neither its mother board problem nor power problem. Its a problem with your RAM only. If RAM is faulty then laptop starts giving same problem.
So, please go & replace your RAM. Its not that must costly also. So you can easily afford also and new RAM will boost the performance of your laptop.
Rate this solution if it was helpful to you.
Apr 27, 2009 | Acer Aspire 3680 PC Notebook
Acer 3680 will not turn on at all
take out the memory from bottom, and battery, plug into wall, and try again..
Mar 20, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
95 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
