Question about ASUS P4S533 Motherboard
Problem with my bios
When ever i start my computer it always come in bios, I have also checked my boot sequence, which is normal. it show that i have installed a new cpu i have to reintall my cpu even though i have not install. and again if i restart i get a message that to make change to the first 4 fiels , the motherboard must be set to jumper free mode. please give me your assistance. thank you
  • ASUS Master
  • 3,051 Answers
The first thing i would do is check// change the battery to see if it is any good because it looks like the battery may be bad causing the system to forget the time and things like that,,,, then the next time it boots into bios look at the time and date and location ect..ect section and make any changes to it that it may need , that is why they want you to make changes to the first 4 fields when it boots into bios is to select fail safe options if you have that option and see if it will boot . if not go to default settings ok please keep me posted on this i can help you aout a lot more if needed ok best regards mike
Posted on Aug 26, 2008
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Strike f1 retry boot then how to set boot sequence
Boot sequence is usually accessed by typing either F12 or F10 when starting the computer. If you have changed nothing in your computer and you are getting a book error you may have a failed harddrive.
Jan 12, 2015 | Dell Computers & Internet
Cant start acer 5920
Hi Dear,
Check the mention below instruction to solve you problem.
1. Is the boot sequence in BIOS set to boot from CD or DVD, if not I would suggest you to go to BIOS and change the boot sequence to boot from CD and try to boot from the CD
2. Is the computer custom built or OEM built?
3. What is the model number and who is the manufacturer of the computer?
4. Have you made any changes to the computer by installing any new software or hardware?
5. Since when are you unable to boot the computer normally?
6. You need to get Windows Vista DVD to perform further troubleshooting either to scan the computer or to perform repair install, I would suggest you to contact the computer manufacturer to obtain vista DVD.
Thanks
Sep 07, 2012 | Acer Aspire 5920-6423 Notebook
How can I change boot sequence in Compaq Evo N410c?
You need to access your BIOS configuration. 1. To do this, shutdown your computer and boot it by pressing the power button. 2. You need to hit F10 when the computer first powers up in order to get into BIOS (Note that the key is usually different for different computers. If F10 doesnt work, try F2, F12, Delete or F9. 3. Once in the BIOS, you should find the boot sequence option.
Hope this helps!
Apr 11, 2011 | Compaq Evo N410C Notebook
Recovery Issues A105-s361. Boot sequence always starts with HDD. Tried F12, tried F2 (bios). Any other way to boot from recovery disk(CD-ROM)!!
There is still a way for you to boot from your CD ROM. Just access or go to BIOS again, look for "BOOT" tab and then set the boot sequence of your computer and the set the first priority to be on the (ODD or CD DVD ROM), just make sure you put the CD ROM option at the first section and to do that, Use the arrow keys on your keyboard and highlight it and then press normally "F5 and F6" further instruction are there any way. Once your done, press F10 and select save and exit, Insert the disc on the CD ROM restart your computer at that time your computer should be booting now from the CD ROM.
Cheers . . .
Feb 09, 2011 | Toshiba Satellite A105 Notebook
When I turn on my computer, it goes to a black screen and says, "Disk Boot Failure, Insert Disk and Press Enter". I am also seeing an Error Code BIOHD-2 and it say Warning no drive detected. Can you help...
Possible tha the PC is infected and has the booting sequence faulty , some files are lost. you must reinstall the OS , format teh drive , then install an antivirus and finally the PC harware drivers.
Sep 19, 2010 | Computers & Internet
Cannot boot from hard disk CD. An error occured that your BIOs would be updated and it is not fully ACPI compliant
Windows normally does not update system Bios. If your having trouble booting from CD, start the computer and enter the Bios setup. Change the boot sequence to CD then Hard Driveand save the change. Restart the computer with the CD in the drive and it should work fine.
Jun 28, 2010 | Microsoft Windows XP Professional
Only booting after pressing f12 and select boot devise
You must change the boot sequence from your BIOS.
To do this, when your computer starts press F1 or F2 until you enter the bios setup menu. Usually on Toshiba is F1 or Esc key.
Now that you are in the BIOS, you must locate the boot order section. Just go through every page until you see something like Boot Device, Boot Order, Boot Management, Boot Sequence, etc. (its different for each computer)
There, change the boot order to move the Hard Disk or DVD ROM in the top two items in the list.
Save your settings and exit the BIOS.
Your computer will restart and it should boot up normally.
Feb 02, 2010 | Toshiba Satellite Pro A200-EZ2204X...
My laptop won't boot from cd
to reset the BIOS, there is a small battery somewhere in your computer. if you unplug it for 3 seconds, it will reset the BIOS. I RECOMMEND THAT YOU DO NOT TRY THIS! get a service professional. If this doesn't work you might need to get a new laptop.
Dec 29, 2009 | Toshiba Satellite A105-S2712 Laptop
When I plug in my WD MYBOOK ESSENTIAL 1 T Drive the XP machine will not boot. It locks up during boot but if the WD drive is unplugged the boot process continues. After booting plugging the WD Drive back...
This is normal, simply because when your system is performing the boot sequence when it is first powered up, it checks all the possible drives that has an operating system on it according to the way it is configured to start checking it from the BIOS.
So possibly the default selected place for it to check first is the external drive, and since there is no operating system on it, it gets locked up and it might show NTLDR Missing...or Disk Error.
What you can do to stop that is :
When your system is booting go to setup, and depending on your BIOS type, try to locate where the boot sequence starts checking for Operating System from, if it is removable drives, then just change it to Hard Drive. Then save and restart.
Hope this helps you out.
Goodluck
Nov 17, 2009 | Western Digital My Book Essential Edition...
ASUS P4S533 Motherboard Logo
63 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
