Panasonic tv (tx-80v02a)no picture (green line middle of screen)
Gday ohms, checked the cables running around the tube and they have good resistance,checked av cable all o.k.
any thing else i could look at ,thanks
  • 1,879 Answers
Like we have good power supplied to the picture tube itself ?
Posted on Aug 25, 2008
  • monk3ybidzness
    monk3ybidzness Aug 25, 2008
    like we have good power supplied to the picture tube itself ?
Picture is pink in places and dark scenes the picture is mostly green
Oh dear.
It sounds like you have magnetised the screen by placing something magnetic too close.
Your only hope is to unplug the TV, and remove ANYTHING magnetic away from it, such as speakers etc. Give it a few hours then retry.
If this has been going on some time, it will already be too late.
The other possibility is the tube could be going!
Jan 10, 2018 | Panasonic TX-36PF10 TV
I have a Panasonic TV CT-34WX50 every time I change channels
it sounds that have problem in the chroma board ( video board ) a small board that hooked up in the neck of the picture tube. if the color is greenish the cause is dead in red video driver transistor or open resistance. hope this can help good luck.
Jul 26, 2012 | Panasonic CT-34WX50 34" TV
I have a green tint on the screen. covering about 90 percent of the tv. it looks like a block on the bottom right corner. the very top and right side of the tv is fine. its prob about a two inch line that...
If you tried to clean the mirrors or someone else tried, there may be an object on one of the picture tubes. I've seen this happen. In one case I repaired a projection TVwith a piece of black tape across the red tube. It may have left the manufacturing plant this way. Please check and see if a cloth is laying on one of the projection tubes. If not, you have a contaminated picture tube, replace the fluid. Thanks for asking!
Mar 21, 2011 | Panasonic PT-50LCX64 50" Rear Projection...
I left my tv on when I went to bed and the picture was fine. Then I woke up and turned it off. When I came home and turned it back on, the picture was blurry all around the tv except in the middle of the...
is the blurry all around the picture have different color like a smear of red, blue or yellow?
if it is i think the posistor of your tv is not working. it is the one who activate the degaussing coil around the picture tube the prevent color miss-landing upon opening your tv set.
Aug 11, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Green line in middle of tv when switched on
Is there a picture with the green line going through the centre. If it`s just a green line with no picture, it sounds like the Frame (Vertical scan) Output IC has failed and possibly the safety feed resistor near the LOPTX. The reason why it`s a green line is to protect the tube from phosphor damage. The older TV`s would produce a VERY bright white line across the screen which could burn the phosphors withing the tube if left turned on in that condition. It`s not an expensive repair, but is it worth it with the price of Modern TV`s nowadays. If there is a picture with a green line, it may be due to phosphor damage, in which case, it`s a new CRT (tube). Ian
Jul 15, 2009 | Panasonic Televison & Video
Intermittent 3 inch green vertical line-5 inches from right side
it you have a repair skills you need to open the TV and make sure all the ribon connectors around the circuit boards are proper connected
and if all seems to be ok, the DG board will need to be replaced.
If you dont have any repair skills I would recommend you to take you TV to a repair shop since this is complex repair
Jun 16, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Panasonic - Poor Picture Quality
There can possibly one problem. If you check on tube bords. There is a white plug that plugs into the tube. If you carefuly open that white plug, there is 2 silver contact point, called the spark. clean it with benine., but it must be clean. If you have to use small peace of sand paper ok. But afther that use clear Q-Tex (for Nails) and cover points. Let it dry and set will be ok.
Mar 30, 2008 | Televison & Video
Panasonic Color Rings
It sounds like you have a warped shadow mask in your picture tube if your set uses a picture tube. A shadow mask is like a screen wire that lets the three color guns shoot electrons to their respective phosphor dot on the screen to produce the three primary colors which are mixed properly to produce the scene that is being shown. In other words you have a bad picture tube. Stargazer
Aug 12, 2007 | Panasonic CT-27SF37 27" TV
No picture, only sound
The set has a shorted vertical output IC, probably a TA8427k. The capacitors around the heat sink of this IC dry out and cause the IC to run hot. The correct repair is to replace the vertical output and the electrolytic capacitors near it. Also use 105 centig instead of the original 85 centigrade. The is some time a pico fuse or current limittng resistor which must also be replaced. This a common problem with Toshiba and is not a bad picture tube. The usual cost of this repair is around $120-150 depending on the integrity of the technician. Scrivitron
Jun 18, 2007 | Toshiba 27DF46 27" TV
Televison & Video Logo
Top Televison & Video Experts
