Question about Sony Ericsson W550i Cellular Phone
My mobaile view the white screen
At first. my phone Battrey Discharge for 2 days and then it jus turn off and then next thing is a white screen appeared. i cant even off my phone... i hv to unplug the battery. i try charge mobaile but view white screen. when i tried to on my phone again, the white screen reappear. what happenned ? . Pls help give me Solution . pls white screen
  • 1 more comment
  • sharmark1969 Aug 25, 2008
    i have a similar problem
  • elafff Aug 27, 2008
    it juts turn off
    my phone and then next thing is a white screen appeared. i cant even off my
    phone... i hv to unplug the battery. i try charge mobile but view
    white screen.
    when i tried to on my phone again, the white screen reappear. what happened ? . Pls help give me Solution . pls
    white screen
  • Anonymous Aug 28, 2008
    the phone fell and on restarting just the white screeren appears and it can't be turned off using the off switch
    Brigadier General:
  • 7,752 Answers
Elaff + SHARKmark + arun - your phone sounds like you are having battery issues you can replace the battery with a new one and see if that fixes the problem if not take the phone and ahve it reflash or replaced the flexcable.
GUEST - the phone needs to repaired the flexcable also need replacing
Posted on Sep 21, 2008
My LG phone screen will not react to touch
When a phone screen is blank or has a white screen, etc, there are three things that could be the cause;
1. Bad/defective screen and the solution is screen replacement. (In your case, your screen might be failing).
2. Software/Virus problem and solution is to flash the phone
3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
Conclusion
Disassemble your phone and check the screen part in order to verify from the above which is actually the cause of the problem.
Please let me know if you need anymore assistance.
Good luck.
Jan 12, 2012 | LG GT540 Cell Phone
Hi, I have a problem with my battrey phone, the battrey does not last takes about one day or two days. Sony Ericsson Experia X10 kind regards, Lungile Mbuyeleni
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 13, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Won't stay charged for more than 6 hours with new battrey
its the default & maximum service given by your new battery & any kind of multimedia phones. you can not increase the time of discharge. don't use it much to listen songs,watch videos, surf net,etc. also disable the screen saver. all these will save your battery charge.
Dec 15, 2010 | Samsung Smooth SCH-u350 Cell Phone
My car want turn over and new radio install fuse problems
mcdevito75 here, The battery light indicates the charge the alternator is putting back into the battery, a regulator in the alternator allows only a certain amount of electricity to be built up. Sounds like the regulator in the alternator is shorted and draining the battrey, Have your repair shop test the alternator and replace.
Mar 04, 2009 | 1989 Chevrolet Celebrity
Nokia N70 white screen
jus use a hair dryer for a FEW min ONLY...prob solved
Jul 17, 2008 | Nokia N70 Cellular Phone
White screen sony ericsson w810i
i got the say problem 2 days back. I read some pots in forums. This is what worked for me. First fully charge the phone some. Get a friend's phone or something. Then get ready with the data cable and your computer with internet.
Goto Sony ericsson site.
search for w810i SEUS Sonys update system.
At the bottom result it says"Sony Ericsson - Support - Update Service Compatible with K510i W810i W200i .
Click on that and dowload the program. At the right corner it shows the phones which supports it.
install the program and run it.
do exactly what it says.
it worked for me. I got all my contacts and messages back.
Good luck
-Manoj
Nov 03, 2007 | Sony Ericsson Walkman W810i Cellular Phone
there is 2 things.first maybe software problem or second you have to change the 2 wire that conect the main board with lcd.
Jul 04, 2007 | Sony Ericsson W550i Cellular Phone
White screen
Very common. you're not alone... ;] Hopefully your problems will get fixed with the latest firmware, there are all sorts of firmware bugs like this. You can take your K750i to an authorised Sony Ericsson Repair Centre and they will update it for free for you, providing its still under warranty. Or you could update it yourself via the sony ericsson website - Hopefully your problems will have been fixed with the latest firmware, there are all sorts of firmware bugs like this. [b]a[i]s, You can take your K750i to an authorised Sony Ericsson Repair Centre and they will update it for free for you, providing its still under warranty. Or you could do try doing it through the website - http://www.sonyericsson.com/spg.jsp?cc=gb&lc=en&ver=4000&template=ps1&zone=ps&lm=ps1&pid=10242 You could also try fixing it by using a new SIM, I heard it worked for someone with a 32k SIM that had this problem, and put in a new 64k one. Good luck
May 03, 2006 | Sony Ericsson K750
Sony Ericsson W550i Cellular Phone Logo
445 people viewed this question
Top Sony Ericsson Cell Phones Experts
Sandeep Shenoy
Shehu Pro
Shehu Pro
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
