Question about Motorola Mobility RAZR V3i Cellular Phone
V3i as bluetooth modem
My bluetooth modem on the V3i was working fine till 10 days ago and I could connect through my pda and my laptop, for the last 2 months. Then 1 fine day it stopped, and I have not been able to get it going again. I spent an hour with the service provider (airtel). We did the following- 1. Checked and re-entered the settings on the phone and pda. (both are correct) 2. Switched off/ soft reset and restarted. 3. Unpaired and re- paired the devices. 4. Entered extra string modem commands on the pda. 5. Removed memory card on the phone. 6. Reset Cache in "Browser" in the phone. 7. Each one of these has been done before and after a switch off and switch on/ soft reset. I have tried all these on my own too.
The message I get is "the answering modem has disconnected... please check settings..."
The service provider has given up and have just asked me to change the handset saying the v3i modem is known to give problems.
In response I say (and they do not listen) that everything else seems to be working fine. For eg-
1. I am able to use all other bluetooth services between the two.
2. I am able to dial phone numbers from my pda through my phone via bluetooth.
3. The error message comes after the following stages have been passed-
- Opening Port
- Connection established
- Dialling number *99***#
- Verifying pin and registering
- Verified
- Registering... on network
- Wait
- Error "the answering modem...."
Please Help. I cant afford an new phone yet.
    Brigadier General:
  • 7,752 Answers
Update the firmware then try again
Posted on Dec 28, 2008
How to connect my to the internet
you haven't told us your pda model, but nevertheless, let us assume your pda is bluetooth capable, can be use as usb modem. and the necessary drivers are already installed.
on your computer, go to network, then select set up a dial up connection, then on the modem's list, select your phone, then indicate a phone number by inputting *#99# (this means that your pc will dial the default internet configuration on your phone) so it can connect to the internet. you must configure your phone browser settings for this to work.
you may also pair your device using bluetooth, then setup a bluetooth connection. same process as usb modem setup..
Dec 29, 2012 | Computers & Internet
Im trying to use PDAnet with bluetooth I have the bluetooth card installed on my laptop tuning vista, and it has an error that says that I need to install the bluetooth software for the phone, and I've...
Make sure you have bluetooth on on both, and that you are connected via bluetooth to your computer.
Turn on pda net on your DI and enable bluetooth dun.
Now go to your bluetooth settings on your computer and double click on your device, a new service should pop up allowing you to enable dun/modem and select that.
right click on your di bluetooth connection on your computer and create a dial up modem.
select the generic bluetooth modem, not the pdanet modem.
Type 123 in the phone number and leave the username and password blank and click connect.
Now you can right click on your DI bluetooth icon on your computer and select connect to the modem connection you just created.
After using my DI as a modem over bluetooth there are a few things to consider.
1. yeah it works great.
2. Its a battery **** fest.
Constant 3g with constant bluetooth = constant battery draw.
I would still recommend using your pdanet via the usb cable, seeing as this will keep the battery level charged, as well as same speed!
Aug 29, 2011 | Motorola Mobility Droid X
My compaq laptop refuses to connect to dial-up & braodband (LAN)
please update ur driver immediately or contact vendor
Jul 24, 2009 | Computers & Internet
I just got an LG shine TU270 3 days ago and I installed the LG USB modem driver and LG PC Suite but for some reason when I run connection wizard it fails when connecting to USB or Bluetooth and now im...
dont connect the phone until the software is installed...
try to reinstall the phone software on the system again,,,and wait for the phone to install al the interfaces by itself on the system...till be be calm after connecting the phone with the system
Dec 04, 2008 | LG Cell Phones
Use as phone modem for my laptop
go to ur settings..connections....USB device or modem the required and proceed..all the best
Thanks for using Fixya
Aug 23, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola V3i phone tool free download
what I need to know is where can i get free download for Motorola V3i phone tools to use my phone as a modem. Thanks. Richard.
Jul 14, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Modem Drivers for chinese mobile phone MT 6227 and Mt6228
You can download your modem driver from here
May 18, 2008 | Cell Phones
V3i as modem
yep simply attach the cable start your motorola ponetools and tada you are done
Nov 18, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Restoring SD Card from ActiveSync Backup
I am fairly sure that you are out of luck. The Active Sync backup does not backup SD card data.
Sep 08, 2005 | HP iPAQ H2212
Motorola Mobility RAZR V3i Cellular Phone Logo
91 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
