I write complete answers, and know the GE timer line.
Open links to illustrate discussion.
Aug 2011, Jasco does not show a manual for 15351 timer.
They show 120V 15350, which is identical to 120V 15306.
That makes me believe that 240Volt GE15351 is identical to 240V GE15307.
BUT the 15351 might be a DPST with NO and NC terminals >>> add a comment if your instructions say anything about NO NC terminals.
If 15351 and 15307 are identical, then your wiring is 100% correct, assuming you connected hot leads to terminals L and 1.
http://waterheatertimer.org/images/GE-15307-wiring-250.jpghttp://waterheatertimer.org/GE-timers-and-manuals.html#15306Checking details:
1) You checked that terminals L and 1 are not connected by a brass bridge.
The 120Volt timer comes with a brass bridge across L and 1
2) Timer mechanism is attached to enclosure with 2 screws. Remove timer mechanism from enclosure, and compare back of your timer with following image to confirm timer is DPST.
http://waterheatertimer.org/images/IMG_9334-GE15307-500.jpg3) Test 10-3 wire from breaker box. Test each wire to bare ground to confirm the hot wires. Then test each hot wire to other wire to confirm neutral wire. Tape tester leads to wood sticks to keep hands away from power and stand on dry boards.
4) Read nameplate on motor to make sure it is single-speed 240Volt.
5) IF motor is 2-speed, then look at wiring diagram and then add a comment with that information.
6) If pump motor trips breaker when connected directly, then pump might be shorted out. Double check wiring diagram on pump.
7) Take photos of problem. Post photos on flickr. Then add a comment with links to photos so I can see wiring diagrams, for possible help.
