Question about HP LaserJet 1020 Printer
Printer prints blanks lines
My printer prints blanks lines within a print job.
please see the image below.
what can i do.
  • coolcurrent4 Aug 29, 2008
    where is the drum. in the cartridge or printer?
  • coolcurrent4 Sep 04, 2008
    i would need to replace the whole printer, or cartridge cos have replaced the cartridge already.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Does it move to a different spot each copy? yes
replace drum
Posted on Aug 25, 2008
  • CheckitRight
    CheckitRight Aug 29, 2008
    did you replace the dum?
  • CheckitRight
    CheckitRight Sep 04, 2008
    the drum in your case is part of the cartridge, so you will need to replace the whole unit
Printed copies have ghost images on them. I have never had this problem before., It looks like the image printed twice - once fine and then faint horizontal lines, sometimes some of the previously printed...
1) try doing a full clean from within the menu on the printer, or within the computer software
2) You need to perform a half test. Put a sheet of paper on the manual feeder and do a config page from the information menu on the printer. When the back edge of the paper enters the printer, quickly open the toner door to stop the printing. Now remove the toner cartridge and look at the image below. If the defect is present, then the toner cartridge is the problem 99% of the time. There is a slight possibility that during the conditioning stage of the print process the drum of the toner is not being fully discharged so when the next stage takes places part of the previous image gets put on the toner cartridge again. Very rare. If the defect is not present then the fuser has an issue.
May 04, 2011 | HP LaserJet 2420 Printer
When asked to print my c5180 all in one ejects blank sheet of paper making no attempt to print
Just click below for more information;
s.gif » Macintosh: All-in-One Ejects Blank Page or Pages in Mac OS X V10.4
Mac OS X V10.4: A blank page or pages emerge from the product when it is turned on. s.gif » A Blank Page Prints at the Beginning of Every Print Job ...
A blank sheet of paper prints at the start of every print job. s.gif » Load Paper
Instructions on loading paper and envelopes. s.gif » When I Try Printing in Windows Vista, My Printer Is Not Available in the List of Printers ...
Windows Vista: The product does not appear in the printers folder when attempting to print on a network. s.gif » HP Photosmart C5180 All-in-One Printer: Manuals
... HP Customer Care | HP Photosmart C5180 All-in-One Printer | Product information HP Photosmart ... One Printer | Product information HP Photosmart C5180 All-in-One Printer: Manuals About these files: These
Hope this may help;
Regards,
VOTIT
Aug 23, 2008 | HP Office Equipment & Supplies
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
My printer started printing everything backwards. I don't know how to fix it?
Please follow the steps given below:
Click Start
Click Settings
Click Printers and Faxes
Right click on the printer icon
Click properties
Click printing preferences
Click basic tab
Remove check from Mirror Image
also use the link given below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01957673&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=2512009&lang=en
Mar 28, 2010 | HP Officejet Pro L7680 All-In-One Printer
My HP color laserjet 4500 is printing only blank pages
This is usually the Transfer kit, but if the image drum or one of the power supplies goes bad, that can also give blank pages. The Drum problem for no print is usually a grounding/connection problem. Power Supplies are a complicated repair, but these printers aren't too bad to work on. You can buy good used one's fairly cheap on ebay, though. Should consider going to a later model CLJ if you replace with a used, though.
Apr 07, 2009 | HP LaserJet 4500 Printer
Kyocera FS 1010 is printing blank pages
You may need an imaging unit. VERY expensive.
Sep 12, 2008 | Kyocera FS-4000DN Laser Printer
I have a epson stylus 925 printer an when I print the ink either comes out with lines through the picture or in blotchy spots that bleed and make the picture look like a watercolor painting. I have glossy...
Usually this type of problem is related to the paper choice setting in Printer Setup within your Graphics program. If you are printing from within Windows Preview, you would need to set the values first in the Printer property pages found from Start menu, Printers and Faxes. This leads you to the default setup for your entire system. So it is more preferable to open the image in a Program vs Windows Preview and from within the program usually you go to the File Menu and then Print Preview witch allows you to access the Printer property button and setup from there or you will see a Print Setup item to click on and access the properties just for this print job alone.
Does any of this help you or have you more to offer so I can more specific?
If so, use the comment box below to reply.
Thanks,
Worldvet
Sep 02, 2008 | Office Equipment & Supplies
Workcentre c2424 Color Problem
For Microsoft Windows 2000 / XP OS:
  1. Within an application, click on [File] on the toolbar, and then select [Print] from the menu. The Print window will be displayed.
  2. Click on the [Properties] button. The Properties window will be displayed.
  3. Click on the [TekColor] tab.
  4. Select a TekColor correction.
    NOTE: It may be necessary to try all the color corrections to obtain the required results.
  5. Click [OK] twice to send the print job to the printer.
For Microsoft Windows 98 / ME OS:
  5. Click on [Apply].
  6. Click [OK] twice to send the print job to the printer.
From the Apple Macintosh OS 9:
  2. From the General pull-down menu, select [TekColor].
  3. Select a TekColor correction.
  4. Click on [Print] to send the print job to the printer.
From the Apple Macintosh OS X (10.2.x and 10.3.x):
  2. From the Copies and Pagespull-down menu, select [Image Quality].
    NOTE: If the Image Quality option is not displayed on Copies and Pages pull-down menu for OS X, configure the printer with the correct PPD. See the procedure below, if needed.
To configure the Printer with the correct PPD:
The PPD file contains features a particular printer supports such as TekColor Corrections. In order for the TekColor Corrections and other printer specific features to be available, the correct PPD file must be specified when the printer is installed, or modify the setting following the procedure below.
  1. Open the appropriate utility: Print Center (for OS 10.2.2.x) or the Printer Setup Utility (for OS 10.3.x):
    1. Double-click on the [Hard Drive].
    2. Double-click on the [Applications] folder.
    3. Double-click on the [Utilities] folder.
    4. Double-click on [Print Center] or [Printer Setup Utility].
  2. Select the appropriate printer from the Printer list.
  3. Click on [Printers] on the toolbar, and then select [Show Info] from the menu.
  4. From the Name and Location pull-down menu, select [Printer Model]. The current PPD being used will be displayed.
  5. If the PPD displayed is incorrect (for example; the PPD is set to 'Generic PostScript Printer'), click on the pull-down menu, and select [Xerox].
  6. Select the corresponding PPD for the printer and then click on [Apply Changes].
    NOTE: Make sure the correct feature set is selected. For example; if the printer is a Phaser 8400DP, make sure the DP feature set is selected.
  7. Close any open windows.
  8. Make sure the Image Quality option is available on the Copies and Pages pull-down menu following the OS X procedure above.
Jan 10, 2008 | Xerox C2424 Copier
Printout blank
Hi Seng, Run a self test from the printers control panel. 1. Press the printer?s ON LINE button to take the printer offline. 2. Press the Control Panel MENU button until TEST MENU appears on the display. 3. Press ITEM until SELF TEST appears on the display. 4. Press ENTER. The Self-Test will print. 5. Press ON LINE to return the printer to the online state. If it prints than you have a software issue if not it's hardware. For Software Check the Density Settings. Make sure it's not set too light. Also try printing from another app, maybe you have a corrupt print job. If you have a hardware issue come back here and I'll help you sort through those. Let me know, Dude
Nov 23, 2006 | HP LaserJet 4 plus Printer
HP LaserJet 1020 Printer Logo
179 people viewed this question
Ben Johnson
