Question about Dell Dimension 3000 PC Desktop
WIndows XP won't install/ recognise new hardware
I have a dell dimension 3000 and windows XP operating system with service pack 2.
Although existing pre installed hardware works fine, windows will not install / recognize any new hardware, either via a disk supplied with the hardware or direct from the suppliers web site. The drivers appear to download onto my system direct from the manufacturer’s web site, but when for example the I try to plug a new camera or Web cam after downloading the drivers, windows Found New Hardware runs, but then a window pops up saying
'Problem installing this hardware USB device. An error occurred during installation of the device. The data is invalid'
I have checked the USB ports via the device manager all of which say they are working properly (although this is incorrect as the 2 front ports no longer work). I have also tried the update driver tab for each which advises there is no new update.
Not sure if it has any relevance but, The Phillips DVD drive supplied with the original system has also recently stopped working, which I am currently replacing with a Pioneer DVR 125. I'm on virgin media broadband, have a Zone Alarm firewall and AVG antivirus software, which I have closed down and tried to then install devices incase they are having any affect, but this does solve the problem.
I am sorry that this is so lengthy, but I am now at a complete loss as to how to resolve the problem as I am not sure if the problem is with the windows install shield / USB connections or either.
If you have any suggestions I would be very grateful as I am at a complete loss why windows will no longer recognize or install any new hardware.
Many thanks
J Stoodley
1. Start the computer.
2. During preboot Press F8 repeatedly to display the startup menu. (alternative below)
3. Select Safemode from the startup menu and continue.
4. Right-Click "Mycomputer".
5. Select Properties.
6. Select Hardware Tab.
7. Click "Device Manager" button.
8. Click (+) plus sign next to hardware or components in question.
9. Right-Click each hardware in question and select uninstall.
10. Perform steps 9 for all the components that are having issues.
11. Restart the computer.
Alternative into Safemode:
1. Click Start, then run.
2. Type msconfig and hit enter key.
3. Click BOOT.INI tab.
4. Check /SAFEBOOT
5. Click OK
6. Reboot PC
Upon reboot into Windows, your PC should attempt to install drivers for the hardware that was uninstalled in Steps 9-10. Keep in mind though that Windows will choose the best match possible drivers for the hardware in question. Once Windows has installed the drivers, I normally reboot the system again, if Windows doesn't mention it or not. Also, you may want to reset your boot option into normal mode, like mention in Step 2 or Alternative Option just uncheck /SAFEBOOT and restart computer.
NOTE: I'm sure you've already updated Window from Microsoft, If not, you should.. just in case Windows Update have crucial updates to your problem or similar. There also maybe updates to your hardware as well when the scan is performed. -- Good Luck
Posted on Aug 25, 2008
    Novelist:
  • 125 Answers
Ok firstly can you see the DVD drive in BIOS or any USB Devices Within Bios ?
If yes , we have just solved your problem to both your USB and DVD Drive problems , it being windows , it is failing to communicate device anomalies and is failing to handle device operations.
If the answer was no , you most probably have a faulty motherboard and the problem in question is most likley the south bridge , this is responsible for handling plugged in devices , IDE devicesUSB controller etc.. and communicating with the CPU
On another note in windows you could try one of two things:
1. Completly remove existing drivers , including the chipset and USB control drivers and reinstalling them , then rebooting and trying it all again
or
2. Reinstall the Windows OS and test your devices once more
I Hope this will solve your issues
Thanks , and please dont forget to rate :D
How to do a system restore on a dell dimension 3000
To perform a system restore, go to start ->programs->Accessories->system tools->system restore .There you need to select option restore you computer to a previous date. chose a date and click on finish..it will continue restoring
Aug 27, 2010 | Dell Dimension 3000 PC Desktop
Is Windows XP Home Edition Service Pack 2 compatible with the Dell Dimension 3000?
Installation checkup If you already have a copy of XP in your hot little hands and you're not sure yet whether your system is compatible, you'll find the XP Setup routine contains built-in compatibility checking. You can save yourself a lot of headaches if you:
  • Read the compatibility report which is generated automatically at the beginning of the installation and take note of its findings.
  • Remove any items that are likely to cause problems. If the compatibility checker finds any likely problems, uninstall or disable any incompatible software and remove any incompatible hardware (if possible) before continuing. Particular software to watch out for is CD burning software, system utilities and antivirus software. Check the manufacturers' sites for updated drivers and software and install them before trying to run XP Setup once more. And watch out for your USB hardware, as XP seems to be particularly finicky about which USB devices it will support. Once again, check the manufacturers' sites for updated drivers.
  • Abide by any warnings from Windows. I deliberately ignored XP's warning that the USB Smartcard reader I installed was likely to cause problems. The result? A blue screen of death, a series of reboots, and the forced removal of the offending Smartcard reader. (In fact, it gave me a chance to use one of XP's nifty features: Device driver rollback. Worked a treat!)
Aug 22, 2010 | Dell Dimension 3000 PC Desktop
Keep getting stack overload. line 0
Your browser is corrupted, reinstall it.
Jul 11, 2010 | Dell Inspiron 1720 PC Notebook
Dell dimension 3000 series won,t install drivers and utilities cd after fresh install of windows xp sp2
Hello
Run the windows update again to win sp3.
Sp3 has most of the drivers in the dowload.IF not you should be able to install utilities after you get win xp sp3
Apr 12, 2010 | Dell Dimension 3000 PC Desktop
Misplaced cd for operating system
reinstall CD will not help u do a clean install after formating, so u need to get a windows install CD....try piratebay.org u can get the torrent link file there for any win OS and download that, it will get u the full working version of any Win OS in google do a search "Torrent piratebay Windows XP" u also need to get/install BitTorrent software from google/internet to get the torrent link file...
the full file of WinOS say 400 - 700 mb may be a ISO file that u need to burn to a CD so that u can boot from the disk and install windows
Feb 01, 2010 | Dell DIMENSION 3000 CELERON 2.4GHZ...
Dell Dimension 3000 system recovery
AH yes, Kristen very familiar with your issue, it is trying to load the primary boot record from a device it dosen't see , ( re: a floppy thats not there) you need to check the BIOS and make sure the booting sequence is correct (re:disable floopy if one dose not exist, etc) please write back if you need help doing all of these things
Apr 18, 2009 | Dell Dimension 3000 PC Desktop
I have Dell inspiron 1525 laptop with windows Vista home premium
go to bios setup n change sata driver to ATA from AHCI n  also disable da flash play module
Mar 18, 2009 | Microsoft Windows XP Professional for PC
Windows installer not found
Does the Vostro have PCRestore (some business lines do not).
To verify see if there is a bar along the top that says WWW.DELL.COM just after the Dell logo during startup.
if it exists shut down the computer, power it up, hold the CTRL key and tap the F11 key a few times, it will bring up PCRestore for XP systems.
If you post the actual error we can probably fix it without reinstalling.
Feb 05, 2009 | Microsoft Windows XP Professional With...
On start up windows wants to install msword which is already inst
What it sounds like is happening is that not all features of MS Word are installed and the system is looking for the installation CD to obtain some necessary feature/option. Don't cancel the installation. Put in the Office CD and let it perform the update.
As for Windows XP service pack 3, you likely need to validate your operating system. The Microsoft website will prompt you accordingly... let it validate and you should be able to download SP3.
Dec 30, 2008 | Dell Dimension 3000 PC Desktop
Sound windows xp dimension 3000
hi if your motherboard have you install sound properly....Or not your sound driver you Go to driver Zone.com then download it
Jun 06, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
1,088 people viewed this question
Alun Cox
