Question about HP iPAQ hw6515 Pocket PC
Device switches off by itself
Can anyone tell me why my HP iPAQ 6515e keeps fading and shutting off by itself when the battery level reaches 70%. but when I connect it to the powersupply or cradle it works fine, but when i disconnect from the powersupply or the cradle, it swithes off again, the battery level is still in 70%. I tried hard reset and bios update, but the problem is still exists. can some one tell me whether should I change the battery. if soo suggest me should i buy extended or the standard battery and also please give me the price in INR and where is it available in Bangalore, India.
The problem is a little microswitch that tells the unit to power off when the back cover is removed... it seems to be a common problem, causing the screen to go 'interlaced' and reset or hang, sometimes shaking causes it to restore itself. solution is remove the back cover (4 torx screws and 1 philips screw under the warranty tag) and glue the switch in the up position...
Posted on Sep 02, 2008
My hp ipaq 614 wif is not turning on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 23, 2012 | HP iPAQ 614 Business Navigator 2.8-tft...
Phone switches off when shaken
its probably problem with switch on the right of the battery. This switch turns off device when back flap is removed.
Apr 15, 2009 | HP iPAQ hw6515 Pocket PC
Ipaq hx2190
hard reset for hx2190
Jun 27, 2008 | HP iPAQ hx2190 Pocket PC
IPAQ 6365 hard reset
I Also Had The Same Problem. Now I Fixed It. Go To Power In Settings. Click On The Advanced Tab. Uncheck The Box Which Says "Turn Off The Device If Not Used For" Box. This Will Solve The Problem. It Solved Mine. Thereafter Once, My Backlight Did Not Switch On. Fix This By Going Into Backlight Settings And Uncheck The Box Which Says "Turn Off The Backlight If Not Used For" Box. This Will Solve It. Then Soft Reset The Device To Change Settings. To Soft Reset, Find A Small Hole In The Left Hand Side Of The Device. Put Your Stylus In And PRESS ONLY ONCE. If You Keep It Pressed, Your Device Will Hard Reset. Don't Do That. Just Press ONCE.
Mar 31, 2008 | HP iPAQ h6315/h6365 Pocket PC
IPAQ PDA
Go to the HP.com site and get the latest firmware upgrade for your IPAQ. If you already have the latest firmware then you can probably try a hard reset which will wipe out all your files then see if it performs better from a factory reset. If it doesnt improve then theres nothing much you can do but send it to the professionals for servicing or get a new phone.
Mar 05, 2008 | HP iPAQ hw6515 Pocket PC
Cannot power on...
How to correct iPAQ 5450, 5455, 5550, 5555 battery charging problems / dead unit syndrome.
The iPAQ 54xx or 55xx will not power on if the batteries charge is lower than 3.2 Volts, if your battery charge falls below the 3.2 volts level your unit will not turn on, you need to plug the iPAQ into a cradle or AC charge adaptor. Note the charging light on the iPAQ will not flash at all (normally flashes orange) until the battery charge has reached a minimum charge level of 3.2 volts. You then need to perform a normal reset, then the unit should switch on normally.
HP Procedure is as follows:
To charge and reset the iPAQ Pocket PC h5400:
i) Connect the iPAQ Pocket PC h5400 to an A/C power supply.
ii) Charge the battery to the minimum level of 3.2 Volts. This will take 5 to 30 minutes depending on the current charge level.
iii) Perform a normal reset.
iv) Power on the iPAQ Pocket PC h5400
It is recommended that you keep the iPAQ Pocket PC connected to the Universal Cradle or Cable when it is not in use.
Apr 30, 2007 | HP iPAQ HX4700 Pocket PC
Power
Mike, Most PocketPC's will turn themselves on in certain situations: - A taks reminder is initiated - An apointment reminder is initiated - You syncronise your PDA with your PC These are just a few examples. However the PDA should turn itself off after a given amount of time, unless set to do otherwise. Go to your system settings, power, and change the time in which your device turns off. It may very well be that it's set to never switch off.
Sep 11, 2005 | HP iPAQ hx2410 Pocket PC
6515e sound problem
Please try soft reset. If it still does not work, most likely is hardware issue
Sep 08, 2005 | HP iPAQ hw6515 Pocket PC
Hard Reset HP 6515
Hold down the POWER button and press the reset hole for approx 5 seconds, then remove stylus from reset hole first, follow by release of POWER button.
Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
HP iPAQ hw6515 Pocket PC Logo
325 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
