Hi i have a panasonic 80cm tv ,model no# TX-80V02A volume is o.k. no picture except for a single green line going from left to right in the middle of the screen any ideas on what could be wrong ,thanks
    Genius:
  • 1,011 Answers
Dear Sir/madam,
Panasonic is well known for their cold
solder joints on their circuit boards.
A component soldered onto the circuit board has a bad solder
connection. When you pound on the cabinet, the component
will achieve connection (now and then).
To find this anomaly, you have to take the back off the set and
access the electronics in the cabinet.
Turn the set on and use a non-metallic wand (wood or plastic)
(and not a pencil) to probe the boards. Since the problem has
a relation to the deflection circuits, I suggest probing the
deflection boards. When you find a "sensitive spot" with your
probing (the picture collapses and returns to normal size), mark
the spot.
Using a low heat soldering iron and a good 60-40 electronic
solder, resolder the connections on the circuit board at the
sensitive point.
Since the cold solder joint will not be readily visible, you may
have to do this two or three times until you finally hit the right
spot.
Thanks
good luck
Posted on Aug 25, 2008
  • 1,879 Answers
>Happens on all sources (dvd / aerials / sat / cable) ?
>If you're qualified to tech it, check the cables for the tube.
WARNING: HIGH VOLTAGE
    Genius:
  • 1,847 Answers
The complaint may be dry solderig or yoke ,horizontal or vertical oscilator
Ive got a line down the left hand side of the screen when the tv is turned on the model number is panasonic viera tx-p42v20b
HI,
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
GOOD LUCK IN RECTIFYING THE FAULT, THANKS
May 13, 2011 | Panasonic Televison & Video
Tv screen is black except for 1 horizontal line of color
The line is there because the vertical deflection unit - the one that spreads that line across the entire screen to form the image - has failed. Replacing it is a job for a professional, or at least an experienced amateur, and the parts will be quite difficult to find for such an old tv .
May 28, 2010 | Panasonic CT-36DV60 36" TV
Thick lines descending plasma screen
maybe you have interference with other electrical component near your tv. move the component, example cable box, dvd, sat box.
Apr 14, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Green line in middle of tv when switched on
Is there a picture with the green line going through the centre. If it`s just a green line with no picture, it sounds like the Frame (Vertical scan) Output IC has failed and possibly the safety feed resistor near the LOPTX. The reason why it`s a green line is to protect the tube from phosphor damage. The older TV`s would produce a VERY bright white line across the screen which could burn the phosphors withing the tube if left turned on in that condition. It`s not an expensive repair, but is it worth it with the price of Modern TV`s nowadays. If there is a picture with a green line, it may be due to phosphor damage, in which case, it`s a new CRT (tube). Ian
Jul 15, 2009 | Panasonic Televison & Video
Intermittent 3 inch green vertical line-5 inches from right side
it you have a repair skills you need to open the TV and make sure all the ribon connectors around the circuit boards are proper connected
and if all seems to be ok, the DG board will need to be replaced.
If you dont have any repair skills I would recommend you to take you TV to a repair shop since this is complex repair
Jun 16, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Apr 14, 2009 | Mitsubishi WT-42413 42" Rear Projection...
Panasonic tv (tx-80v02a)no picture (green line middle of screen)
like we have good power supplied to the picture tube itself ?
Aug 25, 2008 | Televison & Video
Panasonic - Poor Picture Quality
There can possibly one problem. If you check on tube bords. There is a white plug that plugs into the tube. If you carefuly open that white plug, there is 2 silver contact point, called the spark. clean it with benine., but it must be clean. If you have to use small peace of sand paper ok. But afther that use clear Q-Tex (for Nails) and cover points. Let it dry and set will be ok.
Thanks
Mar 30, 2008 | Televison & Video
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
How to adjust picture on projection tv
i have a 52" rca projection , and the screen looks like this ") (" on the sides can i do something to straiten it back out?
Aug 28, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
