Question about Canon PowerShot S2 IS Digital Camera
Overexposure problem after the black screen
After the famous black screen problem and using the 15" trick in Tv mode, my camera now has a problem of overexposure. The pictures are completely washed out when taken in sunlight, however indoor pics are fine but they do have light horizontal lines running across them. I tried clicking outdoor pics in auto mode but it continues to be washed out, too much brightness. Please help !
  • 3 more comments
  • mobcom Oct 18, 2008
    I have exactly the same problem with over exposure and horizontal lines runnig throughout the picture.
  • angeloup Dec 27, 2008
    me 2
  • vkushwaha Apr 28, 2009
    I have exactly same problem. any help or suggestions?
  • Anonymous May 01, 2009
    same problem here
  • mgm_attar May 23, 2009
    my camera is same problem
Given that the 15' batteries out trick is just a way of forcing the iris to get un stick i think your iris is probably still getting stuck (but this time open a bit).
you could try doing the 15' trick a few more times in the hope of loosening it a bit.
ultimately once you have had this issue i think you are living on borrowed time before it happens again unless you get it fixed by canon.
Posted on Aug 27, 2008
My Nikon coolpix will not take a picture. I take a picture, but all I get is a white screen. What is the problem?
probably gross overexposure. What shooting mode are you in? Try it on automatic. Make sure you are not in a manual mode.
Jun 10, 2015 | Nikon Coolpix S9400
Why is the LCD screen white? even when pictures are being taken it also appears white. What can be the possible cause and solution for this?
Well, check what mode you are using. If it's MANUAL, maybe you are using the wrong apperture/speed/iso settings for the light conditions. The picture is being made as you are ordering (with wrong settings), causing a too clear image getting recorded (overexposure); sometimes the overexposure is so extreme that a "all white" image appears on the screen.
Try changing the mode for APPERTURE PRIORITY, SPEED PRIORITY or PROGRAM (A, S or P respectivelly), so the camera will try to compensate the other variables for the correct exposure.
If so, don't give up using the MANUAL mode (which is the best one, in my opinion). Only try to learn a little more about exposure and camera's controls.
Feb 08, 2010 | Cameras
Black AFS Nikkor 300 2.8 occasion overexposure in continuous mode. The closer the subject, the more likely the overexposure. Using to shoot cross country.
Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Sep 28, 2009 | Nikon Telephoto AF-S Nikkor 300mm f/2.8D...
I am getting over expose in auto mode in my canon
An slr has a mirror that needs to flip up at the moment of exposure so you don't get anything on the screen. As for the overexposure, you need to experiment with the ISO settings, the white balance and even the exposure compensation.
Aug 24, 2009 | Cameras
Camera turns on, lens goes out, but it is black, see nothing through it or on lcd screen (yes, cover is off). There is no error messages, still takes pictures but just black. Can view previous pictures on...
It coud be a very common IRIS/Shutter stuck problem...this has been reported on lot of S3 IS & S2 IS cameras... just search for this on web and you'll find a temporary solution also (related to taking battery out in the middle of taking picture during a long exposure (15" in Tv mode), but for more permanent fix you need take it back to Canon service center
Aug 03, 2009 | Canon PowerShot S3 IS Digital Camera
Overexposure in AV mode
check your EV settings.. might have set it high on +7
Nov 11, 2008 | Nikon D40x Digital Camera
No image in viewfinder or on screen
I found this solution on a different page and it fixed my camera that was having the same problem.
In the case where you get a black image, the following may be of help:
This is a common problem in older Canon S2 IS cameras, especially ones that have not been regularly used. What happens is that the lens iris gets stuck at a small aperture. Most often you can get function back. Here's how:
Turn the camera on in shooting mode.
Turn the mode selector to shutter priority ("Tv").
Use the four-way button on the back to set the shutter speed to 15 seconds. That's right, 15 seconds. (To do this you keep pressing the left direction on the four-way button until it goes from 1/1600 or whatever it might be all the way to 15")
Press the shutter release. Count to seven, then pop open the battery compartment.
Wait several seconds, then close the battery compartment.
You may need to repeat the above sequence several times to unstick the iris. If that does not accomplish it, you will likely have to send the camera in for repair.
Once you have it working again, you should use the camera regularly to keep it from sticking again.
This sounds like a pretty ghetto solution but it worked for me and I know it has worked for others. So before you go wasting your time writing letters, give this a shot.
Oct 17, 2008 | Canon PowerShot S2 IS Digital Camera
Canon S2 is washed out pictures
Just when I thought my camera was fixed I started experiencing the same problem with my S2 IS. Don't know if it is any help to finding the solution but the camera works fine outdoors when used in video mode.
Aug 15, 2008 | Canon PowerShot S2 IS Digital Camera
Lumix dmc lx2
Does the menu show up on the screen, or is it totally black?
Does the camera take pictures and behaves as normal (apart from black screen ;)?
If the menu shows up then I'm afraid it's most probably something serious- like dead CCD or failed shutter (probably the latter-LX2s are not famous for failing CCDs). Failed shutter is easy to identify. You would normally hear a faint mechanical"click" when taking a picture (make sure you disable sounds in your camera). If you can't hear anything then the shutter might be dead. In cases like this I normally suggest getting a donor camera from ebay and replacing the lens (the shutter assembly is inside the lens but it's much easier to replace the whole lens).
Good luck,
Raf
Aug 04, 2008 | Panasonic Lumix DMC-LX2 Digital Camera
Camera will not operate
Use the audio-visual cable that came with your camera and connect your camera to your TV.  Now turn-on your camera and switch to "view mode", e.g., to see a already taken picture on your LCD.  You will not see anything on your LCD but may see an image on your TV, even if the image is "F18".
I used the above trick to clear an F18 error on an A75.  Right now I am trying to get the camera to focus properly, but somehow the above cleared the F18 error.
If the above does not work, try connecting your camera to your computer's USB port using the other cable that came with the camera.  Your camera will want to be on, and in the "view mode".  I have read that this trick can reset an F18 error.
Good luck.  At least it costs zero to try these two tips.
Oct 11, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
333 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
