Question about Intel DQ965GF Motherboard
Motherboard Hello my name is Tumelo ive recently started having a problem with my Intel DQ965GF Motherboard, i changed a setting inside the bios so that my board should work with DDR2 667 RAMS only and when I saved the settings and rebooted the computer, it wouldnt display anything on the screen. At the time that I was changing the settings, I was using a 1GB Solid DDR2 533 RAM, that was currently operating my PC, i tried inserting a 256MB DDR667 RAM but that didnt change anything, please HELP!!!
    President:
  • 2,351 Answers
Hi T, you know you can not run two different types (Speeds) of memory at the same time? Please re-check page 14 in your manual. Make sure your current memory timing for 667MHz is set to 5-5-5. Lost display, incert your old memory & reset the cmos jumper page 52 in your manual.
Posted on Aug 25, 2008
Intel DQ965GF Motherboard won't load WIN OS (WINXPPro volume disk or Win7) tho an old Dell disk did load. Is there a fix? Thz
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+965+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DQ965GF
Windows 7 is not a supported system, but you can use the drivers from the vista system, but only the 32 bit.
Turn on or restart your computer and watch for a message during the post about a particular key, usually Del or F2, that you'll need to press to ...enter SETUP. Press this key as soon as you see the message.
After the post, BIOS will attempt to boot from the first device listed in the boot order.You need to change that, so the first boot device in the list is the dvd drive. If that device is not bootable, BIOS will attempt to boot from the second device listed, and so on.
Note: The boot order is a BIOS setting so it's OS independent. In other words, it doesn't matter if you have Windows 7, Windows Vista, Windows XP, Linux, or any other PC operating system on your hard drive or other bootable device, these boot sequence change instructions will still apply.
Here is how you do this:
http://www.hiren.info/pages/bios-boot-cdrom
But ofcourse there could be a problem with the dvd drive or harddrive.
To install windows 7, you will need at least 1 gb ram or more, and a dual core cpu.
Best of luck
Feb 12, 2013 | Computers & Internet
Intel core 2 duo d945gcr
Click the below link and download all the drivers for your Board.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+965+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DQ965GF/
Dec 29, 2009 | Intel DQ965GF Motherboard
How to download sound driver
hello
download from this site
drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Intel-DQ965GF-Sigmatel-92XX-Audio-Drivers.shtml
Nov 19, 2008 | Intel DQ965GF Motherboard
Intel dq965gf mainboard
read this site
http://www.intel.com/products/motherboard/dq965gf/index.htm
told that the max reccomendend conf is 8 gb of ram.
Sergio
Jun 19, 2008 | Intel Motherboard
Motherboard Intel D101GGC no display
Hello dheyx, your Intel D101GGC board used an intergated ATI Radeon Xpress 200 graphics. If you lost display than you're intergated Radeon has died. Suggest you replace it with a
PCI-E X16 graphics card. The Intel D101GGC board does have an opened X16 PCI-E slot. Do not forget to change the bios video card setting. You want the board to see& load the PCI-E first.
Apr 24, 2008 | Intel D101GGC Motherboard
Update my Intel D845GVSR Bios Version to VA84510A.86A.0056.P20, then my USB driver is not working at all.
I followed the suggestion of changing the BIOS configuration to the recovery mode, however one thing was missing - it required a startup disk and I didn't have one. I then changed the BIOS configuration to the config (pins 2 & 3) mode, booted up and went to the BIOS/CMOS setup and a new menu tab appeared called "maintenance". I went to the advance tab and selected USB configuration and, instead of a blank screen, there appeared a selection for USB support and it showed disabled. I changed the setting to enabled and three more lines of information regarding USB came up, but required not further changes. I went to F10 and saved and exited and I now have me USB capability back.
Mar 10, 2008 | Intel D845GVSR Motherboard
NO BIOS
to get bios set up you must press DELETE key or F2 to enter set up...
you do this at the time of the booting ....
if your bios is corrupted then you can restore the bios by changing the bios jumper to restoration mode to do this refer to your motherboard manual...
Feb 22, 2008 | Intel Motherboard
Intel DQ965GF Motherboard Logo
192 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
