Question about HP Compaq nx9030 Notebook
Location of RTC battery
Could you explain where the location of RTC battery is please
thanks
jae
  • dmckee Jan 30, 2009
    I have the same problem. I looked at the HP website for this notebook Parts List and found all the parts except the RTC battery. The RTC battery is not listed. Is there an RTC battery for this noterbook??
  • 70 Answers
The CMOS battery is on the back-side of the motherboard on the nx9030. You'll have to lift the motherboard up to gain access to it.
Posted on Jul 25, 2009
I have laptop sony vgn-n530e i gave bios password but i forgate the password what showd i do
Hi Abid
BIOS PASSWORD CMOS/RTC BATTERY
The only way to solve this problem is to remember and enter the correct password.
On some laptops, it is possible to delete the BIOS Memory by temporarily disconnecting the CMOS/RTC Battery before reconnecting it and reassembling the laptop.
So no damage is done during disassembly and the correct component positions and cable connections are restored during reassembly, this is a job best done by an experienced repair technician.
See below for the location of a CMOS Battery in a typical laptop. The CMOS battery is the rounded, yellow, flattish object at the front centre of the image. While yellow is a common colour, the CMOS/RTC Battery can also be encased in blue, brown, black or green plastic.
On some models the CMOS/RTC Battery is accessible without disassembly, via the Wireless Card compartment underneath the laptop.
On other models, disconnecting and reconnecting the CMOS/RTC Battery is ineffective because nearby capacitors store the data if the Battery is removed and two contact points on the motherboard have to be bridged to dissipate the charge from the capacitors.
The Service/Disassembly Manual for your series of laptops can be downloaded in PDF format from here:
http://www.laptoprepair101.com/laptop/2008/01/07/service-manuals-for-sony-vaio-laptops-notebooks/
In this model, the rounded, flattish light blue object near the Wireless Card is likely to be the CMOS/RTC Battery.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 25, 2011 | Computers & Internet
Where is the lithium battery located on a JAE-A18U model?
Removed 4 screws with black plastic on the bottome. Then slowly seperate the lower housing. Lithium battery is located on the electirc diplay unit which has 3 screws. Unfortunately, the battery is soldered on and will require a shop with soldering experience to replace. I'm having the flashing 0:00 issue and my rice cooker is not working.
Sep 14, 2011 | Tiger JAE-A18U 10-Cup Rice Cooker
Can locate the cmos battery for the Lenovo T400 thinkpad
Welcome to Fixya
The sstem has RTC battery. Please click this link then go to FRU removal. Then click RTC battery.
Thank you for using Fixya!
Aug 03, 2011 | Lenovo ThinkPad T400 PC Notebook
I need to rest password in bios
Removing the RTC battery and leaving it uninstalled for 5 or more minutes causes all passwords and CMOS settings to be cleared. BIOS password can be removed by temporarily disconnecting/ removing the RTC/ CMOS (Coin-cell) battery from the motherboard.
Disconnect the coin-cell battery from the system board and it will reset the BIOS to its default setting and the password would be gone.
Please Refer to Page 29, 106 & 79 of the REPAIR MANUAL IBM T40 for Battery removal, keyboard removal and RTC battery removal instructions.
The Backup Battery (RTC, CMOS) is located under the keyboard. So you have to remove the keyboard to access the battery. The above Manual from IBM shows the exact method/ instructions and pictures for laptop dis-assembly for the purpose.
If you are comfortable with working inside such electronics, you can't do it yourself, or else you may seek help from local laptop service professional.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 21, 2011 | IBM ThinkPad T40 2373 Notebook
Can you please tell me where the Cmos battery is located and if there are any special techniques that need to be employed to successfully remove and replace it? It is (was) a DV6000 series laptop with a...
Remove the battery by following these steps:
a. Turn the computer upside down with the front panel
toward you.
1. Remove the memory module compartment cover
2. Disconnect the RTC battery cable 1 from the system board.
3. Remove the RTC battery
The RTC battery is secured to the computer by double-sided tape.
Reverse the above procedure to install the RTC battery.
Sep 12, 2010 | HP Pavilion dv6000z Notebook
Where is RTC battery located on Toshiba Satellite Pro 6100?
RTC (clock) battery is attached to the battery charge board - it's located underneath the mouse buttons.
Feb 16, 2010 | Navman ICN620 GPS Receiver
HP Compaq nx9020 laptop cmos battery location on mainboard
On the motherboard,does the battery,that looks like a large capacitor.Have a serial number on it that can be matched to Compaqs operations/repair manual(s).?
Feb 15, 2010 | HP Compaq nx9020 Notebook
Password was changed unknowingly by child.can't get in! Acer laptop
1~try to download service guide of your laptop.
2~learn how to reassemble the laptop.
3~ find the the location of RTC battery.
4~take the RTC battery off and wait 10 seconds.
5~put the RTC battery back to the RTC socket
NOTE:
1~BATTERY POSITIVE SIDE DOWN
Dec 23, 2009 | Acer Computers & Internet
Need replace cmos battery on Compaq Armada E500
Please check the manual at this link for the proper removal procedure. In the manual, go to Removal and Replacement Procedures, and then to 5.10 Real Time Clock (RTC) Battery. It will explain how to replace the battery.
Thanks,
Lolita
Mar 05, 2009 | Compaq Armada E500 Notebook
HP Compaq nx9030 Notebook Logo
450 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
