Question about MSI RG54G2 Router (MS-6848-002)
Msi router hi, i have reset my msi 802.11/g router and my laptop reads it full signal, but i cannot access it. i guess i need a default password that i no longer have. what can i do about this??
Reset the router/read the documentation
Posted on Aug 30, 2008
I change my old fios router for a new one my computer work but not my laptop. cant seems to find the password to reset
If you have manual of the router, read what's the default IP adress for accessing router. You can also try typing the 192.168.1.1 instead of a web adress in your WORKING COMPUTER'S web browser (this is the default IP usually). You will get window with username and password (you will find username and password in the manual of the router). When you access router, you can turn Wireless LAN on/off and change all values you need. You really should read manual first, it will all be clear to you after that.
May 21, 2011 | HP Pavilion dv6000z Notebook
Where is the wsp button?
WPS/RESET button it is in the back side of router.Press it for 10 seconds so all settings goes to factory defaults. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Mar 09, 2011 | MSI Wireless-G RG54G3 Router
Need to reset to connect wirelessly to Internet
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access it with above ip then press RESET button for 10 seconds then all settings defaults. Then you can access it with above default ip. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa. .
Oct 07, 2010 | MSI RG54G2 Router (MS-6848-002)
Basically my internet is not secure n i want to secure it but i forgot my username n password to access the the router, wht do i do
Hello
On the back of the router is a small button,hold it in with a pen tip or paper clip for 60 sec.
This will reset it to factory defaults.
Then you can log in as admin
password= admin
username= admin
Once in you can make your changes again.
Apr 08, 2010 | MSI Computers & Internet
I have a laptop running 802,11 g/b and vista and I Cant connect to linksys wag160n wireless router(802,11 n). laptop sometimes recognises network but when I try to connect it wont. could you help ?
Hi, You cannot connect across wireless protocols. In other words to connect to 802.11 n you need an "n" adapter.
Now, the router should be backward compatible & provide wireless g/b but you may find that when you search for networks it will be listed as a seperate network name (from the same router)
Try searching for this other network. Your router documentation should advise you of its default name & any set up process
Dec 23, 2009 | Acer Computers & Internet
Can't access 192.168.1.1
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Or you will need to update the firmware to rest the router.
Nov 08, 2009 | NetGear RP614 Router
Wireless connection
Access the routers admin page with the hardwired pc.  http://*gateway*  right click network status on pc and get gateway.  Google the model you have for the default passwords.  Setup your wifi security then do the same to your laptop and attempt to connect again.  Bad settings somewhere.
James Mac
Sep 09, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Standard username and password
hello!
By default the router username is admin, and the password is also admin
Jul 03, 2008 | MSI Wireless-G RG54G3 Router
Encrypted access
I'm guessing you left it at the default IP address of 192.168.1.1 and you go there using Internet Explorer and are asked for username and password. Is that right? The default username is blank and default password is "admin" with no quotes. If the defaults were changed then that won't do you any good. Your only recourse then would be to hit the reset button on the back of the router and hold if for a few seconds (briefly hitting it does not do a full reset, you need to hold it for a few seconds). This will restore the router to it's factory defaults and the address/password above should work.
I hope this helps. I don't get paid for this, I just like to help when I can. If you found this useful I hope you will give a positive rating. If this did not help I hope you'll ask additional questions.
Good luck and thank you.
Jan 01, 2008 | Linksys Wireless-G WRT54GS Router...
MSI RG54G2 Router (MS-6848-002) Logo
447 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
