If
you hear a noise from the lens when you try to take picture or During turn
on/off time then it's a lens guide pin problem OR Somehow its jammed or
damaged. It's happens when the camera pressed or drop down during turn on mode
or long time not use. For the solution you need to
follow the steps. 1.
Turn off the camera and remove the memory card and clean the external body of
the camera and make sure in place of the lens there is no dust or damaged sign. 2.
Now turn on the camera without memory card & make sure the battery are
fully charged. 3.
If the lens not moving then give a little shake or thrust by hand ( carefully
very slow) and then wait for a moment. If no changes then turn on the camera
and give a little twist an anti clock side and leave for few second. It is
risky ( Do it slowly at your own risk) 4.
If nothing change then reset the camera setting from the menu option. After
following all steps, if the camera does not start working then you need to
visit service center for replacing the Lens or Repairing. If you have any more
questions ask me I fell happy to answer your question. Thank you.
The Turn Signal Indicator
The Sidemarker Lamp
The Sideview Mirror (Pontiac Thunder only)
The turn signal switch also sends a separate on-off signal to the Daytime Running Lamps (DRL) control module, which relays the signal to the appropriate front turn signal. The front turn signals are grounded at G101 and G102. The rear turn signals are grounded at G401. The sidemarker lamps are grounded through the corresponding front parklamp.
The sideview mirror turn signals are a bank of LEDs placed behind the mirror glass.
The hazard lamps operate on battery voltage. The HAZARD fuse supplies battery voltage to the turn signal switch. When the hazard switch is pressed, the turn signal switch sends battery voltage to the hazard lamp/turn signal flasher, which sends an on-off signal to the turn signal switch. The turn signal switch send the on-off signal to all the turn signal lamps, causing all the lamps to flash including both IPC turn signal indicators. The hazard lamp/turn signal flasher is grounded at G200.
When the parklamps are ON, the sidemarker lamps receive voltage from the park lamp supply voltage circuit and illuminate. The sidemarker lamp is grounded through the corresponding rear turn signal. When the turn signal switch is place in the left or right hand position, the rear turn signal illuminates and the sidemarker lamp will loose its ground, causing the sidemarker lamp to turn off when the turn signals are on and to illuminate again when the turn signal is off.
Which blub an socket did you replace ? check the other blub ? The switch and or the flasher module can cause this problem .
Replace the turn signal switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column.
Did you complete the replacement?
Which
