Question about HP LaserJet 4 plus Printer
Printer problem my lasre jet 4 plus gives me error which says printer pc load letter what should i do
  • 138 Answers
Your printer is asking for letter size paper to be put into the main tray. If you have the tray set-up to legal or something else, reset the tray for letter. If you need legal or something else in the main tray, place letter in the manual flip down tray and press the "on-line" button on the printer to bypass the tray selection.
Posted on Aug 28, 2008
HP Laser Jet 4 Plus + PC Load Legal
PC Load Legal means that the printer has been sent a print job formatted for legal size paper and that is not what is currently loaded into the printer's input tray. So, either change the paper to legal or cancel the job in the printer, reconfigure the document on the computer for letter (or whatever is loaded into your printer), and send the job again.
Jan 22, 2013 | HP LaserJet 4 plus Printer
Hp laserjet 4 'PC LOAD LETTER' error
Check to see if the paper guide is up against the paper correctly. Make sure the door is shut completely. I know this sounds elementary but I have been on service calls and this was the problem, just today as a matter of fact.
Sep 14, 2011 | HP LaserJet 4 plus Printer
Printer says " PC LOAD LETTER" will not print
Change in printer driver to use paper "A4" not "Letter" format
Jan 30, 2011 | HP LaserJet 4 plus Printer
Pc load letter
Hi there this issue is caused by your driver defaulting to letter and a4 paper being used set your default paper size to a4 in the driver and also set tray to a4 this should cure the problem Regards AL "alstech"
May 28, 2009 | HP LaserJet 4 plus Printer
I HAVE LASERJET 4 PLUS. WHEN I GIVE JOB FOR PRINTING THE PRINTER DISPLAYS A MESSAGE AS PC LOAD LEGAL. PLS HELP ME IN SOLVING THE PROBLEM
The document you're trying to print is formatted for legal size paper, and the tray contains only letter size. if it's a legal size, put legal paper into the MP tray, or override the setting and manually select "letter size" in the printer dialog box.
Apr 04, 2009 | HP LaserJet 4 plus Printer
HP Laserjet 4Mplus won't print doc & says: PC Load Letter
Pull down front cover and Put a sheet of paper in tray 1 assembly.
Feb 20, 2009 | HP LaserJet 4 plus Printer
Printer cant print excel files
Chjange the page size of the excel document, it at present is set to letter, ...file page set up in excel
Sep 23, 2008 | HP LaserJet 4 plus Printer
My hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
Pc load letter
1-are the guides set correctly?
2-is the sensor flag there? on the bottomof the machine when you take out the tray you should see a piece of plastic hanging and is very loose it is the sensor for the paper, ( although I have seen it work without it !!!!!!)
Aug 21, 2008 | HP LaserJet 4 plus Printer
Laserjet 4 plus printer
printer keeps running until paper tray empty, msg 41.3
Jun 03, 2008 | HP LaserJet 4 plus Printer
HP LaserJet 4 plus Printer Logo
265 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
