Question about Olympus ? Stylus 500 Digital Camera
Date and time
How do I set the date and time on my Stylus 500?
    Master:
  • 852 Answers
With the camera on, press the OK/MENU button. Use the arrow pad to select [MODE MENU]. Select the [SETUP] tab and press the right arrow. Select ‘time icon' and press the right arrow. Select the date format and press the right arrow. Use up or down arrows to set each item and press the right arrow to move to the next item. Press the OK/MENU button when you have finished entering the date and time.
Posted on Sep 01, 2005
How do you set the system date and time
To set the Date & Time, go into the BIOS setting - date 7 time.
When you set the Date & Time and you get this error again when you next boot up your computer, then most likely you have a flat BIOS battery.
Then replace this battery, it could be a coin size battery - 3 volt lithium battery type CR2032. and then go into the BIOS setting and set the Date & Time.
Oct 22, 2012 | Gateway Essential 500 PC Desktop
How to set the date and time
Setting the Date, Time and Date Stamp:
Use the following procedure to change the date and time setting.
1. Slide the Function switch to the capture mode.
2. Press the Mode button twice to turn on function menu. Press the Shutter button to confirm.
3. Press (up arrow icon) or (up arrows icon) to adjust the date and time. Press ◄ or ► to advance to the next setting.
4. When finished, press the Shutter button to confirm the setting; press the Menu button to return to the main menu, press the Mode button to exit the menu.
Jul 07, 2011 | VistaQuest VQ-500 Digital Camera
I CANT GET THE DATE TO DISPLAY ON STYLUS 7010
there is a display button at the bottom right of the back of the camera. its the very bottom rocker buttons. it says DISP/? or/(and the trash symbol). knowing this go to look at your pictures (using the "play" symbol) and click DISP. the time and date should appear now.
Mar 21, 2010 | Olympus Stylus 7010 Digital Camera
My Magellan Triton 500 does not display the correct date or time. Can you help?
Assuming that you have the latest firmware installed. Do a MENU>>VIEW>>SETTINGS and then using the down arrow to scroll down. The Date and time and language and power settings are out of sight. scrool down and you will see date and time.
Dec 03, 2009 | Magellan Triton 500 Handheld GPS Receiver
Can't find how to set date/time stamp on picture
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
Jun 08, 2009 | Olympus i:robe IR-500 Digital Camera
Ultronic lcd clock with a stylus tucked in back of clock
This thing set under my bed, lifeless til I was looking for something else and decided it was time to get this clock working!
(Use the stylus pen for best results) After putting in two fresh batteries (or hit the reset button if your batteries are fresh). This will reset the clock and the 'clock' icon in the upper lefthand corner will be blinking. Now press and hold the display area where the hour of the day is displayed. The entire time will start blinking. Now start tapping on the blinking hours to increment the clock slowly to the correct hours (it will cycle all the way thru military time and regular time, so choose what you desire). Press and hold with the stylus to increment quickly. Do the same with the minutes, that are blinking too. When time is correct, tap the 'clock' icon once. The 'clock' icon will still blink, which I believe is correct operation.
To set the date, tap on 3rd icon down from the top left (it looks like a little calendar). This will put you into the date section of the clock (if you do nothing, it will cycle back to the clock, after ten seconds, as a default). Before it cycles back to the clock, press and hold with the stylus pen right below the word 'DATE', until the the entire displayed date starts blinking. Tap the first two digits of the year to go down in years and tap the right two numbers of the year to go up in years. Tap on the month number to increment; do the same with the date number. When all date entries are correct, either tap the 'calendar' icon, or let the clock sit for ten seconds: it will cycle back to the clock.
I guess you can set the alarm in a similar method.
Hopes this helps!
ExitKC
Nov 03, 2008 | RIM BlackBerry Pearl 8100
I have the date on my Olympus Stylus 1010 camera set, but when I download the pictures the date is gone. How do I set the camera to print pictures with the date?
Normally many cameras do not have date printing in its feature ..... while there wud a date setting ..... still try in your menu if there is any time or date stamping feature that needs to be turned on
Oct 12, 2008 | Olympus Cameras
Date and time
With the camera on, press the OK/MENU button. Use the arrow pad to select [MODE MENU]. Select the [SETUP] tab and press the right arrow. Select 'time icon' and press the right arrow. Select the date format and press the right arrow. Use up or down arrows to set each item and press the right arrow to move to the next item. Press the OK/MENU button when you have finished entering the date and time.
Sep 01, 2005 | Olympus Stylus Verve S / ?-181 mini S...
Date and time
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Olympus ? Stylus 500 Digital Camera Logo
211 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
