Question about Apple Power Mac G4 Dual Mac Desktop
Sound Audio card?
I recently had to replace my cd drive in my unit, and now the sound will not play. I am not sure if I need to relpace the sound card or something isn't hooked back up or what.
Macs don't generally use a replaceable sound card in a slot like PCs. Instead they usually have sound capability built into the main board.
Which model of Mac do have and what model of CD player did you put in it?
Can you hear sound from sources other than the CD player - such as iTunes, internet, system alerts, etc?
As I recall, one CD drive I upgraded on an older Mac did require a light wire harness for the audio output. None of the DVD drives I have replaced recently have needed this.
Did you, personally, remove the old drive? If needed for the new drive, I'm guessing the old drive would have had an audio cable too.
Posted on Sep 05, 2008
Realtek audio sound distorted when playing dvd
The dvd drive has a cable that goes to your sound card. The sound card plays the audio that comes out of the DVD drive. I would try a CD in the drive, alternately try another drive (if using a desktop computer), or try another sound card if you have one. Try another DVD player application (software), it could be a bad codec used for that player.
Sep 19, 2013 | Computers & Internet
My computer wont play the sound when im trying to listen to music or play a movie.i would like to know how to get the sound back on
Have u recently installed a new DVD Drive?
If so and even if so, you need to have an audio cable installed connecting the DVD drive to the Sound Card in order to get sound when playing a MUSIC CD or DVD player from that drive. So double check that inside of the PC.
Next, go into the Audio Settings in the Control Panel and make sure sound is not muted.
Mar 15, 2010 | Acer (54.AA806.001) Sound Card
I have gateway conputer windows 98 ,I upgrded the graphics card to Herculies which is ok , also I upgraded to sound blaster 5.1 live , I can here music from the speakers from the software installed, but...
Hi
the issue is that you have not connected a 3-4 pin wire from the CD drive directly to the sound card.
You will hear sound if you connect your speakers or head phones to the small plug in front of the cd drive.
You will need a audio cable between CD drive and the Sound card.
here is the cable: http://www.pcpartscollection.com/audcabforcdr1.html
sold on the above page for example, or available locally I'm sure in almost any computer repairer. or www.ebay.com
Show this picture or say that you need a audio cable between CD drive and sound card. they will know what you mean (or should)
You need to connect this wire on the cd drive back, next to the other connectors (it has 4 pins)
it also reads AUDIO
other end goes to the sound card, where there are 4 pins aswell, should say CD in or AUX.
Oct 16, 2009 | Office Equipment & Supplies
No sound from inbuilt sound card and pci audio card
you can try going to the intel website and download the audio drivers, as for the sound card go to the manf web site and download the drivers for the card
Jan 26, 2009 | Intel D865GBF Motherboard
Playing MP3's
Hi Jerry,
Sound Blaster is notorious for this problem, I have experienced it myself. Uninstall everything again, sorry it's a must, this time, do not use the cd for the initial driver install, download the latest driver first to your hard drive, uncompress the zip file to a folder on your desktop. Once you have the updated driver info ready, then install the hardware and use the new driver when asked by windows to install it, this should correct the problem. Also, make sure the default sound card is sound blaster using the control panel, sounds and audio devices, audio tab.
Let me know how it works out for you.
Oct 28, 2008 | Creative Labs Sound Blaster Live! 5.1...
Sound when starting up and shutting down. but no sound any other time. unable to play a cd. i have windows vista business.
If all of the Windows sounds work and just audio CD's are failing you can try the following:
First goto Device Manager (right click my computer and select manage, then click on devices in the left hand column). Get the properties for the CD drive you are using. Go to the Properties tab and make sure there is a check in "Enable digital CD audio for this CD-ROM device".
If there is a check there then you need to make sure that you have an audio cable going from the CD to the sound card (or system board if you have on board audio).
Good luck.
Paul
Aug 26, 2008 | Sony Computers & Internet
Audio Breaks
Hello vatsala,
Try downloading and installing the latest sound drive available for your motherboard. Here is the link.
http://www.intel.com/support/motherboards/desktop/D845GVSR/
If that doesn’t work, try using another set of speakers to make sure it’s not your speakers that are bad and if that doesn't work, you may have a bad sound card and will need to put in new sound card.
Sincerely,
Agent Xiong
Apr 16, 2008 | Creative Labs Sound Blaster Live! 5.1...
Searching for audio drive
No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
Apr 04, 2008 | Creative Labs Sound Blaster Live! 5.1...
Creative Labs CT4870 - sound from DVD drive, not from internal or CD drive
Go to my computer. Right click on your CD-ROM. Choose "Properties". Choose the hardware tab. Again hit the properties button and again the properties tab. Click on "Enable digital CD Audio for this CD-ROM device" and make sure there is a check mark in the box.
Click OK, then APPLY, then OK, and try play your audio CDs again.
You can use this so you don't need audio cables.
Jan 06, 2008 | Creative Labs CT4870 / CT4780 Sound Card
Apple Power Mac G4 Dual Mac Desktop Logo
56 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
