Question about Apple MacBook Mac Notebook
MacBook Case cracking
My sister's macBook case is cracking!!!
Will Apple replace the case? Why does it crack? Will replacing it help or it'll happen again?
Just take it back to Apple, it's unfortunately a common problem. Most people have had it fixed for free - warranty or not!
Posted on Mar 11, 2009
    Novelist:
    Champion:
  • 382 Answers
Does it get stuffed in a bag or locker with other items? Is stressed placed on it? Nothing just cracks on it's own. There is no known Apple service programs for cracked cases, only discolored ones. You may want to re evaluate the life of the laptop, especially if it's constantly transported. Has it ever been dropped?
Posted on Sep 01, 2008
Cracked LED screen repair
Ignore it.
Take it to an Apple dealer to get it replaced.
Nov 02, 2013 | Apple MacBook Pro Laptop Computer with...
Macbook battery not charging
If it is under a year old, then you may have a case for a free replacement by Apple. If it is older, then you'll have to buy a new battery and recycle the old one. All laptop batteries have a maximum lifespan and will have to be replaced at some point in the future.
Feb 15, 2012 | Apple MacBook Mac Notebook
My incase case for my macbook pro is causing the hinges to crack
I've had the same problem when I had first installed my case. One day, when it was on the table, my friend leaned on it and there was a loud crack, which got me scared. Due to this, the cracking stopped. Turns out, there is a long tab to attach to where the fan opening is. Just flip your mac over, and push down hardly on the edge of the case, this way, it will be fully attached. Incase makes things perfectly, so if you don't install it correctly, it wont work. Hope this helps. Also, these instructions are not found anywhere.
May 09, 2010 | Incase The Hardshell Case for the aluminum...
How difficult is it to replace a CD-ROM drive in a MacBook Pro?
It is very difficult to replace an Apple Superdrive and is not recommended to attempt to do so yourself unless you have pre-existing experience in doing so. Before resorting to such desperate measures, try testing your hardware with the Apple Hardware Test. You will find detailed instructions on how to use AHT here.
May 03, 2010 | Apple MacBook Pro Notebook
Top Case cracked
Mine has the same problem and I work for a company that uses mac's that also have had the same problem. It is a design fault. Take it to your nearest apple store and state this and they should change it.
Jun 25, 2009 | Apple MacBook Housing, Top Case with...
Cracked keyboard
Are you sure it's a macbook and not an ibook? The macbook has an embedded kebboard. It's ribbon cable and connectors are inside of the laptop as opposed to the ibook, which is installed on the top case. The Ibook did have issues with the clear or green ribbon cable squeezing up from under the right side.
Aug 28, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook keeps restarting
http://www.retrodata.co.uk/notice_apple_seagate_drives.php
May 04, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Cracking noise
Hi terry44,
Try this first. Open the case. Please ground your self by touching any metal surface. Than place your hand on the hard disk drive. Do not hold the underside. Start the PC & continue to hold & listen. You mentioned the system runs for a short time, let’s see if it will crack & shut down while you’re touching the drive.
We want to see if the system still shuts down & you hear that crack. If it’s the hard disk drive you will feel it as well as hear it.
If you feel like the crack came from the hard disk drive than replace the drive because its going to die. Your thoughts about the board could be correct. With the case opened you should be able to pin down where the crack is coming from.
Let me know if this helped & what you found.
Get back to me.
Good Luck!
Mike
Apr 21, 2008 | AOpen AX34-U Motherboard
Cracked psp screen
Youll have to open it up and look if the screen is cracked or the cover, the screen is behind the clear perspex of the outer case.
If its the screen then this will help:
http://cgi.ebay.co.uk/LCD-SCREEN-REPLACEMENT-For-PSP-SHARP-W-BACKLIGHT-Tool_W0QQitemZ200215724197QQihZ010QQcategoryZ127746QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Otherwise you ll need a new case:
http://cgi.ebay.co.uk/SONY-PSP-FACEPLATE-PSP-FACE-PLATE-REPAIR-PARTS-black_W0QQitemZ180232659514QQihZ008QQcategoryZ127746QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Apr 15, 2008 | Sony PlayStation Portable (PSP) Console
Apple MacBook Mac Notebook Logo
114 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
