Email weatherwall wiring
Email weatherwall ww21h..2.5hp.. 700-352-0003
ok. I know the unit is a bit old, but it is in perfect order, however when it was uninstalled the wiring from front panel to the unit was disconected
(red/ yellow/blue and earth )and also the mains in, what I need to know which goes where? I am fairly competent with wiring but a wiring diagram would sufficient or a written exolanation of which goes where.
Thankyou for your time and patience in this matter in advance.
contact
col.mundy@gmail.com
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
RED-- power--r)( yellow-- cool--y) (blue--same as yellow or don't use) (green--fan--) (white--heat) these are wires from the thermostat. Now the ..........................HEY, is this a window unit or central air system!
Posted on Aug 25, 2008
Changed timing belt and water pump because water pump went out also changed the spark plugs and now after getting everything back together the car is only firing on two plugs.
I hate to assume anything, so allow me to just suggest a couple of things I would check...
1. Are the plug wires in the correct order? Do you know what the firing order is for your vehicle? Do you know the order is on the block as well? You should consult a chilton's manual for your vehicle.
2. Did you make sure to look inside the boot and be sure the contacts are actually contacting the plug cap? If you used the old wires, you might want to check them carefully for breaks or other damage.
3. Did you think to gap your plugs before you put them in? "Pre-gapped" isn't always right, sometimes they get bounced around a bit in handling.
Mar 30, 2014 | 2000 Chrysler LHS
Do you know where can i find the rubber gasket that goes around the brew head of my Cuisinart EM 100 espresso machine ?
It sounds to me that your group seal is bad. Since this machine is a 15-Bar unit, it puts out quite a bit of pressure causing water to leak out around the portafilter when making espresso if your seal is old or damaged. The pressure doesn't build up as much when you are running just water through the machine - hence the reason why the machine works ok without grounds. I sell a LOT of parts and accessories for various manufacturers of espresso machines. This particular seal is extremely difficult to locate fom Cuisinart, but is rather easy to replace. Through extensive testing, I have located a replacement gasket produced by another major manufacturer that fits the Cuisinart EM-100 & EM-200 machines perfectly. I sell them for $10.99 each (or two for $19.99) which includes shipping in the continental US and I accept Paypal. If you would like to contact me via email (cowboy_romeo@yahoo.com), I will be happy to help you out.
Mar 20, 2012 | Cuisinart EM100 Stainless Steel Espresso...
Hi, my Nakamichi TM1 clock radio (22 years old) works perfectly except that it turns on intermittently. Can someone suggest a repair site or do it yourself repair instructions? Or a 2 piece replacement. ...
I have an old Nak TM-1 with the same problem....I have isolated ot to the MPC cable connecting the two units; specifically, just outside of the back of the main box. Seems like an intermittent 'short,' even though there is no actual motion of this cable over the years. It mpc's-into the remote unit, but is hard-wired to the base unit. Anyone know if I can order/locate a replacement cable?
--wesmd
Aug 22, 2010 | Audio Players & Recorders
Wired wrong
in order to correctly wire the unit you must have 6 wires outside and a thermostat that will be able to have a aux heat setting if you have further questions tthen email me @ hvacredneck@yahoo.com
Jan 06, 2010 | Heating & Cooling
MEX-BT5700U, no sound in speakers in CD source, tuner source OK.
What many people do on this model is connect the remotes wires improperly. Use the solid blue wire for the amp and the blue with white stripe for the connection to the car.
Dec 06, 2009 | Car Audio & Video
Magicolor 2300DL: prints low on first page, OK subsequent pages
I spoke to QMS about this since it happened to me. It is the registration roller in the transport unit going bad. Basically the clutch is slipping and they are seeing a lot of it on this model. The first page will slip because the clutch is sticking. , delaying the paper pickup . i also have the accordion problem which is where you are headed. this is where the clutch does not disengage when it is suppose to , causing the paper to fold.
The only solution to this is a new transport unit. It is the entire section in the back.. Looks like a bit of work to rip it out but straight forward.
Transport unit
8314131-0360-04
800-972-6705 - $87
I am going to call and order one next week, I’ll let you know how it works out.
Jun 15, 2009 | Konica Minolta magicolor 2300DL Laser...
Broke the touchscreen (LCD is perfect) unit works otherwise
nope
when support is dropped its dropped any unused units or parts end up in the recycle bins or auctions
keep searching internet for a used unit for sale
or put wanted ads in free online sites for one
Mar 04, 2017 | ViewSonic Airpanel V150 15" LCD Monitor
I need a user manual for a email brand weatherwall air conditioner, do you have one?
I have a single sheet "unit controls and operating instructions" as below.
Dec 28, 2008 | Heating & Cooling
Magellan repairs
I don't know what wire you are referring to, however, I just fixed one last week that was 1 year old, not taking a charge (not even to get the screen up at all). Went to batteries plus, ordered a battery for it (there are 4 screws in the back and then some plastic catches that are released with a thin screwdriver--I started on the top). The battery was $25 but the unit is no longer under warrenty and it cost $50 through Radio Shack for them to send it in to the company. Worked perfectly with new battery.
Aug 05, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
RECORD DROP OUT
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
IMPORTANT:
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Oct 02, 2007 | Philips CDR570 CD Recorder
Heating & Cooling Logo
474 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
