Question about Philips HDD1630 MP3 Player
HDD 1620 once i start my player it doesnt go to the menu page after showing go gear on the screen, it also fails to connect with my notebook. i have tried pressin start button with volume + key many times but it is just not starting
  • kamaljeetsin Aug 25, 2008
    thanx for the solution hwever i feel this might not be the case as i ve not used the player so much but it is out of warranty period.i think the player is just jammed somewhere once it goes to the menu page this problem can be corrected
Yep, that means the hard drive is probably fried. I had that problem, ended up opening up the unit and found the hard drive making the standard 'bad drive' sounds (the head moving back and forth repeatedly, unable to read data, occasional clicking sound).. return it.
Posted on Aug 25, 2008
Hi there. I have a hp 6715b laptop and used it the one day and it was working 100 percent. Then the next day it would not get passed the hp boot up screen. It doesnt want to boot into bios or anything and...
wow 2010 year talks to 2017, now that IS MAGIC
ok stutz
hp 6715b let see what you are talking about.
so the screen never onces shows text ever, rigth (a key fact)?
not getting past HP boot up screen means to me windows unstated
XP or VISTA new... so ?
OS login screens are dead, that is booting OS,
BIOS kinda is booted, the processor executes BIOS directly, hard coded in the processors. since 1981.
that is correct bios is first.
for 10 long years, this pc booted and showed you
Hit Esc (or F10) to enter SETUP (hp name for BIOS is silly)
BIOS IS ROM , BOIS WORKS with the HDD and CD drive removed
first lets read your service manual.
see link at end.
Page 101 covers this and tells you to hit F10 at power on,
hammer it, BIOS screens must POP
the hit F1 see the huge info page there, all do that.
unless,
  1. main battery is bad and shorted.
  2. or Coin cell dead as all do 3 to 7 years old, like this one is.
  3. the CCLF lamps or its inverter is dead.
test 1, power on , hammper F10
while shinnging flashlight on the screen
see data now?
yes, bad CCFL lamps/inverter (hp calls it CCFT) search the doc below for CCFT and see it. cold cathode....
no, try the VGA jack to any monitor. got data now>?
data means (words or graphics of any kind)
http://h10032.www1.hp.com/ctg/Manual/c02834030.pdf
see ccfl here (aka dead back lamps)
http://www.pcdied.com/monitors.html#flashlighttest
Sep 20, 2017 | HP Compaq 6715b Notebook PC PC Notebook
When I turn the laptop on (L350) the screen starts with the "Toshiba leading innovation" page then is blank- dark grey. It does not respond to any keys including F2/F12
The laptop can not detect the hard drive please remove the hard drive and then reseat it if the problem persist then replace the hard drive.
Feb 07, 2010 | Toshiba Satellite Pro L350-S1001V Notebook
My dell inspiron 1525 has a black screen with a white cursor showing
First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
Dec 10, 2009 | Dell Inspiron 1525 Notebook
Playlist on go gear vibe
Using Windows Media Player 11 ?
1. Have WMP11 always on top for "drag and drop" usage
Right click in the head of the WMP11 page: in Tools > Options... > Player : select "Keep the player on top ..."
Restore Down the size of the WMP11 screen and adjust the size on the
edge(s) as you require for your screen.
2. in [Library] mode: under Playlists "Create Playlist" e.g. "My Playlist"
and Enter: "My Playlist" is added on the right screen side.
3. Open your music maps and ad songs by drag and drop method
onto the right saying "Drag items here"
4. when ready adding songs in [Library] mode: "Save Playlist"
5. in [Sync] mode drag e.g. "My Playlist" under the connected device
and "Start Sync": wait until al files have synchronized: a message
will show up when you can disconnect the player.
Sep 11, 2009 | Philips Audio Players & Recorders
My Zen Vision M 30GB mp3 player won't turn on, the blue light at the top flashes but the screen won't pop up, not even when i plug it in to charge it (which it usually does automatically). Now, i tried to...
Mine does the same thing, You just have to leave it plugged in for a long time, and after a while the black screen with the battery that tells you it's charging will show up.
Trust me, it'll happen.
Jul 20, 2009 | Creative Labs ZEN Vision:M Digital Media...
Can't see Sumvision Cyclone HDD on PC
see this link
http://docs.google.com/Doc?id=dgcfqncj_0cnqvx5gt
Jan 27, 2009 | Sumvision Sempra PRO Digital Media Player
Blank screen
right mouse click on the desktop now show the desktop icons? was this ok?
Sep 18, 2007 | Dell Inspiron 6000 Notebook
My screen is messing up
Hi hope this helps. Turn off your e260. Slide the hold switch for it to show red/orange color. Then press the record button and the menu button until you see on the screen of the player "Welcome to Recovery Mode". Now go to the sandisk website and download the firmware update if you have not tried to update the firmware of the player. Run and install it on your computer, when it ask you to connect a device hook your player to the computer and then it will try to look for updates for the player. When it does update the firmware of the player. And also if you can get to the menus of the player you may want to format the player maybe it is your songs causing the problem. Switch the player to MSC then open My Computer and format your player on that window.
Jun 17, 2007 | SanDisk Sansa e250 MP3 Player
Wont connect
Try using Windows Media Player (version 11 should be fine) to sync music files to it. Using drag-and-drop to the device folder only sometimes works (and usually doesn't).
May 31, 2007 | Philips HDD1630 MP3 Player
Philips HDD 1620 will not let me view pictures
Open the mp3 player on your computer and make another folder next to it and put the folder containing your picture in that new folder.
Jun 04, 2006 | Philips HDD1630 MP3 Player
Philips HDD1630 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
