Brother Hl-5240 Laser Printer leaves black lines down page when printing
  • Anonymous Jan 29, 2009
    boo
Replace drum if you've tried cleaning corona wires, if no improvement fuser nearing it's life end?
Posted on Jun 11, 2010
Brother hl-5420 leaving imprints
Replace the wiper blade which has been fixed under the drum
Dec 08, 2011 | Brother HL-5240 Laser Printer
I have a Brother HL-5240 laser printer at work, when the printer has not been used for a while, for instance, first thing in the morning. The printer will print 2 thick wavy lines probably about an inch...
there is no problem with printer cartridge, but there is a problem with printer drum unit.
Open the front cover and pool out the drum unit. You will see the blue arrow on the one side on the top of unit. Slide this arrow from left to right few times. If this doesn't help you can get a small brush and try to clean the thin wire (transfer wire) inside the unit and discharge grid below the wire. This should help.
good luck
pifonski
Mar 03, 2011 | Brother HL-5240 Laser Printer
Brother HL 5240 Laser Printer Hi I hope you can
Hello
You need to re-install drivers of the printer. also check the USB cable.
Good Luck
Jan 07, 2011 | Brother HL-5240 Laser Printer
PRINT LABELS
You will need to use the manual feed slot which is above the paper tray.
The manual feed is meant for labels and envelopes
Dec 02, 2009 | Brother HL-5240 Laser Printer
My Brother 5240 laser printer has a red status light when i turn it on. I hit cancel job, and the light turns green. however, when i print a file, the file goes into the print queue for a few seconds then...
It may some paper jam inside your printer . open the front cover pull out the cartridge and look any jammed paper is there or not. if not the the problem may came from your toner drum.
Nov 25, 2009 | Brother HL-5240 Laser Printer
Prints thick black lines
Hello, Andrea.
Sounds like either your printer needs a new fuser assembly (If the teflon roller gets scratched or starts to disintegrate you will get lines or black marks on the page) or you need a replacement toner.
Hope this helps.
Sep 14, 2009 | Brother HL-5240 Laser Printer
Brother printer prints solid black on one side
This is caused by a faulty drum/charging circuit or laser unit. The drum is positively charged with static electricity and a laser draws the image onto the drum (changing the charge to negative) the toner is positively charged to it will adhere to the negatively charged image which is now on the drum. your problem is that the drum is either not being positively charged or the laser is charging the whole drum. There is a corona wire on the drum, remove the drum, sweep the corona wire (there will be a tab that moves left and right) and try it again. next step is to replace the drum. if you dont have a spare drum or one from another printer then it may be more cost effective to buy another printer as drums are quite expensive and it may not even be the problem.
Jun 16, 2009 | Brother HL-5240 Laser Printer
Black pages
Take a look here at the possible causes
http://www.printertechs.com/tech/print-defects/blackpages.php
Hope this helps
Remember to vote
good luck
Dec 03, 2008 | Brother HL 1440 Laser Printer
Black Lines
you need to change drum
elvis
Apr 18, 2008 | Brother HL-5240 Laser Printer
942 people viewed this question
jasbo
jasbo
