SOURCE: Zebra Printer TLP 2844-Z - Will not print from application - prints SM 10 53 4D
Hold the feed button while turning on the printer. After a config label
prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor.
If the red light comes on again, press down a bit on the lid, hit the
feed button and try to print again.
SOURCE: Printer issue in printing
I was told by Zebra tech to attach it with a parallel cable, click on Start, Run, type in CMD and press enter. This takes you to a DOS prompt. type in the following:
cd\ (enter)
ECHO O>LPT1 (enter)
ECHO ^default (enter)
ECHO ^default>LPT1 (enter)
Make sure you follow the capitalization exactly.
Hold the button down for a set of four flashes.
http://zebra.com/id/zebra/na/en/documentlibrary/manuals/en/printer_manuals/lp2844z_users_guide__en.DownloadFile.File.tmp/980410-001B_2844-Z_UG_en.pdf
SOURCE: Zebra TLP 2844 prints slow in WinXP, but fast in
when submitting the print, un-tick the collate box. Use the properties section to check the speed settings in the driver and try again
SOURCE: Zebra TLP 2844 Desktop Printer
The printer driver should be set to Continuous or it will think it is still Gap or Black Mark. Please adjust accordingly
