Question about Olympus Stylus 410 / ? 410 Digital Camera
AC adapter
Which AC adapter can I use with the Stylus Digital camera?
    Master:
  • 852 Answers
The D-7AC AC Adapter is designed specifically for the Stylus Digital camera. It outputs 4.8 Volts at 2 Amps. The stock number is 200850.
Posted on Sep 01, 2005
I have a olympus 7010 digital camera. everytime i try to turn the camera on, a orange light flashes and turns off. i've tried charging the battery numerous times.
The Olympus Stylus 7010 has a rechargeable lithium ion battery that will eventually wear out-- your battery could be at the point where it does not hold a charge any longer.
Have you previously noticed a degradation in battery life? If so, you can try replacing the battery or connecting the camera to a constant power source (like an AC adapter) to troubleshoot.
Mar 04, 2011 | Olympus Stylus 7010 Digital Camera
How do i charge my camera?
You can charge the Olympus Tough 3000 / Stylus Tough 3000 by both AC adapter wall plug and via USB using your computer.
Please let me know if I can assist you further.
Regards,
KYTechnology
Mar 01, 2011 | Olympus ? Tough 3000 / Stylus Tough 3000...
Format Stylus 500
Press >menu< button, select >mode< select >card< select >format< select >yes< press >ok< (menu button)
During formatting DO NOT open battery cover, card cover, or plug in AC adapter.
Make sure you have all your files saved on your computer or elsewhere before formatting your card, since all images will be deleted.#
Hope that helps
Jul 27, 2010 | Olympus ? Stylus 500 Digital Camera
Battery empty message when connecting olympus sw 1030 to laptop
Your recharged battery may be weak. May be time to replace.
If the battery power runs out while the camera is connected to a computer or printer, the image data may be lost or damaged. It is recommended that you
use the AC adapter. Do not connect or disconnect the AC adapter while the camera is connected to a computer or printer.Do not remove or load the batteries or connect or disconnect the AC adapter
while the camera is turned on. Doing so could affect the camera’s internal settings or functions.
Sep 02, 2009 | Olympus Stylus 850SW Digital Camera
Charging problems
The AC adapter is only used as an alternate power source for the camera. It is not intended to charge the battery for the camera in any way. In order to charge the camera's lithium battery you will need the charger that is designed for that battery.
Apr 11, 2009 | Olympus Stylus 600 Digital Camera
Batteries AND ac adapter?
Make sure the ac adaptor ius the right polarity for the camera, negative outside plug and positive centre,also make sure the voltage output of the charger is correct 5 volts dc.You do not need batteries as well as the charger.
Sep 04, 2008 | Toshiba PDR-M60 Digital Camera
AC adapter supplied by a third party
No, Minolta cannot guarantee the compatibility of any third party AC Adapters. We recommend the use of Minolta AC Adapters, AC-1L, and AC-2L. Any damage caused to the camera as a result of use of a third party AC Adapter may void your warranty.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
AC adapter
The D-7AC AC Adapter is designed for the Olympus C-60 Zoom Digital Camera. It outputs 4.8 Volts at 2 Amps. The stock number is 200850
Sep 04, 2005 | Olympus Camedia C-60 Zoom Digital Camera
A/C adapter
Yes, the D-7AC AC Adapter is available.
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
AC adapter
Sep 01, 2005 | Olympus Camedia Stylus 300 Digital Camera
Olympus Stylus 410 / ? 410 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
