Question about Fujitsu 24C1 Air Conditioner
FUJITSU SPLIT AIR REMOTE CONTROL PROBLEM
The timer light is flashing and I can't figure out how to reset the unit via the remote. Unit now only produces fan air. No cold air. Thanks/Aloha, Jim
james.rollison@navy.,mil
  • 2 more comments
  • vwphoto Sep 12, 2008
    i have the same problem
  • mike40033 Dec 14, 2008
    I have the same problem too. The timer light flashes in sets of three blinks, no cold air comes out
  • hendroid05 Jan 17, 2009
    i have a same problem, after my 3 weeks holiday my aircon doesnt work, the green light for timer is flashing together w/ red led light. no fan even the outside.. i think its a timer problem..
  • Anonymous May 07, 2009
    Timer light is blinking, indoor fan is operating but outdoor unit will not run. Just installed today.
I had a similar problem with only fan air then the blinking lights, found out that mice had got into the circuit board and corroded some connections with their urine. I would try the above solution by turning the power off for ten sec first but remember that you have to leave it for a few minutes before you operate remote.
Posted on Jan 27, 2009
  • 236 Answers
Blinking led in the unit means some error or defect in the unit. It stops the remote control from working to protect the unit from operating with defective parts to avoid severe damage to the unit.
Try to reset the unit by disconnecting the power supply for 10sec. then on the power supply again and test. If it wont work then there are some defective parts in the unit that need to replace.
Posted on Jan 21, 2009
I have a 220v system and I had the same problem when we used a 110v line by accident. Once we ran the proper voltage it started up fine.
Remote control functioning unit is functioning, but remote control is not activating unit, could you please help. Part number is 9365005019.fujitsu room split air coditioner
Hi Russell Webe, just a guess, but sounds as though the remote receiver board is faulty, however you might try new batteries in the remote first,it may help. failing that it is time to call the serviceman. Also try turning the power off to the Ac unit for about 5 minutes and then back on again. This will reset the electronics and again may solve your problem regards. col www.digitalcontrols.com.au
Feb 23, 2011 | Fujitsu 24R1 Air Conditioner
Air con not working. Operation and timer lights flashing, then operation light flashes and then lights go off. Air con is blowing air but the outside unit is not blowing any air.
First check your timer on and off. If you want to reset, remove batteries from remote and power off to unit. Reset it. Now run the unit. Set temp mode once again in your remote and wait for 3 minutes. If still out door unit not working, check power line to out door unit.
Dec 31, 2010 | Fujitsu Heating & Cooling
Fijitsu wall mounted split system operation and timer lights are flashing, and the air con is not blowing cold air, only like fan operating even in cool mode.
This the common problem with all a/c holders. Without knowing the function of Timer on and Timer off, if it's pressed the unit will start only at setting time.
Please remove the battery from your remote and reset it. And then with use of your manual, set the timer if you need., otherwise normal function will be activated.
Dec 11, 2010 | Fujitsu Heating & Cooling
The operation and timer lights on my Fujitsu split system are flashing on and off several times when the unit is switched off I noticed this after the system had stopped blowing air & I knew the room...
I have same problem like yours to my newly installed Fujitsu multi-split system (the first time use since system installed 1 week ago). I rang the electrician who did the installation; he said it must be the units themselves nothing to do with electricity.
Okay, then I rang Fujitsu and their local service agent. They suggested me to switch off C/B for an hour to reset the units. I followed the instruction but the indoor units still did not respond to remote control...
It simply looks like no power supply to indoor units (they are hard-wired to the outdoor unit). So I used a multi-meter to test the power terminals of indoor units (Danger! If you have no idea about this, don't even try! ): it seemed no power supply even C/B is on. I turned to the isolator which next to the outdoor unit. The isolator was making arcing noise when I switched it on and off. The indoor units suddenly turned on for few minutes then died again.
So I figured out the problem is that crooked isolator. I called the unhappy electrician to replace the isolator. End story....
I hope my experience will help you a little bit.
Jul 11, 2010 | Fujitsu 24C1 Air Conditioner
Control seems to be working but unit not responding.
Check your remote control by using a camera or cellphone camera as your eyes to confirm if the remote control is ok. Point the remote control transmitter to your camera and check if a light emits in your remote control transmitter. If no light then the remote control is defective, but if the light is present then the remote is ok and the unit receiver board itself is defective.
Check also if there is a reset or rst button on the remote control, press the button and test the remote.
Jan 21, 2009 | Fujitsu 24C1 Air Conditioner
Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Dec 01, 2007 | Heating & Cooling
Fujitsu 24C1 Air Conditioner Logo
1,481 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
