Question about Super Tutor Trigonometry (ESDTRIG) for PC
Addition 1+1
= 2
Posted on Aug 28, 2008
Hi , can you tell me what is the torque settings for Main,biggens and head bolts for Opel combo 1.4 16v 2006 model z14xep motor?
STANDARD TYPE GM ROD BOLTS
STAGE 1---18 LB/FT (GRAPHITE GREASE UNDER HEAD, OIL THREADS)
STAGE 2---30 DEG's additional bolt head rotation.
CRANK BOLT
GRAPHITE GREASE UNDER HEAD & WASHER, OIL THREAD
STAGE 1---70 LB/FT
STAGE 3---15 DEG's additional bolt head rotation.
CYLINDER HEAD BOLTS for standard gaskets
GRAPHITE GREASE UNDER HEADS & WASHERS, OIL THREADS
SEE SEPARATE SHEET FOR TIGHTNING SEQUENCE
STAGE 1---18 LB/FT 25NM
STAGE 2---90 DEG's additional bolt head rotation.
STAGE 3---90 DEG's additional bolt head rotation.
STAGE 4---90 DEG's additional bolt head rotation.
STAGE 5---45 DEG's additional bolt head rotation.
Nov 06, 2016 | Opel Cars & Trucks
InPageError
Check for any virus/worm and try to do a system restore.
Dec 25, 2013 | Microsoft Windows Vista Home Premium with...
Problem Event Name: AppHangB1 Application Name: YahooMessenger.exe Application Version: 9.0.0.2152 Application Timestamp: 49c1a403 Hang Signature: 441b Hang Type: 1 OS...
Just uninstall it through control panel then install the latest version and you shouldn't have a problem. Cheers from Scott and plz vote
Jan 13, 2011 | Computers & Internet
What are the torque settings of the j2 1.8GLS 1996 hyundai elantra
cylinder head bolt torque
10 mm bolts
step 1 22 ft lbs
step 2 additional 60 degrees
step 3 additional 60 degrees
12 mm bolts
step 1 26 ft lbs.
exhaust manifold nut 32-41 ft lbs.
intake manifold nut 11-15 ft lbs.
rocker cover 71-86 in. lbs.
Dec 14, 2010 | Hyundai Motor 1996 Elantra
UNDERSTANDING MATH PROPERTIES OF REAL NUMBERS
Hii,here is list of basic real numbers properties applying them you can solve the problems easily.
Assuming a,b,c,d are real numbers:
1)Commutative Property
a) Property of Addition: a+b = b+a
b)Property of Multiplication: ab = ba
2)Associative Property
a)Property of Addition: (a+b) + c = a + (b + c)
b)Property of Multiplication: ( ab )c = a ( bc )
3)Additive Identity:
a+0 = a where 0 is the additive identity
4)Additive Inverse:
For real number a, there exists -a such that
a+(-a) = 0
5)Multiplicative Identity:
For real number a,
1 X a = a
where 1 is the multiplicative identity
6)Multiplicative Inverse:
For real number X where a≠0, there exists 1/asuch that
a X(1/a) = 1
7)Zero Product Law:
If ab = 0, then a=0 or b=0 or both a and b = 0.
8)Distributive Properties:
a)Left distributive law
a (b + c ) = ab + ac
b)Right distributive law
(a + b) c = ac+ bc
Jun 09, 2010 | Vivendi Excel@ Mathematics Study Skills...
What is the torque rear end bearing cap on a 1500 1999 chevy
Main Bearing Cap Bolt
4.3L
Step 1 15 (20)
Step 2 Additional 73 Degrees
5.0L & 5.7L
2-Bolt Main 77 (105)
4-Bolt Main Inner 77 (105)
4-Bolt Main Outer 67 (90)
4.8L, 5.3L and 6.0L
Main Bearing Cap Bolt/Stud
Inner
Step 1 15 (20)
Step 2 Additional 80 Degrees
Side 18 (25)
Outer (Stud)
Step 1 15 (20)
Step 2 Additional 53 Degrees
Jan 07, 2010 | 1999 Chevrolet Silverado 1500
Sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe ...
sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe Application Version: 4.3.4.17 Application Timestamp: 44fd31e8 Fault Module Name: ProfileU.exe Fault Module Version: 4.3.4.17 Fault Module Timestamp: 44fd31e8 Exception Code: c0000005 Exception Offset: 00001fda OS Version: 6.0.6002.2.2.0.768.3 Locale ID: 1033 Additional Information 1: 253c Additional Information 2: 287b034b0bef0590cba0ccef4c4b4b77 Additional Information 3: 7de0 Additional Information 4: bfe79fb32a74e3eb99cc45f1169d5e8b
Aug 07, 2009 | Computers & Internet
Replacing the head on a 1992 toyota 1.6 what are the torque specs i will need
There are apparently 2 different 1.6 motors.
The 4AFE: front 8-6-1-3-9
of vehicle 10-4-2-5-7
tighten in 3 steps, 1. 20 ft lbs 2. 30 3. 44
The 4AGE front 8-4-2-5-9
of engine 10-6-1-3-7
tighten in 5 steps: 1, 10 2. 15 3. 22 4.an additional 90degrees and 5. an additional 90 degrees again.
Jul 19, 2009 | 1991 Toyota Corolla
Computers & Internet Logo
51 people viewed this question
Top Super Tutor Computers & Internet Experts
ali_zulfikar
ali_zulfikar
cwradio73
Are you a Super Tutor Computer and Internet Expert? Answer questions, earn points and help others
