Question about Lucent PARTNER18 Corded Phone
158d telephone system
How to install the horn for the paging system
  • Lucent Master
  • 2,460 Answers
If you have paging now, it's easy to get one that looks the same from Valcom, Bogen, etc.
If you're doing it from scratch, look at the Viking Electronics Pa-2a. It plugs into the Page or trunk port of an ACS and includes one trumpet.
Carl
Posted on Sep 05, 2008
Horn relay where is it located
Could have DTC"S
B1217 Horn Relay Coil Circuit Failure SJB REFER to Section 413-06 . B1218 Horn Relay Coil Circuit Short to Battery SJB REFER to Section 413-06 .
If the relay had a problem a DTC would be set .
PINPOINT TEST B: THE HORN IS ALWAYS ON Test Step Result / Action to Take B1 CHECK THE HORN SWITCH
  • Remove the driver air bag. Refer to Section 501-20B .
  • Does the horn continue to sound?
Yes
GO to B2 .
No
INSTALL a new driver air bag. REFER to Section 501-20B . TEST the system for normal operation. B2 CHECK THE HORN SWITCH HARNESS FOR A SHORT TO GROUND
  • Key in OFF position.
  • Disconnect: Horn Switch Harness.
  • Key in ON position.
Yes
GO to B3 .
No
REPAIR or INSTALL a new horn switch harness as necessary. INSTALL the driver air bag. REFER to Section 501-20B . TEST the system for normal operation. B3 CHECK THE CLOCKSPRING
  • Disconnect: Clockspring C218a.
Yes
GO to B4 .
No
INSTALL a new clockspring. REFER to Section 501-20B . TEST the system for normal operation. B4 CHECK CIRCUIT 6 (YE/LG) FOR A SHORT TO GROUND
  • Disconnect: Smart Junction Box (SJB) C2280a.
Yes
GO to B5 .
No
REPAIR the circuit. TEST the system for normal operation. B5 CHECK CIRCUIT 1 (DB) FOR A SHORT TO VOLTAGE
  • Install the driver air bag. Refer to Section 501-20B .
  • Disconnect: SJB C2280b.
Yes
No
GO to B6 . B6 CHECK FOR CORRECT SJB OPERATION
  • Disconnect all the SJB connectors.
  • Check for:
    • corrosion
    • pushed-out pins
  • Connect all the SJB connectors and make sure they seat correctly.
  • Operate the system and verify the concern is still present.
  • Is the concern still present?
Yes
INSTALL a new SJB. REFER to Section 419-10 . CLEAR the DTCs. REPEAT the self-test.
No
The system is operating correctly at this time. The concern may have been caused by a loose or corroded connector. CLEAR the DTCs. REPEAT the self-test. TEST the system for normal operation.
Dec 26, 2016 | 2007 Mercury Mariner
The horn dose not sound when button is pushed on steering wheel. Passenger air bag is off, and how can I turn it on to operational mode
As far as the passenger airbag is concerned - OFF may be normal. This is an excerpt from the owner's manual (page 1-67).
Passenger Sensing System
The vehicle has a passenger sensing system for the
right front passenger position. The passenger airbag
status indicator will be visible when you start the vehicle.
The word OFF or off symbol will be visible near the
clock, located in the center of the instrument panel,
during the system check. See
Passenger Airbag Status
Indicator on page 3-27
When the system check is complete, either the words
ON and OFF or the symbol for on and off will be visible
under certain conditions.
The passenger sensing system will turn off the right
front passenger frontal airbag and seat-mounted
side impact airbag (if equipped) under certain conditions.
The driver airbags are not part of the passenger
sensing system.
The passenger sensing system works with a sensor that
is part of the right front passenger seat. The sensor is
designed to detect the presence of a properly-seated
occupant and determine if the right front passenger
frontal airbag and seat-mounted side impact airbag
(if equipped) should be enabled (may inflate) or not.
The horn is another matter. There are four possibilities here. I will list them in order of likelihood:
  1. Bad switch in the steering wheel. These are common failure items.
  2. Bad horn relay
  3. Bad horn assembly itself
  4. Faulty wiring in the horn circuit (including fuse)
You can have the switch(es) replaced in the steering wheel, but they are just as likely to fail again. I have had this issue happen in the past, and I simply went to the bottom of the steering column, found the horn button wire, and installed a dashboard mounted horn button. It is legal in most jurisdictions for inspection purposes as long as the button is easily accessible by the driver.
Dec 15, 2015 | 2005 Chevrolet Aveo
Horn started honk when the start button is pushed
bad horn switch or security system when nuts.
you will need the FSM to diagnose this, complex it is.
owning a hybrid means , close by toyota mechanics. all the time.
complex to the extreme. read the FSM , it NY telephone book sized.
be the first clue.
but can be diagnose. we look at the 2 inputs to the horn relay
is either active, at horn honk time
if its the horn line then its bad
if its the security system that is bad.
if its a PITA, pull the relay. end honks for ever. or horn wire.
Jan 17, 2014 | 2008 Toyota Highlander Hybrid Limited 4WD
Some 3Com NBX telephone 3102's can access paging but has no audible
If the system is in "IP on the Fly" mode you will need to add IP's to the IP pool on the system. If you aren't using any remote phones you can put the system in "Ethernet only" mode and you won't need to worry about the additional IP's. Also, ihave seen problems where you need to make sure that IGMP snooping is enable on the switches for paging to work.
Apr 05, 2013 | 3Com NBX® V3000 (3C10600BUS)
What is the activication code for tradewinds 2??
06C9-7C5B-B06B-D824-B3BC-2672-C82C-24BE-4E52-2060-158D-EF8B
Feb 03, 2011 | 2K Games Tradewinds 2 for Windows
I need unlock Codes for a Wild Tangent Game called Tradewinds 2 where can i find them?
Try this
Tradewinds 2
E-mail: jank184@hotmail.com
s/n: 06C9-7C5B-B06B-D824-B3BC-2672-C82C-24BE-4E52-2060-158D-EF8B
Jun 10, 2010 | Computers & Internet
Horn does not work on my 1999 harley davidson Fat By motorcycle
First check the two wires going to the rear of the Horn. One ground One Power. If they are connected to the horn then check the ground wire it comes lose most often. If you have power to the Horn then the Horn is defective. If you have no power to the horn it is necessary to trace up to your switch houseing. Usually the problem is ground, I have found defective horns but not often. You can take the horn off and using a battery and wire touch the two prongs in the back of the horn.If it works then the problem is either ground or power. Make sure horn is grounded. Usually the problem is a grounding one. Good Luck.
Mar 13, 2010 | Harley Davidson Harley-Davidson Motorcycle...
"where is the Horn Location for 2001 Chevrolet Malibu"
Horn Replacement Removal Procedure
  1. Remove the right headlamp assembly. Refer to Headlamp Assembly or Headlamp Bulb and/or Cornering, Sidemarker, Park, Turn Signal Bulb Replacement in Lighting Systems.
  2. Disconnect the horn electrical connector.
  3. Remove the horn bracket bolt.
  4. Remove the horn from the front frame rail.
Installation Procedure
  1. Position the horn to the front frame rail. Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  2. Install the horn bracket bolt. Tighten
    Tighten the bolt to 10 N·m (89 lb in).
  3. Connect the horn electrical connector.
  4. Install the right headlamp assembly. Refer to Headlamp Assembly or Headlamp Bulb and/or Cornering, Sidemarker, Park, Turn Signal Bulb Replacement in Lighting Systems.
May 17, 2009 | 2001 Chevrolet Malibu
158d system
The paging connects to one of the line ports on the system. Its needs to be specified in system programming which line you will be using. When you login to System programmiing (feature-0-0-left intercom--left intercom) you can go to Loudspeaker Paging Line #617, then select an unused (available) line. (feature-0-0) to save. Then go to the system and the port of the line you selected is where you will connect the signal leads to the paging horn. Then use Intercom *70 to page or program a paging button
Aug 25, 2008 | Lucent PARTNER18 Corded Phone
Lucent PARTNER18 Corded Phone Logo
69 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Computer Repairing
Computer Repairing
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
