Hot water coming out onto roof from hot water tank
    An expert who has answered 500 questions.
  • 540 Answers
Bad valve, just shut it off from the hand valve! and replace it later on! thank-you -very-much!
Posted on Aug 25, 2008
Black water coming out of returns from solar panels on roof of my home. Panels are 15 years old and there was frost in San Diego the nite before it happened
How do solar hot water panels work? - Explain that Stuff
Jun 2, 2015 - Photo of solar hot water panels on house roof. ... What if you cut the top and bottom off a plastic bottle and fitted pipes at each ... This is the technical name for the big black panel that sits on your roof. ... The heat is then passed into the hotwater tank, and the cooled water (or fluid) returns to the collector to ...
Solar water leak - YouTube? 1:46 22, 2012 - Uploaded by EnovativeGroupLeaky solar system, enovative group investigates... ... Solar water leak ... Solar Water Heating Panel and ...Pool Solar Panel - A How to Fix - YouTube? 2:50 7, 2012 - Uploaded by Clive WoodrowEasy and cheap way to fix a leak in your pool solar panel. ... The pipe (to carry the water to and from the ...
Dec 21, 2015 | Solar Pool & Spa
How do I install my hot water heater?
Youtube offers many videos of the water heater installation. Drain first with a garden hose. after turning off water and unplugging electric or shut off gas.
If changing to a tankless, remember they often require a larger vent pipe to the roof. 4" usually, not the 3" for tank water heaters. Local building codes may require a permit and a larger Gas feed pipe.
Also if you're going to use the old Pressure Relief Valve DO NOT test the valve by activating the little lever. Once used over time their internal seals weld onto the closed seat and tend to rip and leak if you test the valves function. Replace with new ( $15) if it's been operated. Most plumbers now use Braded Feed Lines from/to the Water sources, making future replacements easier. You might find the replacement Tank is not the same geometry as the old one, having longer braided feed lines helps when they are on opposite ends of the tank top and the original feed lines are copper and wont reach the new tank pipes or the tank gas starter door is on the back side requiring you to rotate the tank 180. If you're changing size, measure the width and height. It might not fit the old installation.
Hot water heater sweeting from top
Water on top of gas heater can be caused by poor venting, or inadequate combustion.
Make sure water is not coming up from under tank top, indicating tank leak requiring tank replacement.
Have a plumber look at problem to make sure home is not filling with deadly, odorless CO gas.
Inspect pipes that they are not corroded and covered with condensate.
Check that roof cap is in place.
Let heater fire and burn for a few moments so the fire is going good, and then light match just outside the draft hood on top of heater. Blow out match and see if smoke draws immediately into vent and upward.
Aug 31, 2012 | RHEEM 50 Gallon FVR NATGAS Water Heater...
I have a thermostat mixer shower but hot water has become minimal recently, even when water is piping hot from the taps? The shower is fed from cylinder tank on 1st floor, and cold water tank is in the...
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
Feb 17, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Hot water comes out cold side for few seconds and gets cold, no hot from hot side, only cold
Make sure that the water pipes for the cold water coming in and the hot water going out are connected to the correct positions on the water heater. If the connections get reversed, the water that is supposed to be hot will be drawn from the bottom of the tank and will not be as hot as it should be. The cold water input goes to the bottom of the tank. The hot water out comes from the top of the tank.
Oct 09, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Gas water heater pilot goes out only on very hot days
It sounds more like the pilot is being blown out by drafting.If there is any open shielding at or below the pilot light line , it is very possible for it to blow out.Hold a tissue between your fingers and ck for drafts around the burner and pilot area. If it's the case, The drafting needs blocking.the exhaust will still exhaust because of the heat it generates and confined location in the combustion chamber. Good Luck.
Jun 15, 2009 | Water Heaters
30amp breaker labeled heat strip trips and no hot water
That 300 amp breaker must be controlling both your hot water tank and some heat strip somewhere in your house which is designed to either prevent a pipe from freezing or melt ice on the eves of your roof.
please mark this answer as a fixya
Mar 05, 2009 | Weather King 10AJA2501AH Air Conditioner
Water coming from engine into overflow tank
Sounds like an overheating problem, best to get it checked, maybe thermostat stuck closed, pluged radiator, head gasget, cracked head.
Feb 08, 2009 | 2000 Cadillac DeVille
Water is coming out from under the dryer while drying clothes.
only one place water can come from a dryer area and that is if your vent duct comes out top of house or vent housing is pointed up and they catch water if it rains hard ,,, i would check my water for leaks or if you have a hot water tank close check it too ,,, water may be coming from washer and flowing down hill to under dryer and then running out ,,,, your dryer isn't leaking water i bet / larry
Dec 04, 2008 | Dryers
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
