Question about HP (DW017A) Ultrium Tape Drive
HP Ultrium 920 LT03 Drive - All media is 'Write protected'
My LT03 Drive passes all diagnostics but is unable to write to a tape as they are always sensed as being write protected. tried various brands of tape and even LT02 tapes but all are seen as write protected. Front mounted protect tag on tape doesnt change the situation so I think that the mechanism inside isnt capable of detecting the status of the tape.
The tape has been opened to remove a stuck cartridge so warranty is gone and I've been qoted £300-£500 to fix; Seems a lot for what appears to be a mechanical fault. Any suggestions or is there a technical manual anywhere for this drive? Thanks for yr suggestions.
  • 1 more comment
  • Robert Lloyd Aug 25, 2008
    SCSI Connection via 39160 adaptec card.
    Wouldnt mind if writeability was always enabled if this could be set somehow.. D22 firmware installed and uptodate.
  • Robert Lloyd Oct 04, 2009
    I took the drive apart and soldered the front two connections to the write enable switch together by dropping a small blob of solder across them. the unit now works fine but all tapes are available to be written to, even ones you might want to keep. Just need to be more careful, and software always prompts for overwrite... Still cheaper than the £300 quote.
    Scholar:
  • 74 Answers
It sounds like you have broken the write protect lever (that senses the WP tape switch position ) when you removed the tape.
This is a common problem when people lever out the tape without knowing that this lever helping is holding the tape in the drive.
Yes it will need to go away for a repair i am afraid
Try www.tape-drive-repair.com for this. They charge £295 for the repair (so at the lower end of your quoted prices) but they do then offer a 1 years warranty on the drive so you should be OK for some time to come.
Posted on Aug 24, 2009
Testimonial: "Correct, the lever had been broken, but more importantly the switch on the board had been damaged. By soldering across the switch it is now always on"
3 Suggested Answers
SOURCE: ultrium 920 sas install problem
update your SCSI controller drivers and power cycle the server
Posted on Aug 12, 2010
  • 19 Answers
Try to reseat the controller from the PCI slot.
Reseat the SAS cable.
Here are the drivers you may need:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3303460&prodTypeId=12169&prodSeriesId=4150338&swLang=8&taskId=135&swEnvOID=1060
Clean drive esl322e
You can open the housing, and remove the drive. Then open the drive, and use air under pressure to remove dust. Be careful, because if you don't know how the mechanism works, it could be the drive will not take in a tape at all.
I do have a IBM manual, where they show how to open the thing, but it is not easy. The ultrium LTO full high drives are all the same.
And I don't know how to get it with you.
Jan 26, 2014 | HP StorageWorks Ultrium 920 LTO-3 Tape...
Canon ir 2230
Hi Sharma
I think you might need to review this question, The Canon IR2230 does not use LTO Data tapes.
Refurbished Tape Drives Stock List for download Refurbished LTO drive
May 13, 2013 | Imation 17533 Storage media - LTO Ultrium,...
Its capacity, speed and price?
The new HP StorageWorks LTO-5 Ultrium Tape Drives, with up to 3TB* capacity per cartridge, include HP TapeAssure which provides comprehensive information about the status, performance, utilization, and health of the tape drive and media.
s.gif » DAT Tape Drives s.gif Affordable and reliable backup for entry-level servers and workstations
dat72usb-100x70.jpg s.gif • Capacities up to 320GB of compressed data per cartridge • Proven track record for dependable backup • Remarkably low media prices contribute to a very low cost of ownership s.gif s.gif » Ultrium Tape Drives s.gif Based on LTO technology for highest capacity, performance and reliability
ultrium960-100x70.jpg s.gif • Capacities up to 3TB of compressed data per tape • Ideal for midrange and high-end servers • Investment protection through two-generation backward read compatibility and a roadmap for future generations • Choose from high-performance full-height or affordable half-height drives s.gif s.gif
Feb 28, 2011 | HP Computers & Internet
What is the life time of 400 / 800 GB Data Cartridge for LTO Ultrium 3 Tape ?
The life expectancy for LT03 tape media is 30 years if kept in the proper storage environment (cool and dry). BTW StorageTek warranties LTO media for as long as you own the media and store it within the specified parameters.
Ideal conditions are 60 degrees F and 20% relative humidity. Note a 10% change in either temperature or humidity will shorten the lifespan by 50%
411byJay
Aug 14, 2010 | Dell 400/800 GB Data Cartridge for LTO...
LTO Ultrium 4 Drive/Lecteurs stuck in it
Check that 'Prevent Media Removal' is disabled
Check the Support Ticket Device Analysis for indications of a stuck tape
Run the L&TT*** "LTO Stuck Tape Test"
Try a normal eject operation--Make sure that you allow up to 10 minutes for completion
Perform an Emergency Unload
Reset the drive to reset the drive firmware
Use Library and Tape Tools (L&TT) to Upgrade your Firmware
***Download LTT from www.hp.com/support/tapetools
Jul 29, 2010 | HP StorageWorks Ultrium 960 Ultrium Tape...
Ultrium 920 sas install problem
May 10, 2010 | HP StorageWorks Ultrium 920 LTO-3 Tape...
May 05, 2010 | HP StorageWorks Ultrium 920 LTO-3 Tape...
No Compatible media found in HP Tape Drive
Try a brand new tape fresh out the wrapper.
If that doesnt work make sure you are using the right drive in your backup software!
It sounds like a message often seen in windows backup where you have selected the wrong tape drive from the list and it just tells you "No compatible media found" when actually the drive listed isnt even connected to your system still
Nov 27, 2008 | HP StorageWorks Ultrium 448 LTO 2 Tape...
I HAVE A ULTRIUM TAPE DRIVE 920 IT ALWAYS ASK ME TO OVERWRITE THE TAPE BUT THE TAPE IS NOT YET FULL WHEN IT REACH THE CAPCITY OF 300GB, IT ASK ME TO OVERWRITE THE TAPE???? CAN YOU HELP WITH MY PROBLEM
it asking you to overwrite because that is how you set up the backup job. Setup a new backup job using append instead of normal backup and the message will go away. Its not problem its a feature to prevent you from overwriting data.
www.SanDiegoFixMYPC.com
Jul 15, 2008 | HP (DW017A) Ultrium Tape Drive
HP (DW017A) Ultrium Tape Drive Logo
1,270 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
