Question about Lucent PARTNER18 Corded Phone
158d system how to install the horn for the paging system
  • 79 Answers
The paging connects to one of the line ports on the system. Its needs to be specified in system programming which line you will be using. When you login to System programmiing (feature-0-0-left intercom--left intercom) you can go to Loudspeaker Paging Line #617, then select an unused (available) line. (feature-0-0) to save. Then go to the system and the port of the line you selected is where you will connect the signal leads to the paging horn. Then use Intercom *70 to page or program a paging button
Posted on May 28, 2009
Horn relay where is it located
Could have DTC"S
B1217 Horn Relay Coil Circuit Failure SJB REFER to Section 413-06 . B1218 Horn Relay Coil Circuit Short to Battery SJB REFER to Section 413-06 .
If the relay had a problem a DTC would be set .
PINPOINT TEST B: THE HORN IS ALWAYS ON Test Step Result / Action to Take B1 CHECK THE HORN SWITCH
  • Remove the driver air bag. Refer to Section 501-20B .
  • Does the horn continue to sound?
Yes
GO to B2 .
No
INSTALL a new driver air bag. REFER to Section 501-20B . TEST the system for normal operation. B2 CHECK THE HORN SWITCH HARNESS FOR A SHORT TO GROUND
  • Key in OFF position.
  • Disconnect: Horn Switch Harness.
  • Key in ON position.
Yes
GO to B3 .
No
REPAIR or INSTALL a new horn switch harness as necessary. INSTALL the driver air bag. REFER to Section 501-20B . TEST the system for normal operation. B3 CHECK THE CLOCKSPRING
  • Disconnect: Clockspring C218a.
Yes
GO to B4 .
No
INSTALL a new clockspring. REFER to Section 501-20B . TEST the system for normal operation. B4 CHECK CIRCUIT 6 (YE/LG) FOR A SHORT TO GROUND
  • Disconnect: Smart Junction Box (SJB) C2280a.
Yes
GO to B5 .
No
REPAIR the circuit. TEST the system for normal operation. B5 CHECK CIRCUIT 1 (DB) FOR A SHORT TO VOLTAGE
  • Install the driver air bag. Refer to Section 501-20B .
  • Disconnect: SJB C2280b.
Yes
No
GO to B6 . B6 CHECK FOR CORRECT SJB OPERATION
  • Disconnect all the SJB connectors.
  • Check for:
    • corrosion
    • pushed-out pins
  • Connect all the SJB connectors and make sure they seat correctly.
  • Operate the system and verify the concern is still present.
  • Is the concern still present?
Yes
INSTALL a new SJB. REFER to Section 419-10 . CLEAR the DTCs. REPEAT the self-test.
No
The system is operating correctly at this time. The concern may have been caused by a loose or corroded connector. CLEAR the DTCs. REPEAT the self-test. TEST the system for normal operation.
Dec 26, 2016 | 2007 Mercury Mariner
The horn dose not sound when button is pushed on steering wheel. Passenger air bag is off, and how can I turn it on to operational mode
As far as the passenger airbag is concerned - OFF may be normal. This is an excerpt from the owner's manual (page 1-67).
Passenger Sensing System
The vehicle has a passenger sensing system for the
right front passenger position. The passenger airbag
status indicator will be visible when you start the vehicle.
The word OFF or off symbol will be visible near the
clock, located in the center of the instrument panel,
during the system check. See
Passenger Airbag Status
Indicator on page 3-27
When the system check is complete, either the words
ON and OFF or the symbol for on and off will be visible
under certain conditions.
The passenger sensing system will turn off the right
front passenger frontal airbag and seat-mounted
side impact airbag (if equipped) under certain conditions.
The driver airbags are not part of the passenger
sensing system.
The passenger sensing system works with a sensor that
is part of the right front passenger seat. The sensor is
designed to detect the presence of a properly-seated
occupant and determine if the right front passenger
frontal airbag and seat-mounted side impact airbag
(if equipped) should be enabled (may inflate) or not.
The horn is another matter. There are four possibilities here. I will list them in order of likelihood:
  1. Bad switch in the steering wheel. These are common failure items.
  2. Bad horn relay
  3. Bad horn assembly itself
  4. Faulty wiring in the horn circuit (including fuse)
You can have the switch(es) replaced in the steering wheel, but they are just as likely to fail again. I have had this issue happen in the past, and I simply went to the bottom of the steering column, found the horn button wire, and installed a dashboard mounted horn button. It is legal in most jurisdictions for inspection purposes as long as the button is easily accessible by the driver.
Dec 15, 2015 | 2005 Chevrolet Aveo
Where is the horn relay located on a 2007 ford edge sel
It is located in the SJB - smart junction box an it is a non- serviceable part . soldered to the board inside . Where do you hear the clicking noise coming from ? The SJB is located behind the left side kick panel .
SECTION 413-06: Horn 2007 Edge/MKX Workshop Manual DESCRIPTION AND OPERATION Procedure revision date: 10/30/2006 Horn The horn system consists of the following components:
  • Horn switches (part of the steering wheel)
  • Clockspring
  • Horn relay (part of the smart junction box [SJB])
  • Horn
For removal and installation of the steering wheel, refer to Section 211-04 .
For removal and installation of the SJB, refer to Section 419-10 .
Principles of Operation
The smart junction box (SJB) supplies the control and switched voltage to the horn relay (part of the SJB). When the horn switches (part of the steering wheel) are pressed, ground is supplied through the clockspring to the horn relay. The horn relay is then energized directing voltage to the horn and enabling the horn to sound. When the vehicle security system is armed, the SJB provides a momentary ground to the horn relay control side to indicate the system is armed, and an on and off ground when an intrusion is detected or the panic alarm is activated.
If your horns are not working ,you have a wiring problem or the clock spring is open . If the relay is bad the whole SJB has to be replace an the dealer would have to do that . Needs to be programmed ,with factory tool .
Symptom Chart Condition Possible Sources Action
  • The horn is inoperative
  • Fuse
  • Circuitry
  • Horn
  • Clockspring
  • Steering wheel switch harness
  • Smart junction box (SJB)
  • Go To Pinpoint Test A .
You
Dec 02, 2015 | Ford Cars & Trucks
What is the activication code for tradewinds 2??
06C9-7C5B-B06B-D824-B3BC-2672-C82C-24BE-4E52-2060-158D-EF8B
Feb 03, 2011 | 2K Games Tradewinds 2 for Windows
How to fix the horn. or rewire a horn. the previous owner stated that he took out the fuse for the horn because it would not stop beeping . I need the horn to work to pass safety
Apparently the previous circuit of horn is shorted making work all time.
Just check entire wires, relay and horn button in your car for shorted and have them fixed.
Otherwise you need to install new set of horn system ( horn button, wires and relay)
Dec 20, 2010 | 1989 Volkswagen Cabriolet
I need unlock Codes for a Wild Tangent Game called Tradewinds 2 where can i find them?
Try this
Tradewinds 2
E-mail: jank184@hotmail.com
s/n: 06C9-7C5B-B06B-D824-B3BC-2672-C82C-24BE-4E52-2060-158D-EF8B
Jun 10, 2010 | Computers & Internet
Where is the horn located under the hood of a 2005 gmc canyon
Horn Replacement Removal Procedure
  1. Remove the grille. Refer to Grille Replacement .
  2. Disconnect the horn assembly electrical connector.
  3. Remove the bolt that retains the horn assembly to the radiator support.
  4. Remove the horn assembly from the body.
Installation Procedure
  1. Install the horn assembly to the radiator support.
  2. Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  3. Install the bolt that retains the horn assembly to the radiator support.
  4. Tighten
    Tighten the bolt to 10 N·m (88 lb in).
  5. Connect the horn assembly electrical connector.
  6. Install the grille. Refer to Grille Replacement .
Nov 07, 2009 | 2005 GMC Canyon
"where is the Horn Location for 2001 Chevrolet Malibu"
  1. Remove the right headlamp assembly. Refer to Headlamp Assembly or Headlamp Bulb and/or Cornering, Sidemarker, Park, Turn Signal Bulb Replacement in Lighting Systems.
  2. Disconnect the horn electrical connector.
  3. Remove the horn bracket bolt.
  4. Remove the horn from the front frame rail.
  1. Position the horn to the front frame rail. Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  2. Install the horn bracket bolt. Tighten
    Tighten the bolt to 10 N·m (89 lb in).
  3. Connect the horn electrical connector.
  4. Install the right headlamp assembly. Refer to Headlamp Assembly or Headlamp Bulb and/or Cornering, Sidemarker, Park, Turn Signal Bulb Replacement in Lighting Systems.
May 17, 2009 | 2001 Chevrolet Malibu
158d telephone system
If you have paging now, it's easy to get one that looks the same from Valcom, Bogen, etc.
If you're doing it from scratch, look at the Viking Electronics Pa-2a. It plugs into the Page or trunk port of an ACS and includes one trumpet.
Carl
Aug 25, 2008 | Lucent PARTNER18 Corded Phone
Lucent PARTNER18 Corded Phone Logo
264 people viewed this question
Top Lucent Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Computer Repairing
Computer Repairing
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
