Question about Cavalry Storage Cavalry CADB001U32 1TB 7200RPM USB 2.0 3.5-Inch External Hard Disk Drive 500 GB Hard Drive
Hard Disk won't connect to my computer
I have a Cavalry 1TB external hard disk and it was working fine for a while until recently when I noticed that it has disappeared from 'My Computer'. I have tried connecting and disconnecting it to no avail. When it is connected, there are times when my computer plays the sound when something is connected and immediately after it disconnects. I can see on 'My Computer' the icon for my hard disk appearing and then disappearing immediately after that. I have not moved my hard disk at all and this problem just came up spontaneously. Any help would be greatly appreciated! Thanks!
  • 1 more comment
  • andromean Aug 25, 2008
    Thanks for your reply! I am running Vista and the drive is in the enclosure that is standard with the Cavalry CADB001U32 1TB 7200RPM USB 2.0 3.5-Inch External Hard Drive. The fan works fine and I have not noticed it getting hot nor have I noticed any weird noises coming from it. I don't think the disks are knocking around in there as I opened it up again to make sure everything was screwed tightly in place. Thanks!
  • Anonymous Oct 09, 2008
    I have the Cavalry 1TB drive, and it worked up until recently, but as of today, it is no longer being recognized by my computer, or any of my friends. i have Ubuntu, and they have Vista and XP.
  • sonicfury May 11, 2010
    What OS are you running? What kind of enclosure is the drive in? Is the drive wobbling around, or is it fixed firmly in place inside the enclosure? Does the enclosure get hot when it's on for a while? Does the drive make any noises other than the spinning/humming sound they make when they spin up and down?
    I have an external 500 GB HDD with a fanless metal enclosure that gets pretty warm when it's on for a while, and if I don't put a fan blowing on it, it overheats and "disconnects" from my computer. And before I put some padded tape in a couple of spots on the drive, it used to bump the enclosure when it was knocked, causing errors once in a while.
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
External hard disk not opened,how i can open?
Opening the drive on the computer or physically opening the drive enclosure box? 500GB is so small it's not worth spending too much time on getting it working.
Oct 10, 2014 | Cavalry Storage Cavalry CADB001U32 1TB...
My Cavalry 1TB USB 2.0 external hard drive will not connect to my computer. I have not had it for long, possibly 2 months. It worked fine all day today but tonight the blue light does not turn on. It...
Hey Jeff,
Sounds like this is something with info you need to keep..Keeping/securing/BACKING UP your data is your priority!! Personally, I would find a QUALITY (ASK a lot of questions.. can they guarantee their work,,- and NOT LOSE your data..!!) .. skip the geek squad - .. computer repair shop..(or some 10 year old).. I would first see if they could copy this drive to another drive (solid state) so you will not lose your data... we are at 4.0 with USB now... 2.0 is becoming the "floppy" of today..I have 3.0 drives and feel left out.. again.. securing/copying/backing up your data is paramount.. Good luck,,,
Sep 08, 2017 | Cavalry Storage Cavalry CADB001U32 1TB...
Computer stopped recogn drive after install utility progrm
you will probaly have to buy some expensive software to get your data back. or just reformat.
Nov 26, 2009 | Cavalry Storage Cavalry CADB001U32 1TB...
Calvary 1TB USB 2Bay external hard drive problem
The problem could be the enclosure, not the drive.
I would take the drive out of the Calvary enclosure and install it in another one. Hopefully it will come up and you can access your data.
Jun 15, 2009 | Cavalry Storage Cavalry CADB001U32 1TB...
Need help recovering from a Steel Vine software mistake
well..maybe, and that is a major maybe..sometimes, with really good tools, some of that can be recovered, like when a hard drive crashes. assuming there was no other backup, this is problematic. I recommend you seek a really top flight computer person. This will cost a bundle though.
Oct 22, 2008 | Cavalry Storage Cavalry CADB001U32 1TB...
Computer does not recognize new 1TB ext HD
First I had to reseat one of the drives which had worked loose and become unseated during shipping. Then I had to format the hard drive and finally I had a 1TB external hard drive I could use. The light is still red.
Jul 31, 2008 | Cavalry Storage Cavalry CADB001U32 1TB...
Broken Fan
You should be able to open up your external hard drive enclosure, find the right size fan, and order another one from almost any online store for cheap. You may even be able to go to some computer store nearby you and you may be able to get one there.
Jun 17, 2008 | Cavalry Storage Cavalry CADB001U32 1TB...
Cavalry Storage Cavalry CADB001U32 1TB 7200RPM USB 2.0 3.5-Inch External Hard Disk Drive 500 GB Hard Drive Logo
1,172 people viewed this question
Top Cavalry Storage Computers & Internet Experts
Arora Singh
Arora Singh
gary433
Glenn Smart
Glenn Smart
Are you a Cavalry Storage Computer and Internet Expert? Answer questions, earn points and help others
