Question about Microsoft Windows XP Home Edition
Sound No sound from speakers. Tried everything under HELP & SUPPORT. Still no sound. Indications are the sound card is OK - I had back of CPU off to clean inside unit. Worked fine until then. Cannot find any driver downloads that will work. I am now lost. Acelapage
  • 1,586 Answers
Maybe this is a foolish question, but are you positive the speakers work? Can you test them on another machine?
Posted on Aug 25, 2008
  • Jeremy Dellow
    Jeremy Dellow Aug 25, 2008
    It's possible that there's damage to the speakers you're using, so if you can try them out on another computer, or get a different set to try on yours, that'll clear that one way or another.
    Also, did you use the standard volume control on the lower right of the screen, near the clock? It's possible that the sound has been muted via checkmark on the subscreen for volume and tone control. Make sure that's not turned off.
No sound from ASUS P5VDC-MX
If everything is OK in Device Manager, check Audio in Sound and Audio Devices under Control Panel. The Sound playback should default to Device Manager device.
Plus, make Volume Controls are not muted.
Last, simply check with headphones.
Dec 09, 2012 | ASUS P5VDC-MX Motherboard
I cannot get sound on yahoo messenger pool game ive tried everything i reinstalled messenger 10 i cleared my cookies ive got the latest java and ive even tried to change profiles Ive checked my volume...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Apr 25, 2011 | Computers & Internet
Sound doesnt come out from guitar link UCG102
what you need to do is install the asio4all driver then select file, adio midi settings and where it says behringer audio codec click the arrow and select asio4all then click the configure button and in the wdm list you must activate all the items under audio codec and the audio speaker under High Definition audio device this will allow it to work through the speakers, or just leave it how it is and plug in a set of headphones. make note though that your speakers will play nothing else but the guitar sound. all other music internet sounds, the lot will no longer work as your ucg102 is high jacking your sound card to produce the sound from your guitar. hope this helps.
May 27, 2009 | Behringer (UCG102) Sound Card
I have a creative audigy Creative Labs Sound Blaster Audigy 2 Sound Card and Creative 7.1 surround sound speakers. When I was using XP all 7 speakers worked perfectly. Now with my newer Vista machine,...
Uninstall all sound drivers for the card. Delete all folder and use search to locate everything related to the sound card. Remove card , turn comp on w/o card. Turn off reinsert card.
Should fix it.
Vista has many,many issues like this.
If you have more types of sound listed in "SOUNDS" delete all but Audigy.
Re-install drivers AFTER you get ALL NEW VISTA UPDATES>
Mastersage
Feb 18, 2009 | Creative Labs Sound Blaster Audigy 2 Sound...
Hi. The audio sound failed on my Asus P4S800D mother board, so I installed an internal sound card, that solved the problem except that there is still no windows start up & shutdown all the usual...
check if you have right driver installed for your card ,and your integrated (realtek)chipset on your mobo ,than if its ok than go to,>control panel>sounds and audio devices>audio ,and check if your sound card is as a default audio device in the sound playback section ,and if this is 5.1 or 7.1 card check if your speakers are plugged into the right connectors and check advanced options to set up what kind of speakers you have plugged
Apr 09, 2008 | Computers & Internet
No sound
What exactly is evrything?
Reinstalled sound drivers?
Checked your speaker cord to make sure it comes into the green hole on the back?
made sure your speaker wires are not broken?
Volum on the speakers?
Control pannel> Sound> Speaker Icon: Are the controls HIGHLIGHTED? If not sound driver is not loaded.
Check Volum MUTE. SOme programs MUTE your volume without a warning.
Jan 04, 2008 | Behringer FCA202 - FireWire Audio...
HELP
ok what computers model u have ill get sound card drivers using limewire to play back music sucks use windows player 11 dl from windows update doinga custum scan then add software to left list so u get new stuff in windows what computer moodels do u both have ill help u get sound going with windows xp corect
Dec 16, 2007 | Logitech X-530 Computer Speakers
Sound Starts on Then Goes Off Randomly
I actually fixed the problem. It was a driver issue. Try this with your sound card program. I opened up the program in charge for sound. In my case it was soundmax. And pressed the load defaults button and clicked apply and everything started working again. The same thing happened again after a while so I pressed defaults again and it worked. But It happened again so I uninstalled the drivers and updated them. Everything was fine after that. Now I have a problem with my registry.lol
Hope it helps.
Nov 06, 2007 | Mach Speed P4MBMS Motherboard
Speakers not working proprerly
This may be in the sound card settings itself. Even though you may have adjusted the Windows settings {if thats what your using} the sound card needs to also be set up for surround. Some sound cards do not support 4 speakers or surround sound systems. Go to Device Manager and find your sound card and manufacture then check there technical support page for info.
Sep 07, 2007 | Audio Players & Recorders
My hp speakers wont work
Sample testing is usually a firmware built into the monitor amplifier ie the monitor is testing itself. you problem possibly lies with the computer sound system. Tell me more about this. Is it an 'On-board' sound card or separate PCI card. You can determine this by looking at the back of the computer- if all the connectors - sound- PS2 and USB are in the same panel - then it is an on-board system. If the sound is separate in one of the card position then it is a PCI card. The possibility is the sound system needs setting up- check your computer paperwork/manual and utilities disk for Audio drivers. Come back with some answers
Jun 23, 2007 | HP P5302M Computer Speakers
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
