Question about Electrolux Refrigerators
I have a dual voltage "Des Origio" refrigerator and wish to have it tested and serviced.
  • Electrolux Master
  • 19,396 Answers
If you live in US call
+1-877-435-3287If you are in a different country, select your country on website here.
Please rate solution appropriately.
Thanks.
Posted on Aug 25, 2008
GE refrigerator water dispenser not working
The water control valve has two side's, one controls the water to ice maker and the oher side controls the water dispenser. Most likely the water dispenser side has become defective and can no longer open the water valve to let water come to dispenser. You can test the voltage to the water dispenser side by useing a multi meter set for 120 volts and have someone press dispense water while watching the test meter. Use care not to be shocked while testing by not touching any bare probes or wires during testing. The coils can also be ohm test and both sides should be near to the equal amount of resistance. The location of the valves are listed as part 800 in this photo=> PSS26MSRASS Rear Parts Photo
Here is a Service Manual=> HERE
If you have any questions I will be here to answer them for you, Thanks Sea Breeze
Oct 27, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Where can i get fan motor for delfield 407a in des moines, ia. its the cooling fan in back not the one inside.
Hello Jfarrell677,
Here is your local service provider for Delfield in your area they should have the part or be able to order it for you.
Goodwin Tucker Service Co
2900 Delaware Avenue
Des Moines
Iowa
50317
USA
Email : dgoodwin@goodwintucker.com
Telephone : (515) 262-9308
Thank you for choosing FixYa.com
Justinbur167
May 11, 2011 | Delfield Undercounter Freezer - 407CA
Our ice maker has stopped making ice. I've replaced the water filter (we are still getting water through the door), the "arm" is in the down position, and the temperature is cold enough. Any...
If the cube slots are empty try filling with tap water and allow to freeze while arm is down. If cubes drop and the ice maker does not refill with water then the dual water control valve=> 67005154 Dual Water Control Valve Another possibility is the ice maker thermostat pictured here=> MZD2669KES Ice Maker Parts Breakdown item 13 in photo. If the test fails then it is sometimes better to buy the complete ice maker=> 7824706Q Ice maker Module
Jan 26, 2011 | Maytag MZD2669KES Stainless Steel Side by...
Water will not flow. It is a kenmore cold spot
Most likely the dual water control valve is not opening to allow the water to the dispenser if that is your meaning. Now if you mean water for both dispenser and ice maker then that would change everything. See if you can locate the model number that Sears puts on the door frame near floor. The fresh food section door at base and the number will look like this example 312.256489 With that number I can see everything your side by side came with and tell you the parts and locations. You also can have someone test voltage going to the water control valves while someone presses the dispense water switch. And with a voltage meter set to OHM's test the coils on the dual water control valves for resistance and if one has a very different number that can tell you. So we have several things to look for, water supply, dual water control, (if one works and other will not) and model number, Let me know what you find, Sea Breeze
May 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I interconnect a D-Link DES-10160 with D-Link Gigabit Switch DGS-1024D network and my network becomes slow
connect only DGS -1024D to your network....it will be faster...
because DGS supports 10/100/1000 speed.... but DES supports only 10/100 speed...
connect DGS directly to your network and work with that... if you wish to extend the number of ports then connect the DES to one of the ports of DGS
and dont connect DGS to one of the ports of DES
May 10, 2010 | D-Link DES-1024D Express EtherNetwork...
Why is the water not dispensing
Most likely the dual water control valve for the dispenser side has failed. You may test the power to the valve by unplugging the side that goes to the dispenser and placing a voltage meter into the female section of the wires and have someone press dispense while you read the voltage. If you get you normal voltage like 110 - 120 volts AC and the valve does not open then replacing the valve will solve this.Let me know what you find, Sea Breeze
Apr 19, 2010 | GE GSH25JFR Side by Side Refrigerator
Stério philips les 2 casettes ne fonctionne plus
Please write your problem in English, as this an English based web site.
Apr 06, 2010 | Philips Magnavox DVD/VCR Dual Player
I cannot get water from the water dispenser
OK can you get someone to test the voltage on the water control valve on the rear of the refrigerator. Someone needs to press dispense water while the other person test the voltage. I believe the dual water control valve on the rear for the dispenser side has failed. Could you send the model number? Thanks, Sea Breeze
Nov 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Need to order output wire harness for dual xdm6220 stereo
Hello cmknightro,
Unless you can find a friendly local Dual dealer, your best bet is probably to go directly to Dualav. Click on the "Parts Department" link at the right and it will bring up your email client to send an email to parts@dualav.com. Or, you may wish to call their toll-free customer service number shown in the center.
Hope this helps.
May 08, 2009 | Dual XDM6220 CD Player
Refrigerators Logo
77 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
