Garden Logo
Posted on Jul 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does the Ryobi, model CS26, curved shaft string trimmer require an air filter? I dropped it the other day and the cover over the carburator popped off revealing a place for an air filter but there was not one.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 03, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
687
Points
0
I have the exact same trimmer and mine did not come with an air filter. There is a screen, but that's all. There is nothing in the manual or parts diagram that shows an air filter. In fact, the manual on page 11 says, "For proper performance and long life, keep air filter screen clean".
Phil Walker
Level 3:
  • Master 610 Answers
  • Posted on Jul 05, 2011
Phil Walker
Master
Level 3:
Answers
610
Questions
0
Helped
250395
Points
1613
Yes it must have one to prevent engine wear, regards Phil.
Ryobi cs26
Mike it sounds like the head has sheared where it goes onto the shaft. You may be able to get the head off and see if there is any way of re attaching the shaft but it may be tricky. You could use the modelling clay that is also a resin that sets rock hard. (milliput) works for me.
Oct 18, 2013 • Garden
Is the Ryobi model CS26 considered a professional weed trimmer?
The Ryobi curved shaft trimmer is a consumer grade trimmer. Both the 26cc & the 30cc engines from Ryobi (Homelite) are pretty light duty. They have 1 piston ring and use an anodized aluminum piston and cylinder. A commercial grade engine would have 2 or 3 piston rings and the cylinder and piston would be chrome plated for longer life. Look for the emissions label on your trimmer. The emissions code of C would indicate a 50 hour emissions longevity (consumer grade). A code of B would indicate 125 hour emissions longevity (estate grade). A code of A would indicate 300 hour emissions longevity (commercial grade).
I hope this helps.
How do you change the string feeder on a ryobi gas
If your machine is a "bump feed" there should be a knob on the bottom of the string feed.....this is a LEFT HAND thread, so turn it clock wise and it should pop free and unscrew....re-string your cartridge and replace it tightening the knob counterclockwise until it stops....that should do it !!!... ;-D
1helpful
My ryobi grass trimmer will only run on 1/2 choke model RY 30524
Check for fuel supply problems (clogged cap vent, dirty tank fuel filter, clogged or faulty fuel intake lines, leaky or cracked primer bulb, air leak in rear crankcase cover...check 4 screws above gas tank, air leak in carb gasket...check carb nuts, trashed up carburetor...needs cleaning or rebuild, mixture screws need adjusting)....a myriad of possibilities here but I would guess it's a dirty carb....hope it helps
Bought a Ryobi weed trimmer CS26 from Home Depot. The second time I used it string broke both ends. Could not take it apart went to Home depot after 30 days they could not take it apart. They would not...
just cheap equipment. Mark it up to experience and do not purchase equipment fro home center or box stores ever again.
This is just one of the many problems of dealing with
the box stores rather than a full service qualified dealer. If you can
find one in your area, patronize them. Not just when the box store
lets you down but for everything. These type dealers are
disappearing and are not being replaced and soon they will all be
gone.
4helpful
2answers
Installing new string line for Ryobi 4 cycle straight shaft s430
Go to www.managemyhome.com and download a free copy of the onwers manual.
1helpful
The motor want turn the attachments i.e. string on the trimmer or blade on the edger
there is definitely a problem in the drive shaft. check to make sure there's nothing blocking the mal and female ends. if there is, clean it out and lubricate it so that the male will attach to the female slot. also check to see that both ends are not stripped. if the motor portion of it is stripped, which most liekly is out culprit, then it needs to be replaced, or you need to get a new trimmer. if you do, i recommend the Ryobi model CS26 gas trimmer.if the atachment shaft is stripped, the the attachment needs replacement. if you replace the motor portion you need not lubricate the attatchment slot. if the attachment is stripped, it needs to be replaced, but im quite sure the female end in the motor shaft is our problem. it could also be broken inside the shaft. make sure nothing falls out if you hold the attatching ends to the ground.
2answers
Was told to replace carburator and gas tank on ryobi string trimmer, which no doubt it needs. where can U buy these?
well if anyone is going to have that parts then its gonna be Ryobi the best solution I have to this is to contact them directly and even order the parts from their website
https://www.gardnerinc.com/recons/splash.php
The above link is to the ryobi outdoor parts replacement store.
Top Garden Experts
Jay Finke
Jay Finke
john h
