Question about Memorex (32025536) DVD-RW Storage Media
Not readable. I've been using Memorex rewritable 2X 4.7GB DVD-RW DVD without problems. Today I purchased a 25 pack Memorex rewritable 4X 4.7GB DVD-RWs but they don't work on any of my 3 players. Unknown Disc or no disc shows up on the screen. There is something on the disc but doesn't show. The last time I tried to put the disc in and re format (just in case) it tied up the computer and I had to do the Task Manager thing. It wouldn't open the door to the drive or stop trying to do ??? Are these just bad discs?
  • Memorex Master
  • 19,396 Answers
If the disks do not work on any of the three players they are probably faulty, try buying a spare disk of same kind , or writing a disk from a different pack, it it does work then you bought a box of faulty DVDs, ask a refund.
If disk from different box gives same problem when burned on same computer, then there may be a problem with DVD burning software, try doing a system restore to a recent date,
Posted on Aug 25, 2008
Cd-rw won't burn on by Dell laptop
Ah, where did you buy them? I have had the same problem when I buy such CDs on sale, my most recent purchase was at Staples. These are low quality CD-RWs and it could be the s/w or the driver you are using just does not recognize them as being blank CDs. I took mine back, got a full refund and purchased a well known/quality brand like HP or SONY, and no problems.
Again, Imitation has been known to have problems. I would stay away from them!
May 22, 2011 | Imation Products - CD-RW, Rewritable,...
It will not load certain dvd discs
Below is a list of discs that should or should not be used with the DVD recorders.
DVD-R
4x can be used
8x will result in a disc error.
DVD-RW
2x can be used
4x will result in a disc error.
The following discs have been tested and are proven to be compatible with our DVD recorders.
MEMOREX DVD-R
FUJIFILM DVD-R
FUJIFILM DVD-RW
IMATION DVD-RW
IMATION DVD-R 2.0
TDK DVD-RW 2X
TDK DVD-R 2X
The following are brands of discs we DO NOT recommend:
MEMOREX DVD-RW
SONY DVD-RW
SONY DVD-R
TDK DVD-RW 4x
TDK DVD-R 4x
Please be aware that a free software upgrade is now available to customers. This upgrade will enable your unit to recognize the (DVD-R 8x) discs. To obtain a copy, please call 1-800-242-7158. Customer service by phone is available 7 days a week 6:00am to 9:00pm pacific time.
In order to receive the upgrade we need to know what firmware version your unit requires. First you need to access the DVD recorders service mode. Turn on the DVD Recorder and the Television, make sure the unit is on the DVD side. You may access the service mode by pressing the CMSKIP button on the remote control. Once you press CMSKIP you must press the numbers 1,2,3. You must do this quickly so it may take a couple tries. The model name will appear on the screen followed by Firmware Version. I need to know the serial number next to FE:
Press the RETURN button to exit screen.
Brian W.
Customer Support
Funai Corporation
19900 Van Ness Avenue
Torrance, CA 90501
1-800-256-2487 Customer Support
1-310-320-0571 fax
Feb 07, 2010 | Emerson EWR20V4 DVD Recorder/VCR
I have a LG GE20 DVD Rewriter Is a DVD+RW disc a format that is editable and suitable for this unit?
The LG G20 DVD Rewriter is an advanced external burner that supports 'editable' Rewritable DVD+RW disk.
As a generic comment, not all writable/rewritable media are made equal and problem with branded & unbranded disks are not uncommon, so stick to brands that work for you for your specific unit!
The following is the advertised support for your unit, hope it helps:
Reading Rate DVD-R/-RW/-ROM 16x/13x/16x/16xSL/12xDL max. DVD-RAM 2x, 3x-5x, 6x-12x DVD-Video (CSS) 4,8x max. (Single/Dual Layer) DVD+R/+RW 16x/13x max./ 12xDL max. CD-R/RW/ROM 48x/40x/48x max. CD-DA (DAE) 40x max. Burning Speed DVD-R 2x, 4x CLV, 8xZCLV, 16x PCAV, 20X CAV DVD-RW 1x, 2x, 4x, 6x CLV DVD-RAM 2x, 3x ZCLV, 3x - 5x PCAV, 12x PCAV DVD+R 2.4x, 4x, 8x, 12x, 16x PCAV, 20X CAV DVD+R Double Layer 2.4x, 4x, 10x, 12x ZCLV DVD-R Dual Layer 2x, 4x, 6x CLV, 10x, 12x ZCLV DVD+RW 2.4x, 4x, 6x, 8x ZCLV CD-R 4x, 8x CLV, 16x, 24x, 32x, 40x, 48x ZCLV CD-RW 4x, 8x, 10x CLV, 16x CLV, 24x, 32x ZCLV
Dec 28, 2009 | Computers & Internet
DVD-RW will not record. Using Memorex DVD-RW and get the "Incorrect disc C104" message. Where can I get the correct disc and what are they? these used to work, but the new ones don't.
I have the same machine and I've used Memorex DVD-RW 2X/4.7gb/120min dvd's for a long time. The newer ones at Officemax are 4x, 8x, 16x and 52x they won't work. I think they have to be 2x only!!!
Nov 06, 2009 | Sansui VRDVD4005 DVD Player/VCR
I have Windows XP on my computer. What program do I use to erase information on a DVD+RW disk?
While the DVD in the Drive Open the windows Explorer and right click the DVD
Drive Letter and select Erase this DVD,
this Help?.
Jul 23, 2009 | Memorex (32025541) 25 Pack 4x DVD+RW...
Recording error
Refer to your user manual for error codes and troubleshooting tips.
If you cant find the error code then please kindly forward the following:
Disk Type:
Recording Device:
Hardeware Specifications:
May 26, 2009 | Symphonic SR90VE
Sony Precision Drive 3 DVD+RW
If you are using RW media, that could very likely be the source of the problem. Here are detailed instructions on how to determine or confirm the source of the problem.
http://docs.info.apple.com/article.html?path=iDVD/7.0/en/6669.html
After completing these steps, if it is caused by the DVD+RW media, re-record them on regular DVDs, and assuming your player will accept that media, they should play appropriately. Let me know if you need additional assistance, but thanks for rating FixYa!
Apr 27, 2008 | Memorex (32025541) 25 Pack 4x DVD+RW...
Recording DVD-RW
Make sure the discs you are using are the same as the ones listed as compatible in the manual:
• DVD-RW ver. 1.1 / 1x / 1x to 2x, ver. 1.2 /
2x to 4x / 2x to 6x
• DVD-R ver. 2.0 /1x / 1x to 4x /
1x to 8x / 1x to 16x, ver. 2.1 / 1x to 8x / 1x
to 16x
• DVD+RW 1x to 2.4x / 1x to 4x / 3.3x to 8x
• DVD+R 1x to 2.4x / 1x to 4x / 1x to 8x / 1x
to 16x
• DVD-RAM ver. 2.0 / 2x, ver. 2.1 / 2x / 2x to
3x / 2x to 5x, ver. 2.2 / 2x / 2x to 3x / 2x to 5x
• DVD-R DL ver. 3.0 / 2x to 4x
• DVD+R DL 2.4x / 2.4x to 8x
Any brand can be used.
Jan 11, 2008 | Pioneer DVR-540HX DVD Recorder/HDD...
Memorex (32025536) DVD-RW Storage Media Logo
174 people viewed this question
Top Memorex Electronics - Others Experts
Stu Morris K
tdk1988
Are you a Memorex Electronics - Other Expert? Answer questions, earn points and help others
