When I click on the install wizard to install my printer. It keep saying couldn't install because the wizard cannot find the necessary software. What does that mean?
  • 19,396 Answers
It means you need to download the driver software to install the printer on your system.
Ask a new question posting printer on model number, and ask how to download and install driver software for your model, driver requests are usually answered quickly.
Posted on Aug 25, 2008
How do i install a hp deskjet f 4280 all in one manually ?
You can't. There is too much software that controls the printer, cartridges, plus of course the Windows Drivers.
Software, Drivers and Manual in the link.
HP Deskjet F4280 All in One Printer
Feb 15, 2016 | HP Office Equipment & Supplies
Scanner doesn't work. It says no scan options,
You can check if the scanner driver is still installed by going to Control Panel\Scanners and cameras (if you have windows vista, you need to be in "classic view" in control panel)
If you see the HP scanner listed there, you can double click on it to run the windows scan wizard.
If this works you just need to find some scanning software, not necessary the HP one.
If there is no scanner listed, you will need to download the software and drivers which you can most likely find on the HP website.
Mar 25, 2010 | HP OfficeJet 6210 All-In-One InkJet...
When I insert my Cruzer Flash Drive, the Hardware Update Wizard pops up and asks if I want to install the software automatically. I then click "Next" and it says "the hardware was not installed because the...
Hello my friend.If your usb has U3 you must install U3 software.So download this.Insert your SanDisk U3 drive to your computer.
2. Double-click LPInstaller.exe
3. Click Next.
4. Select Accept then click Next.
5. Select Yes, backup and restore all data to restore your data after it is reformatted, then click Next
6. Click Next after confirmation of Installation Options.
7. Click Finish after the installation is completed.
Unplug it when is finished and plug it again and leave windows find it,dont do anything just wait the windows to set the device.
Feb 08, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How do i install logitech quickcam
please download necessary drivers and software from below link. this link is from Logitech website and you can download latest necessary software/drivers by clicking on Download.
http://www.logitech.com/index.cfm/webcam_communications/webcams/devices/3480&cl=gb,en
let me know if any issues.
Thanks.
Apurva
Jan 20, 2010 | Logitech QuickCam Communicate STX Personal...
Says unable to print
If you're using Widows XP, the solution may be the driver installation. On some printers, the drivers seem to install properly, but don't enable the printer.
Start by completely uninstalling the printer, and manually delete the drivers if necessary. Then put your driver disk into the CD drive, but when the installer comes up click EXIT or CANCEL.
You then need to go into Control Panel and open the Printers icon. Click on "install new printer" and follow the wizard until it gets to the where it says "install automatically" or "search for drivers". That is where you specify that you have the disk and follow the instructions to point the installer to the location of the printer driver disk. Then select the proper printer and let the system install the drivers that way. Most of the time with Brother Printers that will work.
Jul 17, 2009 | Brother MFC-5840CN All-In-One InkJet...
Canon PIXMA MP190 'not responding'
There are possible causes of this not responding status message you get. you will try out these option i have listed here and see which one resolves the problem. after each one, try to print from a file and from the web.
1. Configure driver to correct printer port
On the 'Ports' tab of 'Printer Properties' window, select the correct port for the printer driver.
From the Windows desktop, open the printer's properties window.
Click the Ports tab.
Below 'Print to the following port(s)' section, select the port to which your printer is connected.
Click 'Apply' to accept the changes.
Click General tab and then click 'Print Test Page' to confirm the changes corrected the issue.
2. Checking USB Connections
You should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists.
Disconnect one end of the cable and then reseat it ensuring the cable is firmly seated into the USB port. If the USB cable is plugged into a hub instead of directly into the computer, try connecting the USB cable directly into the computer.
Repeat step one to reseat the cable on the other end.
3. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
when you are through, restart the system.
4. Uninstall and Reinstall the Driver
If the MP Navigator or the MP drivers are no longer required, or if they are not installed correctly, uninstall them.
Caution: Uninstalling means deleting software, such as MP drivers, from the computer. Once the software has been deleted the unit cannot be used through the computer until the software has been reinstalled.
Note: Login as a user with Administrator privileges to uninstall . Turn off any programs running in the background, such as antivirus programs and firewalls before begining.
Select 'Program' (for Windows 2000), or 'All Programs' (for Windows XP / Vista) from the Start menu.
Select the name of the printer model to remove and select 'Uninstall.'
When the MP Drivers Uninstaller window is displayed, click 'Perform.'
When the confirmation window is displayed, click 'Yes.'
When the Uninstallation Complete window is displayed, click 'Complete.'
5. Reinstall the Drivers
Note:
The MP drivers can be installed using Easy Install or Custom Install.
Easy Install automatically installs the software which is in the CD-ROM.
This method is recommended if you are a first-time user.
Custom Install allows you to select the software programs from MP Drivers, Application Software, and On-screen Manual.
Login as a user with Administrator privileges to install on WindowsXP/Vista/2000.
Close any antivirus software that may be running prior to installing the drivers.
Turn off the printer and disconnect the cable connecting the computer and the printer.
Insert CD-ROM in the computer. (The CD-ROM will start automatically and the following window will be displayed on the screen.)
If the setup program does not start automatically, click 'Start' and go to 'My Computer', then double-click the CD-ROM icon.
If you use Windows Vista, select 'Computer' from the Start menu, then double-click the icon of the CD-ROM.
At the main installation window, click 'Easy Install' or 'Custom Install'.
When selecting Easy Install:
(A) Click 'Easy Install'.
(B) Click 'Install' in the following window.
* Display varies according to the printer model.
When selecting Custom Install:
(A) Click 'Custom Install'.
(B) When the following window is displayed, click 'MP Drivers' and the application software to be installed, and then click 'Next'.
When the License Agreement window is displayed, read the content carefully and click 'Yes'.
The installation will start.
Messages may be displayed during the installation of the application software.
Follow the instructions on the window and continue the installation.
When the Printer Connection window appears, connect the printer to the computer and power on the printer.
Note: If the installation cannot proceed even after 2 minutes, stop the installation by following the procedures below and start from the beginning again.
1) Click 'Cancel' at the Printer Connection window then click 'Start Over' at the Installation Failure window.
2) At the window to install the driver / applications appears, click 'Back' then click 'Exit'.
3) Restart the computer.
4) Install the printer driver again.
For Windows XP, at the Welcome to the Found New Hardware Wizard dialog box, confirm Install the software automatically (Recommended) is selected, then click 'Next'.
Note: The Welcome to the Found New Hardware Wizard dialog box may be behind the Printer Connection window.
In this case, click 'Found New Hardware Wizard' button on the task bar to display the window.
After the files are copied automatically and the dialog box Completing Found New Hardware Wizard window appears, click 'Finish'.
If the Welcome to the Found New Hardware Wizard dialog box appears again, click 'Finish' again.
At the Print Head Alignment window, click 'Execute'.
Note:
* The Execute button may not appear for all models. In that case, skip to step 13.
* The Print Head Alignment can also be done after the installation of the printer driver.
When the Start Print Head Alignment window appears, load one sheet of A4 or letter size plain paper in the sheet feeder and click 'Print Head Alignment'.
At the Do not start another operation until current one has finished dialog box, click 'OK'.
When the pattern is printed, click 'Next' at the Print Head Alignment dialog box.
At the Installation Results dialog box, check the content then click 'Next'.
The installation of the MP drivers and application has completed. Proceed to the Canon user registration.
If you want to register now, click 'Register'. If not, click 'Next'.
Registration can be done after the MP drivers installation.
Then, Inkjet Extended Survey Program will be launched. If you agree, click 'Agree'. If you do not agree, click 'Do not agree'.
At the Installation completed successfully dialog box, click 'Exit'.
Note: When the Restart button appears, confirm that Restart the system now (recommended) is checked then click 'Restart'.
May 22, 2009 | Canon PIXMA MX310 All-In-One Printer
Lost installation CD for printer
whats the model number of printer
Dec 13, 2008 | Office Equipment & Supplies
Lost cd for HP PSC 1410 all in one printer
If you do not have the disk you download software from Internet, follow instructions below,
Click right here.
A web page will open, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading, find thefile, double click on the file, if you get introubles ,then follow instructions below to reset and reinstall:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Sep 13, 2008 | Office Equipment & Supplies
I have a laptop an i am trying to install my lexmark z600 printer but it says the wizard cannot find the necessary software to install
Dear Trishawells,
You can download the driver for you printer , from this URL :
http://www.opendrivers.com/categorycompany/13/1287/printers-lexmark-free-driver-download.html
But first you have to select the proper model of your printer from the list, then download the driver and install it on your Notebook.
Cheerup and be happy always
Mar 04, 2008 | Computers & Internet
jasbo
jasbo
